Please help identify "lift"
Discussion in 'Suspension' started by TundraDan723, Jul 12, 2017.
  1. Jul 12, 2017 at 5:07 PM
    TundraDan723
    TundraDan723 [OP] Not as new as I used to be...
    2023 Celestial Silver Tundra 1794 TRD CM
    I recently purchased my truck that had a camper on it from PO. It has airbags on the rear suspension. In the front it has a spacer or something that seems to add lift. Can you help identify what type, and how much of a "lift" the truck has?
  2. Jul 12, 2017 at 5:10 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Urinal cake, for sure......
    Defintely a spacer lift. If you measure the space, that is about half "lift" you are getting from it.
    *Edited to provide accurate info, thanks @gosolo @16tunterd @csuviper
  3. Jul 12, 2017 at 5:15 PM
    TundraDan723
    Is this purely cosmetic or does it actually do anything functionally? Would it allow for slightly larger tires?
    My guess is that it isn't the proper way to lift a truck, is it?
  4. Jul 12, 2017 at 5:18 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I would like some suspension guru to confirm this, but the way I understand the front end geometry, the lift should be roughly double the thickness of the spacer.
    This looks like a 1" spacer so it's probably about 2" higher in front than it was when stock
  5. Jul 12, 2017 at 5:22 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    It's actually a negative for "functionality"
    It limits the shock.
    The only positive thing is by lifting the front of the body you increase your approach angle meaning you can climb over obstacles without hanging up on the bumper
    Law323 likes this.
  6. Jul 12, 2017 at 5:23 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    It does look like one of those things in the urinal!
  7. Jul 12, 2017 at 5:25 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I am not a suspension guy, I have always kept my suspension height stock.
    It is the same as a "leveling kit", the cheap way to raise the front end a bit. Make sure to extend your bump stops or you could collapse the bottom part of your shock if you bottom out hard.
    The next step up would be adjustable shocks like the Bilstein 5100's or 6112's.
    Then come adjustable coilover kits, etc. There is a whole suspension section in this forum that could teach you a lot. I would get into it but I don't have the knowledge.
    Law323 and gosolo like this.
  8. Jul 12, 2017 at 5:27 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Hopefully someone with more knowledge can chime in, for the bigger tires you may need wheel spacers or a different offset to prevent rubbing up front.
    Law323 likes this.
  9. Jul 12, 2017 at 9:44 PM
    TundraDan723
    Two more questions:
    How difficult is it to remove the urinal cake that's installed?
    Would it be a dumb idea to run airbags in the rear with totally stock suspension in the front?
    Eclipsed & Floating likes this.
  10. Jul 12, 2017 at 9:47 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    That's my understanding too. But, I'm far from a suspension guru.
    MotoTundra likes this.
  11. Jul 12, 2017 at 9:51 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    The airbags are usually used for towing to help decrease the saggy butt syndrome. There's nothing wrong with running airbags in the rear w/o a urinal cake in the front.
  12. Jul 13, 2017 at 12:36 AM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    with a couple of jack stands - it shouldn't be more than an hour to take them out - will be a lot less after you've done it once. **edit** looks like you'll need a spring compressor too - your local parts store will rent them for free...
    Where are you located?
    Not a dumb idea at all - possibly the opposite... if there's a load on the back, either in the bed or towing, air bags help with that
  13. Jul 13, 2017 at 2:55 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Looks like a top plate spacer in which case he won't need to disassemble the coilovers. Should just be able to lower the shock enough to remove the cake and reinsert the shock
    1UPPER likes this.
  14. Jul 13, 2017 at 3:58 AM
    DVYota
    DVYota Super stock street truck
    2014 Sequoia 2021 Tacoma
    Basically stock
    In before @Sean266 and @Law323 show up and recommend a Toytec Boss kit :popcorn:
  15. Jul 13, 2017 at 5:04 AM
  16. Jul 13, 2017 at 7:12 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    The actual spacer width is not the actual lift height because of the angles involved. I believe its 1/4" spacer height = 1/2" lift height.
    T-Rex266, gosolo and MotoTundra like this.
  17. Jul 13, 2017 at 7:59 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I think that is what i said in post 4 above, but no doubt, the more different ways we say something the more likely that it will be understood!
    DVYota likes this.
  18. Jul 13, 2017 at 8:20 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Just don't call it a strut... That might get you banned lol
    gosolo[QUOTED] and T-Rex266 like this.
  19. Jul 13, 2017 at 8:26 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    it'll take you longer than an hour to get it off. Try 4 hours total and that's lowballing.
    it does decrease functionality but not by much since it's such a small lift. 3" would be a different story. Best thing you can do is go back to stock (remove the urinal cake) or upgrade to bilsteins, toytec (how bou daaa @DVYota ) or any other adjustable coilovers if you really want a lift.
    gosolo likes this.
  20. Jul 13, 2017 at 8:31 AM
    DVYota
    Basically stock
    :thumbsup: just swapping to a new coilover or lift like the boss system would be easier and quicker. Those coils might be worn out because of the spacer. Maybe try and find a newer stock set on Craigslist or here. Lots of guys sell theirs cheap after they get a lift
    Law323[QUOTED] likes this.
  21. Jul 13, 2017 at 8:46 AM
    Primo
    Primo White Tundra
    Primo
    San Antonio, Texas
    2016 SR Double Cab
    Level kit and TRD Pro Grill Installed.
    Just doesn't look right. Bet the ride is bumpy as hell. Not the spacer I would use. The picture above is the right lever to use.
  22. Jul 13, 2017 at 8:49 AM
    DVYota
    Basically stock
    I have the same spacer you posted there with the extra top plates.
  23. Jul 13, 2017 at 9:10 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I had that before my coilovers......hated the ride.
  24. Jul 13, 2017 at 3:40 PM
    TundraDan723
    Located in Beaverton, OR
  25. Jul 13, 2017 at 3:50 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I've had no luck getting banned, despite my best efforts. All I've managed is 2 scoldings, 4 threats, 1 minor ass whooping, and a couple of pages of deleted threads.
  26. Jul 13, 2017 at 4:08 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Maybe you should try making a political thread. That might do the trick. Lol
    T-Rex266 and MotoTundra like this.
