trd pro double cab mpg- considering buying
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by hockeyman70s, Aug 31, 2022.
  1. Aug 31, 2022 at 8:04 AM
    hockeyman70s
    hockeyman70s [OP] New Member
    Hi all, I have read through quite a few threads. I am considering buying a 21 double cab trd pro. I currently have an 05 6 speed tacoma trd of. Curious what folks are seeing for lifetime mpgs. I currently get around 18.5 and have seen plenty of posts about 12-13 on the tundra. I feel like in todays world i should be heading for better fuel economy but understand ill be taking a hit- just a matter of how much. I do mostly country 40-50 mph roads and drive pretty conservatively. It will tow a 10k dump trailer from time to time. Thanks
  2. Aug 31, 2022 at 8:08 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    i get 14mpg on stock wheels with a 2" level
    10k dump trailer? As in, you tow a 10k lbs or the trailer is rated for 10k and you tow about 3-4k lbs with the tacoma? I hope you aren't towing 10k lbs with a tacoma, i wouldn't even do that with a tundra.
    Oey12 likes this.
  3. Aug 31, 2022 at 8:17 AM
    hockeyman70s
    Appreciate the feedback. Its rated for 10k. weighs just over 3k empty. Ive only ever filled it to maybe 7-8k total. I have a 1 ton cummins that tows it- never the tacoma. My hopes are to get rid of the two current trucks in favor of the tundra.
  4. Aug 31, 2022 at 8:20 AM
    Danimal86
    Daniel
    Sacramento, CA
    ohh good. Was worried for a min.
    8k is about max i would want to tow with a tundra for a fairly short trip.
  5. Aug 31, 2022 at 8:26 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    Honestly it depends on how you drive and where you drive. If you live in an area where there are many stop lights/stop signs than 12-13 will be your average. If you have to “beat” everyone off the line or drive consistently over 70mph ish, that will put you in the same boat. I have zero problems averaging about 17ish mpg’s setting cruise control at 70 and minimizing “city” driving. But I am well aware not many owners can do that. Truthfully I have not found the mpg’s to be as bad as the internet makes it out to be.
    In my 4cyl RAV4 I have seen multiple occasions where I average 12-13 for an entire tank of gas due to traffic. I don’t idle, cool, or warm any vehicle I own. Just get in and drive. But that I consider bad for the size/power ratio…
  6. Aug 31, 2022 at 8:26 AM
    hockeyman70s
    Haha, thank you- Im really just trying to convince myself that going for less mpgs is a good idea with the direction that gas prices and gas vehicles seem to be going.
  7. Aug 31, 2022 at 8:51 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Welcome to the forum.
    I get around 11 in my 2014 with 33s on it.
    Mostly city driving, I never tow anything..
    I had a 2021 rental 6-cylinder Tacoma for 8 months.
    It was like driving a gocart with a lawnmower engine compared to my Tundra's 5.7.
    Even my wife made fun of the squirrels under the hood.
    Although it did get 18 MPG when gas prices were at their peak....:thumbsup:
    Tundra234 likes this.
  8. Aug 31, 2022 at 9:20 AM
    Elduder
    Elduder New Member
    Im on 35s, lifted and once hand calculated and offset for the fact that my speedo is ~5% off, Im averaging 12-13 on short trips and can still get 16-17 on long highway trips. It varies so much on location, driver and the truck itself.
    Our 4runner is stock and averages 16-17 city and up to 21 highway.
    We take the Tundra everywhere, simply because its so much more enjoyable to drive. I had a 2018 Tacoma prior, dont miss it.
  9. Aug 31, 2022 at 3:28 PM
    Johnnyquad
    Johnnyquad New Member
    21 Pro double cab MGM
    Tint, clear bra, OEM stereo upgrade, tonneau cover, line x, 285/65/18 Toyo AT3
    I get between 15 to 15.5 with my 21 Pro and 33 inch tires per tank on average.
    hockeyman70s[OP] likes this.
  10. Aug 31, 2022 at 4:35 PM
    Bulldog9
    Bulldog9 "My other car is a Porsche"
    NOVA
    2017 TRD PRO in Cement
    see sig for mods.....
    I've got a 2017 TRD PRO DC and running 275/70 18 tires which are just a bit taller than OEM. With the Stock tires, I could easily average 19-20 on the highway, and 18-19 on country roads, with 15-17 city. With the larger tires my City mileage is the same, but I've lost 1-2mpg highway over the last 70K miles and 5 years. My son in law has a 2020 Taco, he gets 2-3 better MPG than I do.
  11. Sep 1, 2022 at 10:56 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    If you are worried about MPG, then you probably should reconsider a Tundra. EPA estimates 13/17 and that is attainable or you can do better if you mind your driving and keep stock size and SL tires. Add larger, heavier tires, lift it and you will drop a few MPG.
    It is a heavy truck with an old school 400HP V8 and 430 gears, nothing about the truck is MPG friendly. But they are capable, powerful and reliable trucks.
  12. Sep 1, 2022 at 1:02 PM
    Ejp1234
    Ejp1234 New Member
    2021 TRD Pro DC Lunar Rock
    13-14 at best for me, but I drive it like it wants to be driven.
  13. Sep 1, 2022 at 1:22 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    You’ll do fine with only open county road, tundra is made for long slow road trips, it suck gas in local stop and go traffic.
  14. Sep 1, 2022 at 3:57 PM
    Wintersun
    Wintersun New Member
    Best option is to buy a very fuel efficient vehicle for trips where you do not need a pickup truck. My truck averages 16 mpg but my plug-in hybrid has been averaging 99 mpg. Trips to the supermarket or Ace hardware or Costco or to restaurants are done with the hybrid. Trips to the landscape supply and building materials stores and plant nurseries are done with the truck.
    Good fuel efficient cars include the Suburu SUV that get 30 mpg and the Honda Fit that gets over 45 mpg or the Kia Soul, etc.
  15. Sep 4, 2022 at 2:46 PM
    Bulldog9
    NOVA
    The retained MSRP, super low cost of ownership and maintenance way offset the 3-4 mpg difference.
  16. Sep 4, 2022 at 3:36 PM
    Wintersun
    My primary concern is the driving range of a vehicle. My diesel pickup got 16 mpg and had a 36 gallon fuel tank. A 2022 Tacoma has a 21.1 gallon fuel tank and at 17 mpg provides a usable range of only 320 miles. The Tundra has roughly the same fuel economy but depending to the model comes with a 22.5 or 32.2 gallon gas tank.
    Towing the range is likely to be reduced to 240 miles which is a consideration as it is no fun running out of gas and even less so when towing a trailer.
    It is not legal to swap out the factory gas tank for a larger one which is why Arrow and Titan have stopped making them. So whatever the truck comes with is what you have.
  17. Sep 4, 2022 at 4:06 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    My 38 gal tank have 500 miles range of highway driving, it's the local that kill the mpg
