Which model year is good for me?
Discussion in '1st Gen Tundras (2000-2006)' started by rnln, Aug 29, 2022.
  1. Aug 29, 2022 at 4:35 PM
    rnln
    rnln [OP] New Member
    Hi everyone,
    I am looking for a good used truck to tow my boat (everyone is proximate 5,000-6,000 lbs total include trailer) and also can be able to take 5 people comfortably, a crew cab type? If possible, I am thinking $10,000 or below. My question is if it's possible? If so, does anyone know which model/year is good for this and also more reliable, and which I should try to steer away from?
    The boat is a Boston Whaler revenge 22'.
    Thanks in advance.
  2. Aug 29, 2022 at 5:02 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    I have a 2006 Double Cab 2WD.
    I tow a 1988 Boston Whaler 15 and a 1986 Boston Whaler 18 Outrage, both are very light for their respective size.
    The truck handles both fine, but I can 'feel' the 18 back there . . . maybe around 3000-ish lbs.
    The 4.7 motors in these trucks are great motors, but far from being 'powerhouses'. (relatively small displacement)
    5000-6000 Lbs. is going to tax the truck. Can it 'handle it' ??? . . . sure. Is it ideal? . . . nope.
    If you're just going a few miles to the launch ramp, it'd be 'OK' . . . but if you're doing any lengthy trip, and or pulling some grades, I'd look at something more substantial.
    If you're dead set on one, i'd def. look into upgrading the rear suspension with either beefier leafs or airbags, (these trucks are soft riding half tons).
    Also, the brakes on these trucks aren't their strong point, I'd look into upgrading the fronts even if your trailer is equipped with brakes.
    And I would for sure use one of those weight-distributing hitches.
    6000-7000 lbs. is a lot of weight for ANY 1/2 ton truck . . . you're more in the 3/4 to 1-ton arena.
    Sorry to be the bearer of bad news, just don't want to give bogus info . . . could cause an accident.
  3. Aug 29, 2022 at 5:25 PM
    rnln
    Hi HBTundra,
    Thanks for the info. Do you know if Toyota make Tundra with bigger than 4.7L engine?
    Thanks.
  4. Aug 29, 2022 at 5:37 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    2007 and up, 5.7L
  5. Aug 29, 2022 at 5:42 PM
    rnln
    Thank salb1k,
    This is talking about power and towing capacity. Can I ask about reliability. Is there any model/year I should avoid to stay away from headache?
    Thanks again
  6. Aug 29, 2022 at 5:46 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    4x4? If you let a 4.7 rev, its adequate. My sequoia had a lsd, but i only took it to a boat ramp when the lake was high, so i didnt get down in the algae. But the 5 speed in the '05-'06 with double first gears might be the ticket.
    theres a weird master cylinder to stay away from, and the vvti engines have a pita air pump that might need attention.
    5N0W808 likes this.
  7. Aug 29, 2022 at 5:46 PM
    alb1k
    Left Coast
    It's good
    They are all reliable. Someone had a report I saw a while back and maybe it was the '15. But, I would buy any through '21.
    5N0W808 likes this.
  8. Aug 30, 2022 at 6:48 AM
    chunk
    chunk New Member
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    Like mentioned they are reliable, but a bit anemic, my 2001 has shitty brakes too, when you are towing that much. I heard Toyota may have addressed the brake issue in later years. $10,000 isn't much anymore to by a decent vehicle, unless you get lucky. Good luck in your search.
  9. Aug 30, 2022 at 7:35 AM
    Not a guarantee though. They offered the 4.7L in the 2nd gen for a few more years. Until 09 I think.
    alb1k[QUOTED] and Tundra2 like this.
  10. Aug 30, 2022 at 9:42 AM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    I’m at 308k with the weird master and SAI with no issues.
    The fancy master gives the truck a very modern brake feel as compared to my 07’ sequoia without it. That being said my 07’ sequoia’s SAI Pump went out, but that was an easy fix thanks to the Hewit pass.
    I would stay with an 05-06, VVTI and 5-speed is worth it.
    But honestly depending on how far you tow the boat, I think it’s too heavy to comfortable tow with these trucks. My RZR trailer and gear is about 4,500lbs, and it tax’s it pretty hard in a head wind or up grades.
    This little trailer it pulls no problem.
  11. Aug 31, 2022 at 9:58 AM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    Sadly, for us 1st Gen cheerleader's, this is probably the best answer.
    DarkMint likes this.
