How do you calibrate speedometer after bigger tire size?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Nativeimages, Apr 17, 2021.
  1. Sep 5, 2022 at 5:01 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Except it’s not always the same 5 mph difference. And your odometer will be off, along with mpg and other calculations. Installing a speedometer calibrator isn’t difficult, either, so that should just be budgeted into your tire purchase.
  2. Sep 5, 2022 at 5:25 PM
    If you buy cheap tires, you should have plenty left for recalibration.
  3. Sep 5, 2022 at 6:06 PM
    Kur
    Kur New Member
    Mesa, AZ
    08, 5.7, Double Cab Tundra, White
    I know it's not always the same 5mph. But it is always the same percentage.
    When i went from stock to 33s on my jeep, that made an 11% difference.
    So i know when the speedo says 40, I'm doing 44.4. When it says 65, I'm actually doing 71.
    And when it comes time to calculate fuel economy, i just add 11% to the odometer reading. 300 miles is 333 miles.
    This isn't rocket science.
  4. Sep 5, 2022 at 6:59 PM
    RNDABOUT
    RNDABOUT New Member
    17 Quicksand TRD Off-road
    Over all distance Mileage decreases value and nominal maintenance rate...
  5. Sep 5, 2022 at 7:31 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Just add 11%! It’s so simple.
    Or spend $200 and 15 minutes on a calibrator… a drop in the bucket on a set of new tires…
    RainMan_PNW and Hightide like this.
  6. Sep 5, 2022 at 7:43 PM
  7. Sep 5, 2022 at 7:45 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  8. Sep 5, 2022 at 8:32 PM
    Joro43
    Joro43 New Member
    2018 TRD Sport 4x4 quicksand crewmax
    1st tundra nautical blue 4x4 5.7l DC TRD had oracle custom color shift halo projector headlights, Fab4 bumper with 12k winch. RBP RX3 Grill Pro Comp stage 1 with bilstein 6112 coil overs SPC UCAs BFG KM3 35x12.5x20 with Moto metal 959s NFab running boards TRD LED DRL pioneer avh 4200nex with Polk speakers and JL 600w amp with JL audio stealth box 196k miles and running strong ready for another 200k until I wrecked it on 2/26/21 Just bought 2018 CM 4x4 5.7l quicksand TRD package upgraded headlights and adaptive CC Trifold bed cover, blacked out badges, KMC wheels BFG KO2 tires, 3/1 pro Comp lift FAB4 front bumper with rigid lights and fab4rear bumper.
    Did it to my 08 with hyper tech and can verify it changes the shift points for the better. Dash install easy 30 min. I didn’t have the pedal commander on that one. Pedal commander adjusts shift points as well. Since that was my only worry I’ll stick with adding speed up in my head
  9. Sep 6, 2022 at 6:10 AM
    RNDABOUT
    RNDABOUT New Member
    Whoa whoa wait.... Wtf is a pedal commander? Why are tune ups soo hard!
  10. Sep 6, 2022 at 7:47 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Pedal commander does not adjust shift points. It only affects throttle response.
  11. Sep 6, 2022 at 7:56 PM
    Joro43
    Joro43 New Member
    Pedal commander re maps the throttle response in the pedal which in turn adjusts the shift points and holds gears longer
  12. Sep 6, 2022 at 9:32 PM
    Saltyhero13
    No it does not. TOW/HAUL does what you say. PC only mutes or amplifies the throttle response it does nothing with shift points. You need another method to modify those.
    mZiggy and TRDFerguson like this.
  13. Sep 7, 2022 at 7:18 AM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    I’m pretty sure you’ve never actually done “rocket science”.
  14. Sep 7, 2022 at 7:33 AM
    Hightide
    Abalama
    Magic School Bus
    I can’t remember if you have remote start, but have you heard of this product affecting remote start?
  15. Sep 7, 2022 at 8:04 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I have a Hypertech calibrator and remote start - no issues from them interfering. What are you seeing happen?
    Hightide[QUOTED] likes this.
  16. Sep 7, 2022 at 8:29 AM
    Hightide
    Abalama
    Magic School Bus
    Nothing personally.
    I was using the google machine to get some reviews.
    That issue popped up a few times.
    Thinking about getting one.
    I have the Car Link remote start.
    Going to 37’s has me doing 80 @ a 71 mph reading.
    I don’t feel like doing math on the fly because I have to access my phone calculator, then that messes up my texting, posting on tundras, shuffling music and following google maps.
  17. Sep 7, 2022 at 8:32 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    We really need to go back to simpler times, where people just read the newspaper or magazines while driving.
    I have a Fortin with the CL6 cellular module. Works great. I can’t really see where the Hypertech would interfere, since that is plugged inline with the gauge cluster and the remote start doesn’t touch that.
    RainMan_PNW and Hightide[QUOTED] like this.
  18. Sep 7, 2022 at 8:52 AM
    Hightide
    Abalama
    Magic School Bus
    yes!
    And drank coffee out of actual coffee cups with no lid.
    That was my thinking as well.
    Wouldn’t seem like it would interfere.
  19. Sep 7, 2022 at 8:59 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I still do this sometimes... unfortunately I only have 1 or 2 mugs that fit the Tundra cup holder well. It's a fun game, trying to wedge the cup in a way that it stays put while driving and is still removable when I want another sip.
  20. Sep 7, 2022 at 9:00 AM
    #50
    TundraTRD08
    TundraTRD08 Somehow I fit 37s on a level
    Wesley
    08 Super White TRD Off-Road on 37s
    3.5' RC lifted struts with RC UCA Alcan rear leaf spring upgrade with 300lbs added weight+1" lift built in. Adjustable Alcan Shackles set to add an extra inch which equals to a 2" lift in the rear. 37” Maxxis RAZR M/Ts with 1.5” spacers 8” BAMuffler Tuned by Bully Dog Tuner
    So after my 33's wear out, I'm going to run 35X12.50R18 or get some rock warrior wheels and do the same, but obviously, it would be a 17" wheel. But anyway, I have 275X70R18 ridge grapplers right now, so if I were to get a ridge grappler or maybe a BFG KM3 in this bigger size (I guess it really doesn't matter which tire it is) my speedo would say I'm going 60, but I'm really going 66? that seems like a pretty big jump to me. Plus my tundra gets to drive like a racecar and sometimes goes to 70 on mountain roads, so I would be going 77? Might have to get that rough country recal after all.
    RainMan_PNW likes this.
  21. Sep 7, 2022 at 6:50 PM
    #51
    Kur
    Kur New Member
    Mesa, AZ
    If you are worried about resale value, then don't do any modifications. Modifications only decrease value.
    And again, just adjust your maintenance intervals by the percentage difference between your stock and new tires. Or don't. It's not that big of a deal.
  22. Sep 7, 2022 at 6:52 PM
    #52
    Kur
    Kur New Member
    Mesa, AZ
    Or save $200 and do simple math.
  23. Sep 7, 2022 at 7:47 PM
    #53
    Hightide
    Abalama
    Magic School Bus
    @TurdFerguson I think he’s volunteering to pay your speeding ticket that one day you forget to math.
  24. Sep 7, 2022 at 7:58 PM
    #54
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Oh… only if I forget though?
  25. Sep 7, 2022 at 8:16 PM
    #55
    Ain’t no body got time for that
  26. Sep 7, 2022 at 8:41 PM
    #56
    Hightide
    Abalama
    Magic School Bus
    FIFY
  27. Sep 7, 2022 at 9:10 PM
    #57
    Can not compute, time limit reached.
  28. Sep 7, 2022 at 9:13 PM
    #58
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    The 21 Pro has Toyota factory start. I’ve not had any issues, and no idea why it would cause problems
  29. Sep 7, 2022 at 9:15 PM
    #59
    RainMan_PNW
    Casey
    Clark County, WA
    My commute is too windy and bumpy for the first 7 miles out of the hills. I have to have my coffee covered or it’ll spill all over and get cold
  30. Sep 7, 2022 at 9:20 PM
    #60
    We’ve got two travel mugs with lids…… one hold the heat well, the other not so well; I do prep them with hot water while the French press is doing it’s thing, but I usually give my mom the lesser heat retention cup…….. I’m terrible! But she sips for hours, so I’m doing her a favor if anything.
