Spacers needed for 12.5 tires?
Discussion in 'Wheels & Tires' started by Iceman9218, Aug 19, 2022.
  1. Aug 19, 2022 at 10:30 AM
    Iceman9218
    Iceman9218 [OP] New Member
    2016 CM TSS
    I'm upgrading from the TSS standard 285/55/r20 to 33/12.5/r20. Will this require 2" (or less) spacers?
  2. Aug 31, 2022 at 6:05 AM
    Jmccracken1214
    Jmccracken1214 New Member
    2015 Tundra CM
    I just went from FN wheels and 285/75/18 to factory trd wheels and 295/70/18, I’m not sure with a factory control arm but with my Ironman offroad UCA, the tire was hitting it without spacer and couldn’t be mounted that way. I ran a 1.25” spidertrax and don’t have any rub.
    joseph_womack likes this.
  3. Aug 31, 2022 at 6:57 AM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    Like stated above ^^^
    Running stock wheels with 35x12.5R18" mud graps, tires clear in the rear without spacers, but in the front they hit my aftermarket UCA (Rough Country Non Adjustable tube UCA) but they do not hit my body mount
    Running 1.5" spacers
  4. Aug 31, 2022 at 10:43 AM
    Jmccracken1214
    2015 Tundra CM
    Are you running spacers front and rear?
    I bought spacers for both, but wondering if I should have skipped them on the rear
  5. Sep 1, 2022 at 7:06 AM
    joseph_womack
    Joe
    Louisiana
    absolutely not, make sure you run the same thing rear as the front... I'm not sure if its dangerous not to, but it just looks silly :rofl:
    make sure you put red Loctite on the spacer studs before bolting them onto the hub, it'll ensure your wheel never comes off on the interstate
