First Oil Change?
Discussion in '3rd Gen Tundras (2022+)' started by scruff1221, Aug 29, 2022.
  1. Aug 29, 2022 at 11:52 AM
    scruff1221
    scruff1221 [OP] New Member
    2022 Tundra Trd Off-road
    Curious to see what thoughts were on this
    I have 5k but all highway miles
    Suggest first oil change now and then 7K afterwards or 5k always?
  2. Aug 29, 2022 at 12:21 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Toyota says 10k miles, Ive always done 5k intervals.
    There are entire threads discussing this timeline, personal preference. Synthetic oil is good for 10k miles....a paper filter however- depends on who you ask.
    I just replace every 5k because it is inexpensive to do so and offers peace of mind.
    TK1979 likes this.
  3. Aug 29, 2022 at 12:29 PM
    TheLordwoulddriveaTundra
    TheLordwoulddriveaTundra New Member
    2022 Tundra Platinum Crewmax 4WD, Mag Grey
    Talons Cat Plate Tuff Skinz Inserts RetraxOne XR Bed Cover Premium Shield PPF Revivify Coating OEM Console Safe WeatherTech Mats
    I just stick with what the manual says I should do. The millions and billions Toyota has put into figuring this shit out carries more weight to me than what anyone who disagrees on forums and articles says.
  4. Aug 29, 2022 at 12:44 PM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads
    The 10k is what they can get away with to make it through warrantee numbers. I wouldn’t run AMS oil for 10k. If you trade vehicles in frequently then go for it if that’s your cup of tea.
  5. Aug 29, 2022 at 12:45 PM
    Zolander
    Zolander New Member
    Zorro
    OffRoad
    I say between 5-10k is good but no more than 10k
  6. Aug 29, 2022 at 1:25 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    I do 10,000 miles per the manual for my 2017 5.7L normal driving conditions. I'm at 84,000 miles and new oil is still amber/honey color on the dipstick at 6,000 miles. I'm running 5W30 Mobil 1 and will be switching to Costco Kirkland brand at 90k. Mama Toyota filters.
    Fumoto valve.
    Jowett Performance filter cap with Fumoto valve.
  7. Aug 29, 2022 at 4:38 PM
    ArmygreenTRD
    ArmygreenTRD New Member
    2022 Army Green TRD, SR5 DC
    OK, I’ll bite. For those that are comparing the 5.7 to the “new” 3.5L TT V6, I would suggest the TT is “harder” on the oil than a NA V8. Not apples to apples. Only you can determine if halving the OCI is worth twice the cost.
    raylo, Hadelson and TK1979 like this.
  8. Aug 29, 2022 at 7:04 PM
    walleyes
    walleyes ‘23 Tundra
    I would recommend changing your oil at 5k miles, oil and filter. It’s cheap insurance, especially if you do it yourself. I perform my first oil change on new vehicles at approximately 1k miles, then at 5k miles and every 5k thereafter.
    The Car Care Nut explains why he too recommends the same, no more than 5k miles for oil changes in his recent video:
    https://youtu.be/TJhFAwFv-O0
    wing-2, WILLINH, NMTRUCKER and 2 others like this.
  9. Aug 30, 2022 at 3:25 PM
    4genRunner
    4genRunner New Member
    Southwestern MO
    2022 SR5 CrewMax TRD OR 4x4 CSM
    RB20's, Extang Xceed Cover, Tint.
    Couldn't agree more. I do the same. First change around 1k miles, then 5k (or 6 month) intervals thereafter. For me it usually turns out to be every 6 months as I work from home and do not put a lot of miles on my truck.
    walleyes[QUOTED] likes this.
  10. Aug 30, 2022 at 3:49 PM
    CTundraForMe
    CTundraForMe New Member
    My manual says 5k, unless you burn corn in your Tundra:
    (FFV engines should 5k I guess?)
  11. Aug 30, 2022 at 4:13 PM
    NMTRUCKER
    NMTRUCKER 1794 Army Green (4x4), ORP, deposit 30 May 2022
    Cloudcroft, NM
    He says 5k or 6 months whatever comes first. He is a certified master mechanic who deals exclusively with the Toyota brand. I would listen to his advice IMO.
    wing-2, WILLINH and walleyes[QUOTED] like this.
  12. Aug 30, 2022 at 4:25 PM
    mverkaik
    mverkaik New Member
    Hamilton, MI
    2021 TRD PRO CrewMax
    WeatherTech Floorliners Toyota Running Boards Reflex Liner Truxedo X15 Pro cover.
    My Land Cruiser had 292,000 mile on it when I purchased it with a blown head gasket. I figured that at nearly 300k I should throw a set of bearings, rings, timing change etc. at it so I pulled the engine.
    I had all of the original owner's maintenance records. 6,000 to 10,000 OCI from what ever quick-stop place was convenient. All Dino-juice. No synthetic.
    That engine was clean. The bore, bearings, pistons, rings, timing chain, guides etc. were in excellent condition. I decked the head and the block The only parts I replaced was the head gasket and seals.
    Regular OCIs are key. At one point I would have argued that it was all about regular OCIs with a good oil. My LC had regular changes with who knows what kind of oil. It faired very well.
    IMO, 7,000 should be just fine. It is well below the Toyota recommendations.... that is unless you qualify as "severe service". I do :) Probably most of us do.... So, Toyota does not wholeheartedly promote 10,000 mile OCIs. They say that it can be done under ideal conditions. I would agree with that.....
    ArmygreenTRD likes this.
  13. Aug 30, 2022 at 9:25 PM
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    I had my Tundra in for service last week with about 6500 miles on it and asked for an oil change since it was there already. The service advisor said, "sure, we can do it, but you are throwing your money away. I would definitely not recommend it." I've never kept a vehicle past 60,000 miles so I took his word for it; I'll do it at 10,000.
  14. Sep 6, 2022 at 8:00 PM
    Carolina Peej
    Carolina Peej Hey can you hold the light for me real quick?
    North and South Carolina
    2022 Midnight Black Metallic 4x4 Tundra Platinum 5.5 w/ load leveling + AVS, HUD, and Power Running Boards
    So y'all started getting me spooked on the oil change... I got 7,000 miles on Tanya and I was ready to take her to the dealer tomorrow for a change. Ohhh the Blackstone! Ohhh the metal pieces.... OMG, what have I done, I've ruined my engine...
    So then I pulled the dipstick for a quick inspection of my 7,000 mile oil. What do y'all think? Looks pretty good to me...
    https://youtube.com/shorts/bbnzAp7Wxus?feature=share
  15. Sep 6, 2022 at 8:06 PM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    My dealer is about 100 miles away but I plan on doing my first @ 3k miles which is coming up shortly. After that I'll do 5k and pay for every other one with Toyota Care paying for the other one...if I ever make it LOL. I've had my Tundra almost 6 months and barely have 2700ish miles, that includes a thousand miles round trip to Westcott the second week I owned it.
    WILLINH likes this.
  16. Sep 7, 2022 at 8:16 AM
    xc_tc
    xc_tc New Member
    The Tundra has a dynamic oil change interval. The computer will calculate the oil life and tell you to when to change it. I think mine said something like 9736 miles which I thought was weird. Anyway, the biggest issue with modern oils and the oil change interval is the amount the oil goes down over time. Subaru changed the OCI on some of their vehicles from 10k to 7.5k because the boxer engines were consuming a lot of oil causing the level to get too low and leading to oil starvation. Most people don’t expect to top off their engines. All engines consume some oil but Toyota’s 3.5 V6TT seems to be ok in terms of oil consumption.
  17. Sep 7, 2022 at 8:44 AM
    Fishhead
    Fishhead New Member
    I honestly believe that with modern oils and with Toyotas engineering there's no worries about modern oil changes going out 10k miles.
    That being said I run mine at 5k, only because I rotate my tires every 5k. Cleaner oil will never hurt.
  18. Sep 7, 2022 at 9:05 AM
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    Oil is cheap, engines are not, 5k intervals for mineral or blend and 7-8k synthetic (checking life at 5k then making the call) seems safe enough
  19. Sep 7, 2022 at 12:08 PM
    Coasty
    Coasty New Member
    Pat
    Oregon
    2022 SRS Crew Max 6.5 4x4
    Turbocharged engines put more heat and wear into the engines and since I tow our travel trailer, I've done mine at 5K and will continue to do so.
    Mattedfred likes this.
  20. Jun 8, 2023 at 9:53 PM
    Tsm503
    Tsm503 Nothing to see here
    2021 DC SR5
    RC leveling kit GCS Transmission Cooler
    1k miles first oil change
    5k max following
    raylo and Mattedfred like this.
