General Supercharger Thread
  1. Sep 7, 2022 at 4:45 PM
    #3211
    Saltyhero13
    Saltyhero13 Throbbing Member
    I don't remember what the stock Harrop looked like. Sounds like it would be easier to mount a MAF to the tube. Lots of ways to skin the cat.
    Silver17[QUOTED] likes this.
  2. Sep 7, 2022 at 4:56 PM
    #3212
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Hmm, if my lead on a magnuson one at a better price doesn’t pan out it could be worth a try. It looks like this.
    Saltyhero13[QUOTED] likes this.
  3. Sep 7, 2022 at 5:09 PM
    #3213
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Would also create an insulated barrier
  4. Sep 7, 2022 at 5:10 PM
    #3214
    Saltyhero13
    I don't remember how it all connects, is the MAF on the ribbed tube?
    No sure I understand replacing that ribbed section with a larger dia pipe when you have a restriction before it. I don't think you would get the full benefit but I'm not an airflow guy.
  5. Sep 7, 2022 at 5:36 PM
    #3215
    Silver17
    Eastern PA
    No the MAF mounts on the little stub of plastic tube coming right out of the airbox. It’s less about the tube diameter for flow for me and more about getting the MAF voltage ceiling taken care of. The throttle body necks down to 76mm (2.99”) anyway, so it’s not as if the 3.5” pipe can’t move enough air….it’s just that damn MAF voltage ceiling.
  6. Sep 7, 2022 at 5:56 PM
    #3216
    4firemandan
    4firemandan Superduper Member
    SWFL
    2016 Crewmax 4x4, 5.7
    TRD Supercharger, Ported SC inlet, RCF TB, 4.5” intake, WMI, 2.38 pulley, custom tune, DW660 inj, aeromotive fpr, msd boost-a-pump
    HulkSmurf14[QUOTED] likes this.
  7. Sep 7, 2022 at 6:25 PM
    #3217
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    The aluminum pipe to me has a better bolt up location for the maf. The maf screws into plastic which I’ve seen cause issues of staying. So that alone to me is worthy of switching tubes
    Saltyhero13 and HulkSmurf14 like this.
  8. Sep 7, 2022 at 10:22 PM
    #3218
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    Wonder if this box is the same size as the 07-13 OE Airbox. Does anyone know?
  9. Sep 8, 2022 at 3:04 AM
    #3219
    Silver17
    Eastern PA
    The lower airbox is the same. 07-13 lower airbox is the same lower as the Magnuson lower, but the lid is different and that’s what matters. The lid on the 07-13 still has the smaller 3.5” MAF tube attached. The magnuson lid has the 4” MAF tube attached. Both the magnuson lid and the 07-13 lid do not fit the 14+ lower box.
    mustang67408 likes this.
  10. Sep 8, 2022 at 3:36 AM
    #3220
    Bo-Hunter
    Bo-Hunter I like fast
    Greg
    NOVA
    2009 RW 4x4 Truck
    Long Travel, DC Shortbed
    When I was thinking about doing this I was actually going to cut the existing tube that comes out of the OE airbox lid that has the original MAF sensor mounted on it and leave maybe like a quarter inch or half inch of the tube sticking out and actually try to JB weld the aluminum one in Somehow to the existing airbox lid. I remember the OD of the existing tube especially right where it joined the lid was similar to the ID of the aluminum tube. I also found a plastic one identical to the aluminum one that’s used on the newer LS engines that have the same mounting point for the MAF sensor as the Toyota but it was also back ordered. The interesting part about this particular tube is that the MAF sensor mounting point was raised quite a bit above the body of the tube which made me think of something else The Something else I was thinking about was I used to have an MR2 Syder and one of the popular mods was to get Larger Celica GT injectors but then just use quarter inch spacers to raise the MAF sensor in the existing air intake, just lifting it up out of the tube itself tricks it into thinking it’s in a larger tube and would increase its capabilities. This mod would give that little engine about 25hp. Not sure if it would work on our trucks, but it always fascinating where our minds go and what can be accomplished with a little redneck engineering
  11. Sep 8, 2022 at 6:05 AM
    #3221
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    Sweet!Thanks :) I still have my OEM Airbox. I guess I just need to buy the top and I might just buy the coupler too. I’m assuming it’s the same filter size?
  12. Sep 8, 2022 at 8:08 AM
    #3222
    Silver17
    Eastern PA
    The Magnuson intake and the 07-13 are the same filter size to my knowledge. If you have the rubber boot that came with the Harrop that should stretch over the Maggie lid and work perfect, no need to buy the other one. In fact the other one may not line up with the Angle of the Harrop inlet at all.
    vq35721[QUOTED] likes this.
  13. Sep 8, 2022 at 11:04 AM
    #3223
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    Just got off the phone with SCOL. Ordered the box. They have them in stock so grab them while they still have them lol
    Platinum714, reywcms and HulkSmurf14 like this.
  14. Sep 8, 2022 at 1:24 PM
    #3224
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    So would this AFE ‎31-10146 filter be the one to buy?
    https://www.amazon.com/dp/B001ABOTUA#aw-udpv3-customer-reviews_feature_div
    vq35721 likes this.
  15. Sep 8, 2022 at 1:34 PM
    #3225
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
  16. Sep 8, 2022 at 1:35 PM
    #3226
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    M3Tundra-JK likes this.
  17. Sep 8, 2022 at 1:39 PM
    #3227
    ZPhilip
    Philip
    West Chester, PA
    Roger that. Let us know when you receive it.
  18. Sep 8, 2022 at 1:44 PM
    #3228
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Thats correct for the maggy box from what ive heard
    vq35721 likes this.
  19. Sep 8, 2022 at 1:46 PM
    #3229
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    I can't wait to use the phrase, "You are wrong and I hope you get crabs."
  20. Sep 8, 2022 at 2:24 PM
    #3230
    snivilous
    SW UT
    300k+ Supercharged 2008
  21. Sep 8, 2022 at 2:30 PM
    #3231
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    We are groovy then :)
  22. Sep 8, 2022 at 6:00 PM
    #3232
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Vent cut in the test fender. Just need to mesh and see how it looks. Then I’ll create a template to do it on the glass on the truck.
  23. Sep 9, 2022 at 5:46 AM
    #3233
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    So I’ve been in contact with someone who’s got a supercharged tundra. He just dropped his rig off at AFE where they’re going to R&D creating a new intake setup. So far only details I got are conical filter will be used. He mentioned having issues under boost with filters. So I imagine it’s what was mentioned here with the filter collapsing but waiting to hear back.
    nags, Saltyhero13, omgboost and 4 others like this.
  24. Sep 9, 2022 at 6:11 AM
    #3234
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Now I’m thinking of mount the GoPro in the box and see wtf Is going on in there lol
    Saltyhero13, omgboost and 4firemandan like this.
  25. Sep 9, 2022 at 6:39 AM
    #3235
    M3Tundra-JK
    Scott
    2005 GX470
    DAMN IT! lol. I LOVED my AFE Momemtum GT intake on the supercharged tacoma. It has a larger filter and stage 2 intake than the Stillen. I did an extensive compare between the Volant and AFE over on Tacomaworld. See link below for pictures. I'll gladly rebuy an AFE version for our rig
    https://www.tacomaworld.com/threads...ricks-and-mods.518932/page-1942#post-26263576
    Saltyhero13 and reywcms[QUOTED] like this.
  26. Sep 9, 2022 at 6:44 AM
    #3236
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Yea I’m siked to see what they come up with. Who knows how long it’ll take but I’ll keep everyone posted as I talk to this dude on the Instagram.
    Saltyhero13 likes this.
  27. Sep 9, 2022 at 6:46 AM
    #3237
    M3Tundra-JK
    Scott
    2005 GX470
    They already make boxes for our truck, even with the stage 2 port, they just don't have the larger intake tube or adapter tube for the stage 2 port
  28. Sep 9, 2022 at 6:56 AM
    #3238
    M3Tundra-JK
    Scott
    2005 GX470
    I'll go ahead and throw the AFE conical filter pic over here. It's HUGE for the Tacoma, larger than the Stillen filter for the Tundra....
  29. Sep 9, 2022 at 6:57 AM
    #3239
    M3Tundra-JK
    Scott
    2005 GX470
    Also, they seal up the gap on the fender inlet port really well! No hot air entering this box. I'm totally excited to see it and will buy it as soon as it's available!
    Saltyhero13 and reywcms like this.
  30. Sep 9, 2022 at 8:11 AM
    #3240
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Guess I'll need to stock up on more gold wrap for the new box lol
