Octane difference?
Discussion in 'General Tundra Discussion' started by Rjlman, Sep 6, 2022.
  1. Sep 8, 2022 at 10:39 AM
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    Costco gas is Tier 1. I just don't often use it because the lines are too long. :D
    NewImprovedRon and AZBoatHauler like this.
  2. Sep 8, 2022 at 3:05 PM
    CTundraForMe
    CTundraForMe New Member
    There's a wealth of misinformation on the internet as well. How do you know what's true and what isn't?
    Mike59 likes this.
  3. Sep 8, 2022 at 3:09 PM
    CTundraForMe
    Thanks!
    No stations near me. :(
  4. Sep 8, 2022 at 3:15 PM
    timsp8
    NY
    I don’t think that site has been updated in several years.
  5. Sep 8, 2022 at 3:19 PM
    737fixer
    737fixer New Member
    Damn, I wish I could disagree with everything the poster said since every article, scientist, professional, whatever says it can't happen but absolutely I notice slight improvement in performance and definitely a 10-15% increase in MPG.
    AlrightAlrightAlright likes this.
  6. Sep 8, 2022 at 3:21 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    But would a transmission cooler help mileage even more?
    <doing the trans cooler jig>
    pursuit2550 and Mike59 like this.
  7. Sep 8, 2022 at 3:30 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    No but tow hooks would most def
  8. Sep 8, 2022 at 5:00 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    :rofl::rofl::rofl:
  9. Sep 8, 2022 at 6:15 PM
    pursuit2550
    pursuit2550 New Member
    Your right there is a lot information on the internet. But it only takes a little bit of thinking to know that higher octane doesn’t burn hotter. It also doesn’t clean your engine better. How about that it scientifically been proven that all grades of gas have the same BTU. Every source of energy has a BTU rating, propane, diesel, electric, etc. The BTUs in gas don’t magically change because of higher octane. Plenty of creditable sites that know a thing or two about it would be good place to start. Instead of telling random people on the internet that he read from a friends uncles brothers, that his truck does everything he mentioned because they know.
    Mr.bee likes this.
  10. Sep 8, 2022 at 6:18 PM
    pursuit2550
    Only if you used low octane trans fluid. It doesn’t burn as hotter as high octane trans fluid.
  11. Sep 8, 2022 at 6:28 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    it's also hella fresh gas..they have new gas twice a week
  12. Sep 8, 2022 at 7:18 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  13. Sep 8, 2022 at 8:03 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Where did you get 108 octane? Racing fuel is not even 108.
  14. Sep 8, 2022 at 8:17 PM
    AZBoatHauler
    So.Arizona
    Eh - that depends. We run 116 in the drag boat.
    87 in the Tundra.
    GPJoeyD, TRDFerguson, BTBAKER and 2 others like this.
  15. Sep 8, 2022 at 8:45 PM
    AlrightAlrightAlright New Member
    Northwest Arkansas
    2020 SSM DC 4x4 with SR5 Upgrade Package
    RetraxONE MX retractable bed cover TRD Rear sway bar Debadged FabFours Matrix front bumper Smittybilt 9,500# XRC winch Aries 30" light bar (internal bumper mount) Diode Dynamics SS3 3" SAE Fog and Driving lights ConsoleVault RhinoRack crossbars
    This has been similar to my experience with ethanol gas as well going from 87 to 89 octane, which has been consistently $0.20/gal more in Gods country. I saw no difference with 91 octane, so I suspect there are other constituents in the fuel causing the bump. Have not tested ethanol-free. (Side note: I can say I’ve broken the no-ethanol-in-small-engines rule and am now paying the price with fuel system rebuilds on my yard equipment.)
    My conclusion is, I like the bump (closer to 8% in my case) and the additional insurance benefits of added solvents in the fuel.
    I didn’t see this mentioned, but there are a number of factors here, right? Speed, hauling loads, humidity and temperature, road profile, AC on/off, etc. And another interesting question… does the increased mileage hold steady at 65, 70, 75 and 80, or does the increased mileage degrade?
  16. Sep 9, 2022 at 3:30 AM
    pursuit2550
    I have always heard of this no ethanol on lawn equipment or boats, I have owned a few boat and use to hear it all the time on the boat forums. I guess I must have been lucky because I have never had an issue. I have had to do maintenance but never a total engine failure. What do you mean by added solvents in the fuel? All fuels from a certain manuf has the same solvents/additives across all grades. Now if you use E-15 or E-85 then yes, there is more solvents. Alcohol is a solvent. Only way to know about your last question, is a blind test. Give someone a vehicle and tell them to drive it normal. In the past when I have tried higher octane or non-ethanol, you tend to be more cautious to try to achieve better results.
  17. Sep 9, 2022 at 3:58 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I did just that.
    i ran 3 tanks of Costco 87
    and 3 tanks of Costco 93
    I drive like an old robot (albeit with a trans cooler). South Houston - 60mph to work and back - 56 miles round trip.
    it made Zero difference. 17mpg.
    this was before boost. using the tried and true Scanguage 2. that thing was within a tenth of a gallon at fillup.
    now I use 93 octane - because that's what the Dr. ordered.
    so I took it a step further after boost and bumped my octane to ~95 using royal purple octane boost.
    again....no difference.
    I still get 17mpg with the Harrop blower - right up until I press the skinny pedal.
    to address a concern a few comments up....if I was going to tow/haul a load for an extended distance...I would probably bump my octane a couple points - because.
    Mr.bee likes this.
  18. Sep 9, 2022 at 4:55 AM
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    I'm sure the mpg numbers shrink, but I'm also sure the smile on your face increases! :)
    nobodyintexas[QUOTED] likes this.
  19. Sep 9, 2022 at 5:07 AM
    pursuit2550
    It would have worked if you tweaked the timing more. But yeah just adding octane boost does nothing. Funny you mentioned octane boost. This goes to show you how advertising works. Back in my dirt bike days, I was around 10-11, I use to think that octane boost would make my dirt bike run faster. Boy did I waste money on OB. :D:mad:
  20. Sep 9, 2022 at 5:18 AM
    #50
    nobodyintexas
    nobodyintexas What?
    South of Houston
    maybe.
    my tuning map is set up quite nice. (according to the blabbage the tuner was barking at me)
    Octane will only help me under rare circumstances....like pulling a load, under full boost, at slow speed.
    these conditions would produce the effect you are alluding to. Toyota pulls timing when it see big knockers.....wait...when it hears the knock sensors. sorry.
    but my tune is set to accommodate that with timing... up until an ECU threshold. since I don't haul heavy sh1t, I'm all good.
  21. Sep 9, 2022 at 5:25 AM
    #51
    18" TRD Off Road Wheels
    He said he's rebuilding fuel systems. That's a fair bit away from total engine failure. Ethanol is more acidic and harder on seals, and it attracts moisture.
    You'll burn more ethanol to go the same distance compared to gasoline because ethanol has less energy in it. It has nothing to do with a driver being more cautious. It is measurable and documented. Ethanol free will get better MPG than fuel with ethanol, regardless of octane.
    Mike59 likes this.
  22. Sep 9, 2022 at 5:31 AM
    #52
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I'm gonna test ethanol free next week. Buccee's in has 92 octane ethanol free & beaver nuggets*.
    I'll run it and see if I bump higher than my usual 17mpg.
    I'm not sure of the effects that the beaver nuggets will have, but it is worth the effort.
    *for the unwashed...Beaver nuggets are Texas sized super sugar crisps. Remember the honey bear?
    Mike59, Joro43 and GODZILLA[QUOTED] like this.
  23. Sep 9, 2022 at 5:33 AM
    #53
    nobodyintexas
    nobodyintexas What?
    South of Houston
  24. Sep 9, 2022 at 5:34 AM
    #54
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I have a hard time staying on topic.....
    GODZILLA and pursuit2550 like this.
  25. Sep 9, 2022 at 5:34 AM
    #55
    pursuit2550
    I know what he said. Just that in the boat forums they would say don’t use ethanol or your engine will blow.
    I understand that ethanol burns faster. I am just saying that if you do a blind test the results would probably come out different. In my head I would be thinking how much better mpg I could really get, so my driving habits would change. Obviously non-ethanol will get mpg than ethanol but I was saying blind test on ethanol 87 vs 93. I know I worded it weird with non vs ethanol.
    GODZILLA[QUOTED] likes this.
  26. Sep 9, 2022 at 5:36 AM
    #56
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Ethanol pulls water into the fuel tank....bad ju-ju
    boat fuel tanks tend to sit for a long time..
    frichco228 and GODZILLA like this.
  27. Sep 9, 2022 at 5:38 AM
    #57
    pursuit2550
    That is true. But you should see some of the comments that where made over on those forums. It was like the end of the world.
  28. Sep 9, 2022 at 5:39 AM
    #58
    nobodyintexas
    nobodyintexas What?
    South of Houston
    amateurs.
  29. Sep 9, 2022 at 12:13 PM
    #59
    CTundraForMe
    I agree. The only way I could see higher octane making a difference is if it has less ethanol in it?
    That said, my uncle IS a Toyota Master Mechanic and drives his own Tundra and says they run better with mid-grade.
    EDIT: I will ask next time I see him in person to grok why.
  30. Sep 9, 2022 at 12:23 PM
    #60
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Anybody know stickers and premium gas gives you more HP…it’s dyno proven…lol
    pursuit2550 and AZBoatHauler like this.
