Remote start won't unlock or turn off truck
Discussion in '2.5 Gen Tundras (2014-2021)' started by Larsstoner75, Sep 2, 2022.
  1. Sep 2, 2022 at 12:00 AM
    Larsstoner75
    Larsstoner75 [OP] New Member
    Lars
    2018 Toyota Tundra crew max sr5 trd
    Hello friends. I recently converted to a tundra from being a Chevy fan boy for the last ten years. So I have a 2018 tundra sr5. I have the remote start. I click lock three times and it will start my truck. But then I can’t unlock my truck. I walk right up to it and press unlock and nothing. I have to unlock it by putting the key in the door. And also I can’t figure out out to turn it off. Like on my chevys I had a remote start button. I press it to turn the truck off and I could unlock the doors with the fob and stuff. Please help
  2. Sep 2, 2022 at 10:32 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Not sure you can turn the truck off with the remote. Lock/unlock should work. Does lock and unlock work correctly when you are in the truck and using the buttons on the doors? If not, you have a lock actuator issue. Actuator may need to be replaced, wiring issue or the actuator has become unplugged.
  3. Sep 2, 2022 at 10:53 AM
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    Something is definitely not right. It sounds like it's starting okay, but it should turn off when you unlock the truck. Something is wrong if you can't even unlock it.
    Larsstoner75[OP] likes this.
  4. Sep 2, 2022 at 12:06 PM
    Larsstoner75
    Lars
    Yeah the lock unlock works fine on the fob normally. Just when I try to unlock it after I do the remote start it won’t unlock I have to put the key in the door
  5. Sep 6, 2022 at 11:32 AM
    hatchboi
    hatchboi New Member
    You probably have an aftermarket remote start kit on your truck. The oem remote start shuts off the truck right when you click the unlock button.
  6. Sep 6, 2022 at 12:17 PM
    Larsstoner75
    Lars
    No it’s factory already thought that might be the problem till I checked
  7. Sep 6, 2022 at 12:50 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    How old is the battery? Often I see remote start/lock issues being related to a bad battery. Ask me how I know...
  8. Sep 6, 2022 at 2:03 PM
    Cliffy34
    Cliffy34 New Member
    Pittsburgh
    2018 White Tundra SR5 Crewmax
    Are you sure it’s stock? I know with the aftermarket Start X remote starter you won’t be able to use the fob to unlock if the TPMS harness isn’t hooked up correctly.
