  1. Sep 7, 2022 at 9:41 PM
    Yeah, I never got pins with pads before.
  2. Sep 7, 2022 at 9:48 PM
    wandering_boy
    wandering_boy Junior Tech Wizard
    California
    2005 AC SR5 TRD
    Don't let a kid out smart you.
    Soooo. I got a little carried away on Crutchfield the other day. I started by looking for rear speakers and ended up buying a new Double din radio. With apple car play. And then I got even more carried away and did it after work and ended up working until about 11:30. hehehe... I ripped out all the carpet in the back and passenger side to do the amp bypass. Got it looking all factory up in there =) Not my best heat shrink work. Nothing a touch of E-tape can't fix. Gotta pull it back out and put the center console back in. Pas. seat has 2 bolts keeping it in for now. Gives me a great chance to do a deep clean =)=)=)
  3. Sep 8, 2022 at 3:36 AM
    Yes. There are only a few companies that make sliders for our trucks and they either bolt on or weld on. White Knuckle bolt on and require drilling a few holes on each side.
    oscardog86 likes this.
  4. Sep 8, 2022 at 4:02 PM
    New sneakers for the fronts that were worn down to the belts after 2 years and lack of inability to get alignment in spec. Setback $386+.
    Now onto the LCAs tomorrow. Hoping that will give me the camber I need or I’m going to get soaked on replacement springs.
    Hooptytrix, bmf4069 and shifty` like this.
  5. Sep 8, 2022 at 6:45 PM
    Found out today my 20+ old spare tire finally died (won’t hold air). Also, the steel rim is so rusty crusty it won’t easily seat the lug nuts over the threads (can only screw it down 1/2 way).
    Now looking for a used tire/rim locally as a spare. Anyone have any idea what years Tundra/Tacoma fit the hub of an 02 Tundra?
    w666, NUDRAT and oscardog86 like this.
  6. Sep 8, 2022 at 7:05 PM
    I think most of the 6 lug wheels work fine. I got one from a junkyard when I moved up to 17" wheels. I see an entire set of the starfish wheels for $65 on Marketplace. I bet you can find one near you.
  7. Sep 9, 2022 at 6:20 AM
    oscardog86
    oscardog86 New Member
    Southern California
    Well atleast you still have the ability to use the truck as a truck, haha. Im pretty commited to this being an RV at this point!
    5N0W808 and Kimosabe like this.
  8. Sep 9, 2022 at 6:55 AM
    snoope
    snoope The Old Man
    I looked over at TW in New England section BUT nothing.... used to be everyone had a few "kicking about"... Times have changed :notsure::notsure:
  9. Sep 9, 2022 at 11:40 AM
    Passenger side LCA is loosey goosey. Torn bushing flexes an inch. Will post video tomorrow. Drivers side is loose as well but not as bad.
    Tundra2 likes this.
  10. Sep 9, 2022 at 11:47 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    5N0W808, bmf4069, w666 and 6 others like this.
  11. Sep 9, 2022 at 12:35 PM
    snoope
    snoope The Old Man
    IMG_4431 (1) mason sand .HEIC.jpg I actually got to drive it :burnrubber: A few business errands and picked up some mason sand :curls:
    Not sure if the Tundra can handle 50 lbs. of sand :D:p
    More "honey-doo's" this weekend :rolleyes:o_O
    Easier to "Prep" for upcoming Events before "Sno-birds" arrive :cool::cool: and I need to "Kick -Start" Momma to start her 2nd edition book :spending: All about the $$$$$$
    I am enjoying Semi-retirement and need her business to "Pick up a notch or 2" :monocle:
    NUDRAT and Jack McCarthy like this.
  12. Sep 9, 2022 at 12:55 PM
    Acutally not that bad so far.
    Both stabilizers links came out without cutting. @Festerw
    Front LCA bolts came out and front adjusters could be turned easily. Hoping rear of arm adjusters are just as easy. Most likely it’s from the greasing I did first time. :)
    @Kimosabe The bolts on my arms hang out past the CAM adjuster nut by 1/2”.
    bmf4069, Kimosabe and snoope like this.
  13. Sep 9, 2022 at 2:45 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    @Jack McCarthy I got my bolts in yesterday from the dealer. Front cam bolts are longer, along with the cam sleeves.
    Got the front end buttoned up yesterday and did an iffy alignment myself. Earliest I can get in for an alignment is next Thursday. So luckily I don't have to drive much before then and can ride my bike since weather finally cooled down.
    Good job on the greasing. I probably should have, but just sprayed down with fluid film.
  14. Sep 9, 2022 at 2:52 PM
    Well if the longer bolts work, that’s great. Not sure why they’re making them longer. When I bought all new hardware 10 years back when I did it the first time, they were the right length.
    I bought a tube of pure nickel anti-seize grease for $20 from Grainger and that’s held up well. Still have more to use with the reuse of the old CAM hardware. Dealer told me I can return the unused sleeves I bought just in case.
  15. Sep 9, 2022 at 5:13 PM
    bmf4069 and oscardog86 like this.
  16. Sep 9, 2022 at 5:14 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    My Tacoma spare is like that - well, was. I found someone giving away his spare when he upgraded to larger size. Think I found it in the Tacoma World classifieds.
    I've bounced most all my 6 lug rims onto & off both the '02 Taco & '03 Tundra. Right now the Taco is wearing a set of '16 Taco takeoff's. ...and the spare lives in the bed.
  17. Sep 10, 2022 at 3:06 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    With everything that rusty you're lucky you got it down at all. I had to use bolt cutters on the cable, then replace the rusted solid winch. I found a matching starfish wheel on eBay for $50. I have 3 Toyotas with this type of spare mounting, so now I drop the spare at least once each year, check the pressure, and lubricate the cable.
  18. Sep 10, 2022 at 3:58 PM
    Finally got the LCAs in today but not without a thorough mangling of both the passenger side shock and it’s bolt. Always seem to have difficulty lining it up even without the LBJ attached. Also redid the anti-seize grease. Decided to use the new CAM sleeves for the rear of the LCA since those seem to rust out quicker. Had to basically pull the steering rack bolts out and move it back 6 inches to get everything out. Now time for a beer and tomorrow I’ll get it all torqued up to spec. and put in the stabilizer links.
    The bolts going back on after clean up and before lube.
    The good install…
    the mangling…
    Kimosabe, oscardog86, bmf4069 and 8 others like this.
  19. Sep 10, 2022 at 4:50 PM
    Oh, I’ve gotten regular use of that spare over the last 8 years with my ex-neighbor who used to put screws in my tires. Always a nice thing to wake up to in the morning.
    w666[QUOTED] likes this.
  20. Sep 10, 2022 at 4:51 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    I can't wait to not be from the rust-belt so I can buy nice vehicles.
  21. Sep 10, 2022 at 4:52 PM
    What state are you moving to next?
  22. Sep 10, 2022 at 4:55 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    next is right, there's been a few.
    @Hooptytrix will probably have one of those in the water rentals ready by the time I'm ready to go. :)
    so ready for:
    OH - what have you done thread. So didn't drive the truck today, it's grounded until Tuesday.
    Was driving & got this front end vibration about 55mph. Mind immediately went to ball joints. Pulled into the tire place, he lifted it up & decided bushings on the steering rack were very tired & one was past done. Phew!
  23. Sep 10, 2022 at 5:12 PM
    @NUDRAT Ah, so ready to retire like myself. Good for you! Only one year for me before I can escape the bonds of my employer and retire early at 60. Not sure what I’ll do for the next 5 years, but with my luck nobody will be hiring since we seem to be heading for a recession.
    oscardog86, bmf4069, shifty` and 2 others like this.
  24. Sep 10, 2022 at 5:16 PM
    snoope
    snoope The Old Man
    I'll LIKE for that pic :cool: but not for the front end "Gotcha's" :ballchain:
    And be careful "buying a southern" Yota.... some of them have had white slime dirt in places and Swamp water to drink :boink::eek: :thumbsup:
    New England rust actually makes noises before dumping your a$$ on the side of the road o_O
    NUDRAT[QUOTED] and Jack McCarthy like this.
  25. Sep 10, 2022 at 5:18 PM
    snoope
    snoope The Old Man
    Anyone that KNOWS HOW TOO , will :thumbsup:
    Unless everybody drinks the 2020 Kool-Aide :hattip:
    Didn't have too DRIVE the Tundra :( this afternoon, both of the old AC's fit in the RX... Kids are happy :D and Dad didn't have to round trip 2-1/2 hours through the heartland...:thumbsup:
    NUDRAT and Jack McCarthy[QUOTED] like this.
  26. Sep 11, 2022 at 1:01 PM
    Finally complete with the LCAs. Truck sits up higher now. Wonder if that’s because I tightened the CAM bolts to 90 ft-lbs with the rotors hanging in the air?
    5N0W808, bmf4069, txagg and 3 others like this.
  27. Sep 11, 2022 at 1:34 PM
    Probably wanna do those on the ground with weight on them. It also may settle a little.
  28. Sep 11, 2022 at 1:37 PM
    Used my on board air to pressure test a gas line at the kids school. So convenient! 7180149F-37C5-4D4E-A901-83CBF268EE1B.jpg
    805Tundra, bmf4069, alb1k and 2 others like this.
  29. Sep 11, 2022 at 3:23 PM
    Wish I could. I should’ve used the jack to push up the arm like it was on the ground before tightening. I’ll let the alignment guys handle that tomorrow.
    KNABORES[QUOTED] likes this.
  30. Sep 11, 2022 at 4:32 PM
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    Shitttttt I'm ready for the house on the water too
    Wifey don't look like that anymore but MLK said I Have A Dream
    Jack McCarthy and NUDRAT[QUOTED] like this.
