FlexFuel E85, and what does it mean for me?
Discussion in '2.5 Gen Tundras (2014-2021)' started by TexMedic, Sep 7, 2022.
  1. Sep 7, 2022 at 7:27 PM
    TexMedic
    TexMedic [OP] I ask a lot of questions…
    2017 Dark Gray DC Tundra 4x4
    Alright guys, just got this Tundra so be easy on me… My last Tundra was just a 5.7, and my current one says E85 FlexFuel 5.7. What does that mean for me? Do I HAVE to use a specific type of fuel? What would happen if I didn’t? I feel like I’m probably overthinking it, but just wanna check. Explain it like you’re talking to a kindergartener, cause you basically are… Not sure if it matters, but it’s a 2017.
    soholingo likes this.
  2. Sep 7, 2022 at 7:37 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    It means you can use E85 if you want because the fuel system was designed for the increased ethanol percentage. Regular E0 and E10 pump gas is also just fine, and preferable.
    If you happen to use E85, your fuel mileage will be worse, and Toyota requires more frequent oil changes. See owners manual. Or better yet, just avoid using E85.
  3. Sep 7, 2022 at 7:41 PM
    RobertD
    Robert
    DFW, Texas
    What he said.
    I have the same engine as you but I've never run E85. Just pretend you still have your last engine and you'll be fine
    TexMedic[OP] likes this.
  4. Sep 7, 2022 at 8:12 PM
    16CMTXED
    16CMTXED New Member
    Gary
    Central Texas
    2016 Tundra CM
    Eibach Pro Sport Shocks (1.25in), RAS HD, Sumo Springs, HAWK Talon Rotors, OEM Tow Mirrows, Lund Hard Fold Tonneau, ESP Storage, Stampede Flares, Husky xAct Fit liners, General Grabber ATX 275/60R20
    It means that when your truck start cranking and not starting, you'll need a new fuel pump. This happened to mine at 75k miles and I never use E85 fuel. Luckily this TSB might apply for you as it did for me. Besides that, enjoy your new truck!
  5. Sep 8, 2022 at 9:38 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Did this happen slowly over a few weeks, or just all at once one morning?
  6. Sep 8, 2022 at 10:05 AM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    It's just a 2 speed fuel pump, oversize injectors, corrosion-resistant lines, etc
    Mine has never given me trouble (yet) and I run e85 a lot through the summer. It has more pep and cleans out enough carbon to cure pinging for a while. The extra oil changes are a nuisance sometimes. Less mpg but similar cost per mile. The dash says 10.6 mpg today for example but the fuel is 2.70/gal, about 25.5c per mile. Regular fuel is 3.70/gal so if I were burning that at 14.5 mpg the cost would be the same sans the extra oil change.
    Just pay attention to the alcohol learn procedure in the manual if you do switch fuels. There's no sensor and it has to calculate it so no joyriding the first 5-7 miles after a fillup. If you always burn gas, nothing to worry about
  7. Sep 8, 2022 at 10:19 AM
    16CMTXED
    16CMTXED New Member
    Gary
    Central Texas
    2016 Tundra CM
    Happened slowly for me, probably 1 month before I had it completely resolved. At first, I thought it was a battery issue. New battery didn't resolve. Took to mechanic and he couldn't replicate, but was able to pull codes related to fuel pump. I can't remember which thread it was, but somewhere on this forum, I found info about TSB. I had to prove to Toyota service department that my VIN matched the TSB and that the P codes matched as well. Afterwards they put me in a loaner Taco and replaced the FP at no cost to me.
