  1. Sep 3, 2022 at 5:53 AM
    Taco-Spike
    Two Trucks
    Spent the past week on a stay-cation. Visiting family, some house chores and video games. Put some miles on the truck :cool:
  2. Sep 3, 2022 at 6:31 AM
    THinTX
    THinTX New Member
    Tony
    2018 MGM DC 4X4
    Got bored at work :D
    YotatheToyota, rebmo, Jcmf52 and 14 others like this.
  3. Sep 3, 2022 at 7:39 AM
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    X2
  4. Sep 3, 2022 at 8:26 AM
    Yzed608
    Yzed608 New Member
    Wisconsin
    So I went to the local dealer and never realized they have their own body shop there, had it done in half a week. They even took my old cracked one to use for color matching. Last weekend I was able to get it on after taking a long while to extract about 7 broken bolts between the rear support and the lower tabs. I got replacement hardware at Home Cheapo and they had GM replacement body bolts. I didn't realize the M6 was M6.3 not M6.0, but worked good because a couple of the ones I drilled out weren't exactly centered so the larger diameter helped. I was surprised to find they also had the Toyota push pin retainer things, grabbed a few of those just for backups too.
    Modified the harness I made for the AGM battery GM diode, filed the edges off the side of the mini fuse plug after realizing it was always loose was because it couldn't seat down all the way. Here's a before and after comparing it to a normal fuse.
    Yesterday sprayed out the bed and installed a gap guard, will see how long it stays on for. Was using bricks to weight it down after installing.
  5. Sep 3, 2022 at 11:11 AM
    Npowers66
    Npowers66 New Member
    18 SR5 crew max
    No pics , but oil change and oil filter housing swap.
  6. Sep 3, 2022 at 7:13 PM
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    20220902_131153.jpg 20220902_131138.jpgGave her long overdue bath yesterday.
    Henry1jg, Jego, Winning8 and 10 others like this.
  7. Sep 3, 2022 at 8:34 PM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM Tundra & 25 TRD Pro Sequoia
    Slapped on my first sticker
    Wallygator, niedejb, SMTundra and 9 others like this.
  8. Sep 3, 2022 at 10:55 PM
    Rangergillikin
    Rangergillikin New Member
    Alabama
    2021 magnetic grey TRD Pro Crew Max.
    TracRac bed rack, Retrax bedcover, Anytime forward facing camera, Rago dash mounting plate, changed all lights to LED with 1200lumen reverse light, added LED above tag reverse light, rear bumper step, Go Rhino step sides, CCM Cat Security Shield, tool mounts on bed rails, added tie down pad eye on bed rails.
    That gap guard looks like a good idea. Which one did you get? I’m always getting stuff stuck between the tail gate and bed.
  9. Sep 4, 2022 at 7:18 AM
    Yzed608
    Yzed608 New Member
    Wisconsin
  10. Sep 4, 2022 at 9:08 AM
    SAGE63
    San Diego County
  11. Sep 4, 2022 at 9:28 AM
    Yzed608
    Yzed608 New Member
    Wisconsin
    Possibly, the front drains are still there though. I actually haven't closed the tailgate yet, but I'd imagine it's not a perfect seal at the edges.
    SAGE63 likes this.
  12. Sep 4, 2022 at 10:51 AM
    HamHands
    HamHands Honey-Glazed Member
    2018 Tundra DC MGM SR5 5.7 TRD 4x4
    Had a power steering leak repaired :( It was a bad hose. I’ve been so busy lately I just took it to the dealer and let them do it. Four years and 60k this is the first repair I’ve had to make. Hoping it’s the only one for awhile, the truck is still new in my mind.
    They tried to sell me the throttle body/fuel injector cleaning service due to mileage. I’ve always thought those things were kinda BS. A sales gimmick. What are your thoughts on it?
    bulldog93 likes this.
  13. Sep 4, 2022 at 11:00 AM
    Taco-Spike
    Two Trucks
    I would say throttle body and MAFS sensor could use a cleaning. Maybe maybe not but an Easy $15-20 for a diy and maybe 20ish minutes of your time.
    Jcmf52 likes this.
  14. Sep 4, 2022 at 12:15 PM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    Finally got time to install the ScanGaugeIII installed this afternoon. Install was super easy and now I can monitor pretty much anything.
    Cost wasn’t bad considering it comes with everything including the nice RAM style ball mount.
    Link below if anyone is interested.
    https://www.scangauge.com/products/productsscangauge-iii/
  15. Sep 4, 2022 at 12:31 PM
    jackienguyener
    jackienguyener OKToyota
    Jackie
    2016 Tundra 1794
    Nice! I’ve got mine mounted in the same spot, but with an Offroam air vent mount instead of the suction mount
  16. Sep 4, 2022 at 1:08 PM
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    Picking up a "new to me" boat next week. Its 11hrs away and a bit on the heavy side... so I added Firestone airbags and a pair of LED rear work lights.
    Also tossed a toolbox in the already too-short bed... but needed a secure place for roadtrip tools/supplies.
    Should be a solid roadtrippin tow vehicle now.
    20220904_152938.jpg received_832797124552334.jpg 20220904_155930.jpg 20220904_155615.jpg 20220904_151114.jpg 20220904_151306.jpg
  17. Sep 4, 2022 at 1:45 PM
    RustyShackle323
    Stewart
    NC
    Really like that mount! Looks clean.
    Tripleconpanna likes this.
  18. Sep 4, 2022 at 2:38 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Cosmetic things today....
    Kid and I removed the plastidip from our steering wheel trim pieces and painted them. Waiting for them to dry before reinstalling.
    Before that, we installed LED interior lights on my wife's 2020 Rav4.
  19. Sep 4, 2022 at 3:12 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Doin' Truck Stuff!!!!
  20. Sep 4, 2022 at 3:15 PM
    Bergy24
    Bergy24 New Member
    Added my PRO wheels to my limited today. 252BF34F-69E0-4BBA-9E63-ED946574347D.jpg
    Henry1jg, lowball, Nbab23 and 24 others like this.
  21. Sep 4, 2022 at 5:05 PM
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    You’re gonna love that boat! I bought my Chappie deck boat new in 2004 and never looked back. Basic upkeep and maintenance and it has NEVER left me stranded in over 600 hrs. I just replaced and upgraded the carpet, installed a new very expensive stereo system and did some minor fiberglass repair, it still makes me smile when people ask me what year it is and they don’t believe me.
    WFD473 and Dragracer_Art[QUOTED] like this.
  22. Sep 4, 2022 at 6:35 PM
    RobertD
    Robert
    DFW, Texas
    Storm knocked down a bit of fence today. So picked up some new fence material and will be rebuilding in the morning.
  23. Sep 4, 2022 at 6:39 PM
    Dragracer_Art
    Dawsonville, GA
    2020 Crewmax 4x4
    Yeah my 1st was a 1997 Chaparral 2330. Only got into boating last year but it was a great "starter boat" to learn on.
    Sold it back in June during peak for way more than I paid for it.
    It was an awesome boat but we needed something newer.
    This 2007 Chaparral 256SSX is just a damn sexy boat. Cant wait to get it home.
  24. Sep 4, 2022 at 6:41 PM
    BrunoTheRescuePup
    BrunoTheRescuePup New Member
    SW Portland Metro
    2021 MGM Limited TRD
    Eibach Pro-Truck 2.0, Coachbuilder +1, Undercover Flex, Tyger Star Armor, TRD Rear Sway Bar, DD SS3 Max, MisoCustoms
    Finally. Neighbor and I busted it out in about 4 hours. Had some hiccups. Next one would be 2 hours.
    Driver and passenger side perfectly level both front and back. 1/4 inch rake. I have a CB +1 I will drop in later in the month.
    New tires in a couple weeks.
  25. Sep 4, 2022 at 7:08 PM
    GELCW
    GELCW New Member
    Erik
    Northern Virginia
    2018 Gray Tundra Platinum
    Please keep us posted on that dash cam, I have been eyeing that one for awhile. I like that it is very compact.
  26. Sep 4, 2022 at 7:16 PM
    Terndrerrr
    Terndrerrr 924000 miles to go
    Music City
    6UR-FE
    Dropped off my rental carpet steamer today. Parked next to this sweet old loooooooong bed. Looks like it has had a workin life.
  27. Sep 4, 2022 at 7:17 PM
    I suggest the Thinkware F200 Pro.
    GELCW[QUOTED] likes this.
  28. Sep 4, 2022 at 7:22 PM
    GELCW
    GELCW New Member
    Erik
    Northern Virginia
    Watch for those two screws on the oil cover, I changed mine over to stainless steel from the big box store. Salt in the winter will do some damage to it.
    Silver17[QUOTED] likes this.
  29. Sep 4, 2022 at 7:25 PM
    GELCW
    GELCW New Member
    Erik
    Northern Virginia
    Thanks I’ll check them out.
  30. Sep 4, 2022 at 7:50 PM
    Is this the 4660 that you had? Any issues with it? According to Crutchfield, the only 3 Pioneers that are in-dash with Android Auto that have an HDMI input are the 4660, 5700, and 6600.
    https://www.crutchfield.com/p_130DMW4660/Pioneer-DMH-W4660NEX.html
