Removing 6" procomp lift to go to stock
Discussion in 'Suspension' started by RobHM, Sep 5, 2022.
  1. Sep 5, 2022 at 7:09 PM
    RobHM
    RobHM [OP] New Member
    Robert
    2008 grey Tundra 4x4
    Good evening all. I just got an 08 tundra crew max 4x4 with a 6" procomp lift kit that I want to take back down to stock. I've seen a couple posts about the crossmember cutout and am wondering if there's anyone that may have the cutout piece taking up space somewhere and/or the stock differential brackets that they wouldn't mind parting with. Please let me know. Thanks so much.
    I added a screenshot from a similar post talking about rewelding the cut piece
    azcoues likes this.
  2. Sep 5, 2022 at 7:46 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    You can actually buy the the OEM crossmember from Toyota, couple hundred bucks. Would need to be welded on.
  3. Sep 6, 2022 at 7:11 AM
    PayItOff428
    PayItOff428 New Member
    Jake
    The United State of Texas
    2012 SR5 Double Cab 4X4
    Looking to do the same. I am going to follow this. Do you have your original knuckles? I have a 6” procomp and want to remove it as well. So we will have to redo the crossmember and also reinstall the stock knuckles
    azcoues likes this.
  4. Sep 6, 2022 at 7:16 AM
    You guys can likely save all of the lift parts coming off the truck and sell to someone looking to do the lift. Offset the cost. Would be sweet to find someone on here that would meet up for a stock to lift swap and vice versa.
  5. Sep 6, 2022 at 7:50 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Guess I was wrong on the cost. It's a throwaway part when it's cut out.
