Customizing my tundra.
Discussion in '2.5 Gen Tundras (2014-2021)' started by tiigerclaw03, Sep 1, 2022.
  1. Sep 8, 2022 at 10:58 PM
    #61
    tiigerclaw03
    tiigerclaw03 [OP] New Member
    2019 tundra sr5 4x4 double cab
    None yet but it’s common
    Having the padded door panels with the matching center console is really going to start to bring in the theme I’m going for. To remove the panel I had to drill out plastic welds. Remove one panel screw and the two screws holding in the Handel assembly. Then I peeled the old pleather off and removed the shortest staples I’ve ever seen from the corners. After cutting an exact piece of neoprene out it was time to spray 3m adhesive on the panel as well as the neoprene. After using my hands to mold everything over the proper edges I employed a butter knife to smooth everything out with even strokes to ensure the two pieces got a proper full bond. Finally I used low profile fender screws that are made fir plastic to reattach the panel. It came out pretty good with no flaws. Going to install the panel in the morning and do the other side. I’ll post pics from inside when I’m done.
  2. Sep 8, 2022 at 11:19 PM
    #62
    tiigerclaw03
    Thank you. I’m going to keep at it till I like it.
  3. Sep 8, 2022 at 11:24 PM
    #63
    tiigerclaw03
    I’d like to see what everyone else has done to their trucks.
  4. Sep 9, 2022 at 3:13 AM
    #64
    GeoJoe
    GeoJoe 2018 Tundra SR 4x4 5.7L Looooooooong Bed
    3/1 lift on 20" OZs with KOs, LED fogs, steps and a handle
    That’s literally what this entire forum is here for.
  5. Sep 9, 2022 at 8:02 AM
    #65
    se7en
    se7en New Member
    Not my style but as long as you like it who cares!
  6. Sep 9, 2022 at 8:03 AM
    #66
    Aqualoon
    Aqualoon New Member
    2019 Tacoma Off-Road DCSB Cavalry Blue
    You should check out some build threads. I made an account here specifically to comment on a build thread that I loved.
  7. Sep 9, 2022 at 10:16 AM
    #67
    TaquitoBandito
    Joel (AKA Bif)
    Exactly - there's some pretty next-level mods going on in this forum.
  8. Sep 9, 2022 at 1:51 PM
    #68
    tiigerclaw03
    Got some inside pics after the door panel and console neoprene mod.
  9. Sep 9, 2022 at 11:09 PM
    #69
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    You know what? I'm starting to dig it with the camo man! surprisingly:thumbsup:
    Tripleconpanna likes this.
  10. Sep 10, 2022 at 12:34 AM
    #70
    trevorklat
    trevorklat Don't Mess with Texas!
    The Lone Star State
    2018 Super White Platinum Tundra 4WD CM
    Linex bed liner, Retrax roll-top bedcover, Ranch Hand Summit brush guard, SDHC ABS sensor guards, Interior LEDs, Cargo lamp LEDs, Reverse Light LEDs, Rear TRD sway bar, Valhalla's Shield Cat plates, Husky floormats
    First of all...great attention to detail and you are doing a very professional job of installing that camo.
    I suppose you plan on keeping that truck forever because the resale value certainly took a hit and now appeals to a much smaller group of potential buyers. But, I guess you knew that going into this mod.
  11. Sep 10, 2022 at 12:35 AM
    #71
    Yzed608
    Yzed608 New Member
    Wisconsin
    Do you have any detailed info on the Lux Auto mats, I'm assuming they're waterproof? I really like that idea for protecting so much of the floor area. Here in winter wearing big salty wet boots you're bound to get the carpet wet even with floor mats, I like that you can put the normal mats over it. Took a look at their site and not a huge fan of their car selection stuff, doesn't seem very complete as far as selection front/back etc.
    As far as the colors the blaze orange and camo theme I don't mind being a hunter, but as you've said there is too much orange. What you did with the neoprene looks very well done, but honestly the quality of the orange stick-on accents is no where near that. I'd think you may be better off looking at what pieces you'd like to have the orange, removing them and having them painted versus the overlays.
  12. Sep 10, 2022 at 5:22 AM
    #72
    tiigerclaw03
  13. Sep 10, 2022 at 5:41 AM
    #73
    tiigerclaw03
    The overlays are a little cheesy but it’s not permanent. They’re really high quality though. And add protection. I would like to do it in paint one day down the road. But I’m not 100% digging it yet. The overlays is really a test run. I’m just not ready for that type of commitment yet. Lol
    I really like the floor mats because they are full coverage. They basically cover all exposed carpet in the truck. It’s a lot easier to clean. Wet rag and armor all. And it cuts down on sound a little. My doors and back floors and all the way up the back has been double layered for sound deadening. Really the only road noise I hear comes from behind the dash. I can have my bass hitting pretty loud and you can’t hear it from the outside. And you can’t hear my high’s 15-20’ away. I’m free to fully jam out anywhere at any time. I’d like to sound deaden the firewall and completely cut the road out but that would be an extremely long and frustrating job. I might do it this winter. I’ll try to add a video showing how effective the sound deadening is on the truck.
    https://luxautomat.net/shop/diamond-pattern-luxurious-custom-fitted-mat/beige-leather/
    Yzed608[QUOTED] likes this.
