Better Towing Rotors/Pads
Discussion in '2.5 Gen Tundras (2014-2021)' started by csevel, Sep 7, 2022.
  1. Sep 7, 2022 at 9:09 AM
    csevel
    csevel [OP] New Member
    2020 SR5 Double Cab
    Before anyone crucifies me.. I don't post here often and have limited experience mechanically. My son will help me with the install. I have tried doing a search and have found a few threads about brakes but need some opinions. I have '20 TRD Sport DC with new Michelin Defender LTX 275/60/20 tires. (the OEM tires only lasted 25K miles) Half of my 30K miles are towing a 6000# travel trailer. I have noticed some pulsing from the front brakes and want to replace rotors/pads fairly soon. My trailer has two 3500# axles and electric brakes. What are some options for my truck since it basically is used for my trailer. I don't do any mountain driving as I'm in the NE but have had to lock 'em up a few times due to asshat drivers. Brake controller set to 7. We do have salted roads(ugh) and I want to avoid as much brake dust as possible. Any help appreciated![​IMG]
    ATHiker, ColoradoTJ, WILLINH and 2 others like this.
  2. Sep 7, 2022 at 9:45 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    You will get lots of suggestions. There are many great pads, but considering you want low dust and good performance I would suggest akebono performance pads.
    For rotors, Cryo treated if possible, but they generally cost about 2x as non Cryo treated. Centric and Stoptech have some as well as @dirtydeeds. The cryo rotors seem to be on backorder everywhere but Dirtydeeds did have some last I checked.
    If you cant find cryo treated rotors (may be a 2+ month wait) then the non cryo rotors from Centric, Stoptech, Bremo, EBC are good quality or just get some new stock rotors.
  3. Sep 7, 2022 at 9:47 AM
    frichco228
    Frank
    Virginia
    Lastly, there are MANY threads about brakes and rotors and improving from stock braking. Search in upper right "brake rotor" and you will get pages of threads with a lot of good information.
    csevel[OP] likes this.
  4. Sep 7, 2022 at 9:56 AM
    Ericbike6
    Ericbike6 So we're doing this shit today?
    Eric
    Austin, TX
    2019 Tundra TRD 4X4 sport
    Air bags, ARK liners, misc bullshit added also
    Good looking set up!!
  5. Sep 7, 2022 at 10:03 AM
    EatSleepTacos
    EatSleepTacos New Member
    Randy
    West Valley, AZ
    2020 Crewmax SR5 TRD Sport
    Have you had your trailer brakes serviced recently at all? Are you engaging the trailer brakes manually from the trailer controller to make sure your gain is set correctly? In the truck settings, there are multiple trailer brake settings, one for electric brakes from 0-4,999 lbs and another for 5,000+. Is the right one selected?
    The reason I ask is if everything is setup correctly, your trailer should be stopping itself and the truck won't be seeing much extra braking force. I tow 8k lbs regularly and between trailer brakes and engine braking, I've never felt that the oem brakes are inadequate.
    ColoradoTJ likes this.
  6. Sep 7, 2022 at 10:06 AM
    Dogsled
    Dogsled New Member
    White 2020 1794 4x4
    Currency converter= Earned to wasted dollars
    Nice trailer…:spending:..haha….cha-Ching
    I changed my out to a big brake package.. -PowerBrake- but, I won’t recommend it because The limited supply of pads and cost…
    Others on here will have better recommendations… Try a Brake/Rotors search… I highly recommend changing them out though.. makes a big difference…
    Good luck and safe travels
    ATHiker and csevel[OP] like this.
  7. Sep 7, 2022 at 10:09 AM
    csevel
    2020 SR5 Double Cab
    Everything is set up correctly for the weight of the trailer. I just recently changed out the bearings/races on the trailer (myself) with Timken USA made parts. While apart, the brakes were adjusted and are working as they should.
  8. Sep 7, 2022 at 10:24 AM
    csevel
    2020 SR5 Double Cab
    I am a Fiberglass nerd.. went from having a Casita for ten years.. Love your Ollie!
  9. Sep 7, 2022 at 10:28 AM
    timsp8
    NY
    I switched to stoptech cryo slotted rotors and ebc yellow pads and they have been the best brakes I’ve had. They just started squealing after a year and over 10k miles though. I haven’t had time to fix it yet and I’ve heard of ebc squealing from other posts.
  10. Sep 7, 2022 at 10:31 AM
    Bammer
    Monroe, CT
    Limited mechanical experience, but you did bearings and races and adjusted the trailer brakes? You have more knowledge than you think . BRAVO
    csevel[QUOTED][OP] and GODZILLA like this.
  11. Sep 7, 2022 at 12:53 PM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    the stock Toyota brake controller isn't the best. I tow a 6Klb boat and I stop better pulling the boat since the trailer brakes are so efficient.
  12. Sep 7, 2022 at 2:28 PM
    csevel
    2020 SR5 Double Cab
    I watched a lot of youtube videos :) and tend to know more about trailers than engines...
  13. Sep 8, 2022 at 3:37 AM
    Bammer
    Monroe, CT
    I'm sure you could do the truck's brakes without trouble. Let us know how it works out.
  14. Sep 8, 2022 at 3:56 AM
    Malinois38
    Malinois38 New Member
    Pa.
    2022 Platinum Hybrid WCP
    I done well with factory Toyota rotors & I tow a 7k camper about 5k every summer. So, yes brakes are important to me & my family. Whatever rotors you buy, just make sure they are not made in China.
    Love the Oliver!
    csevel[OP] and Tripleconpanna like this.
  15. Sep 8, 2022 at 6:04 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I was in the exact same situation as you. OEM rotors were badly warped/uneven at 27k miles. So bad that when we would be towing our 6k lb trailer it make the loose change in the truck rattle. Not a good towing experience.
    I did a bunch of research and was reading about Cryo Treateted rotors and sounds like they really hold up well. I opted to go with Frozen Rotors slotted based on what dirtydeeds was saying (there's a good thread over on another tundra forum about them).
    I was originally going to go with ebc yellow, again based on dirtydeeds recomendation, but when i was talking with Frozen Rotors on the phone they recomended Hawk Green Pads. I ended up going with their recomendation.
    We towed our trailer a few hundred miles and very happy with the upgrade. Butter smooth braking and a noticable improvment in stopping power.
    Here's a little more info
    https://www.tundras.com/search/5296554/
    csevel[QUOTED][OP] likes this.
  16. Sep 9, 2022 at 9:38 AM
    csevel
    2020 SR5 Double Cab
    Thank you for your input..I will feel better about towing my Ollie once I upgrade!
  17. Sep 9, 2022 at 9:45 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Alcon bbk setup hands down.
  18. Sep 9, 2022 at 12:32 PM
    Danimal86
    Daniel
    Sacramento, CA
    If you go the Frozen Rotor route, give them a call and ask them if they have the rotors in stock and ask for a promo code. When i did he gave me one that was enough to cover shipping.
  19. Sep 9, 2022 at 1:57 PM
    greg8765
    greg8765 New Member
    Grant
    Utah
    2021 Cement Tundra
    cryo treated +1
