Paint above rocker Panel
Discussion in '3rd Gen Tundras (2022+)' started by Twinlakes, Aug 29, 2022.
  1. Aug 29, 2022 at 7:02 AM
    Twinlakes
    Twinlakes [OP] New Member
    Burlington Ontario Canada
    2022 Toyota Tundra 1794
    None
    Based on the photo anyone have an idea what this is I drive a 2022 1794
    Thank You
  2. Aug 29, 2022 at 7:05 AM
    DrZoidberg
    DrZoidberg New Member
    Dave
    Tesla MYP
    There’s PPF there. Looks just slightly bubbled like it’s stating to peel or not adhere
  3. Aug 29, 2022 at 7:15 AM
    Twinlakes
    None
    How would you fix this?
  4. Aug 29, 2022 at 7:15 AM
    Knifeguy
    Knifeguy New Member
    Erik
    Oklahoma
    22 SR5 4x4 Crew-Max Short bed
    Mine is full of bubbles along all the edges too. Makes me wonder how long before I have to peel it all off
  5. Aug 29, 2022 at 7:17 AM
    Twinlakes
    None
    Attention to detail just does not seem to be there perhaps all manufaucturers are also suffering.
  6. Aug 29, 2022 at 7:24 AM
    AZTundra
    Paul
    Phoenix, AZ
    Would probably need to remove and reapply the ppf film. The dealership should be able to handle that for you.
  7. Aug 29, 2022 at 7:26 AM
    Twinlakes
    None
    Thank You appreciate the info I will call the dealer.
  8. Aug 29, 2022 at 8:14 AM
    tbrady
    tbrady New Member
    Southern Idaho
    2022 DC LTD Army Green
    Leer Canopy, TRD Steps
    My 2012 has a similar texture for a few inches above the rocker panel. I believe it is by design as it is like bed liner material with color matching paint to provide protection from rocks and other road hazards.
  9. Aug 29, 2022 at 9:20 AM
    Gene5253
    Gene5253 New Member
    Gene
    Boise ID
    2020 Tundra CM Limited
    Do not believe there is ppf in that area. I think it is just an anti -chip coating applied before paint. I do not think you could apply ppf over a textured surface like that. if there is ppf there than not surprised to see bubbling. (I have been known to be wrong before tho)
  10. Aug 29, 2022 at 9:26 AM
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    It’s a texture applied to the rocker panels. It’s been on all generations as far as I can remember.
    I’ve owned each generation at it’s been on my past 3 generations.
    Normal
  11. Aug 29, 2022 at 9:30 AM
    JRD
    JRD New Member
    2022 Tundra 1794 Blueprint
    It is a PPF. Had the same issue on 1794 Blueprint. Had it removed when I had ceramic coating applied.
    Gene5253[QUOTED] and Yaboy like this.
  12. Aug 29, 2022 at 10:00 AM
    Knifeguy
    Knifeguy New Member
    Erik
    Oklahoma
    Not talking about the texture. Talking about the clear film on top.
  13. Aug 29, 2022 at 10:22 AM
    JRD
    JRD New Member
    That is the PPF applied over the texture. It does not appear to adhere well to the texture. I had mine removed, much nicer without it, especially on a darker color paint.
