Column Shifter with Sport Mode?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Cruzer, Aug 31, 2022.
  1. Aug 31, 2022 at 7:03 AM
    Cruzer
    Cruzer [OP] Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Just wondering….do the SR models with the steering column shifter have sport mode shifting capabilities? Basically, can you choose which gear you want to be in?
  2. Aug 31, 2022 at 7:13 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Yup, there is a + and - rocker switch on the shifter, and the tow haul button is also on the end of the shifter.
    My SR5 has a column, so its not just the SR's. Also the S mode is in the perfect position to rest your hand on it if your shifting alot.
    Terndrerrr and Cruzer[OP] like this.
  3. Aug 31, 2022 at 7:14 AM
    NH 2018 Limited
    NH 2018 Limited New Member
    2018 Tundra Limited TRD Offroad
    It doesn't work like that, it's not a sport mode, it just locks out any gear higher than what you select.
  4. Aug 31, 2022 at 7:19 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    I use the sequential shifting primarily for wheeling. Been looking at regular cabs, which the majority that I’ve seen so far have column shifters and was worried I wouldn’t be able to shift manually.
  5. Aug 31, 2022 at 7:21 AM
    MadMaxCanon
    It will work better for wheeling since your hand is really close to the steering wheel, you can go to the shifter and steering wheel back and forth really fast.
    You could probably even rewire the rocker switch to buttons on your steering wheel since the whole mechanism is already right there.
    Cruzer[QUOTED][OP] likes this.
  6. Aug 31, 2022 at 7:21 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Rest your hand on? I’m guessing it’s all the way to the bottom and can’t be moved down any further? That should come in handy off-road.
  7. Aug 31, 2022 at 7:22 AM
    MadMaxCanon
    correct
