Official Tundra Wheel and Tire Setups - Pics and Info
Discussion in 'Wheels & Tires' started by csuviper, Jan 10, 2014.
  1. Aug 25, 2022 at 4:28 PM
    #2851
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    M/Ts are the new A/Ts! @king.cong.1119 Tundra looks killer! I would trimming away with my zero offset.
    king.cong.1119 likes this.
  2. Aug 25, 2022 at 4:35 PM
    #2852
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I think mud flap will rub, my stock height tundra rub on mud flap with 275/70-18 with +15 offset rim
  3. Aug 25, 2022 at 4:59 PM
    #2853
    king.cong.1119
    king.cong.1119 New Member
    thanks man! Yes I was trying to stick with 25mm offset for this reason haha
  4. Aug 25, 2022 at 5:03 PM
    #2854
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    Im in a 2017 - past the point of coddling so cutting her won't hurt too bad at this point; what does hurt is the damn price of tires. Those Yoko's are frick'n sweet!
  5. Aug 25, 2022 at 5:39 PM
    #2855
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Yes, 285/70-18 fit on stock wheels and stock truck.
    mpj76a[QUOTED] likes this.
  6. Aug 25, 2022 at 11:03 PM
    #2856
    Clemshady
    Clemshady Bama Storm Trooper
    Jeff
    2017 Super White Limited DC TRD 4x4 Offroad
    \ Factory OEM LED Tundra Pro headlight upgrade Diode Dynamic amber Pro fogs 3" DD amber Pro ditch lights SDHQ ditch brackets 42" DD light bar SwitchPro 9100 Pedal Commander Vinyl wrapped bumpers Painted calipers Painted horns Chrome delete complete ARE CX Evolve Topper TRD rear swaybar Matching door handles and mirror caps Oh shit handle upgrade Matching grille surround/hood bulge TRD PRO insert grille BBS Forged TRD PRO wheels Coachbuilder +3 shackles Eibach Pro 2.0 Coilovers and rear shocks
    Slapped some 295/70/18 Cooper Discoverer AT3s with my Heritage Edition wheels on my 17 Limited. Still have original UCAs on it with Eibach 2.0 adjustable coilovers set at 2”. Seem to be a perfect fit with no rubbing. I have RCI skid so didn’t have to trim anything. Running +3 Coachbuilder shackles on rear with Eibach shocks. Will be adding RAS soon to help with leaf springs and add a little more rake.
    85A30EC0-4F58-484D-B057-7ED1E29922E8.jpg 2A0DEA59-0E14-4E15-B365-45B350BADACB.jpg
  7. Aug 28, 2022 at 9:28 PM
    #2857
    Dirtnap
    Dirtnap New Member
    2021 Tundra TRD Pro Lunar Rock
    21 TRD pro. Westcott lift. 35’s Toyo at3 on method mesh +18
  8. Aug 29, 2022 at 2:11 PM
    #2858
    Biby
    Biby New Member
    My friend what about with fender flare u think they still stick out. I like it i whant something like that but i have fender flare not sure what to do
  9. Aug 29, 2022 at 2:24 PM
    #2859
    Biby
    Biby New Member
    My friend do u have a pic to see how much the tire stick out i love the look
  10. Aug 29, 2022 at 2:43 PM
    #2860
    Biby
    Biby New Member
    My friend i got the same problem as u did u get an answer yet
  11. Aug 30, 2022 at 2:45 AM
    #2861
    I will take some.
  12. Aug 30, 2022 at 10:04 AM
    #2862
    7dgoat
    7dgoat Member
    NJ
    2025 Terra Platinum Off-road
    Finally got a new pair of shoes today! Cooper discoverer at3 275/70r18.0B95B6A3-92F9-4667-AA43-7B110286ADDA.jpg
    Winning8, ATV25, mZiggy and 2 others like this.
  13. Aug 30, 2022 at 10:39 AM
    #2863
    Uturn09
    Uturn09 New Member
    Roscoe
    2017 Grey Tundra SR5 TRD
    None to day....that’s why I’m here.
    If you rotate them they will last well over the 60k. Mine did.
    7dgoat[QUOTED] likes this.
  14. Aug 30, 2022 at 11:28 AM
    #2864
    SoCalTundy
    SoCalTundy Tundra Owner since 2017
    Icon Shocks. Total Chaos UCA. Deaver u748 TC shackles Flowmaster super 50. Diode Dynamics fogs. 5.29 Revolution Gears. SSW 17" wheels on BFG 35x12.5
    Do you have any pictures of your truck with these on? I'm seriously considering these or the Summit Apex.
  15. Aug 30, 2022 at 12:25 PM
    #2865
    21sr5
    21sr5 New Member
    2021 Tundra SR5 4x4
    K&N cold air intake, MBRP catback exhaust, Fuel Blitz rims, General Grabber A/T tires
    I'm sure you've got many changes since this post, but did you have any issues with bearings or ball joints wearing faster than expected with that offset?
  16. Aug 30, 2022 at 2:04 PM
    #2866
    7dgoat
    7dgoat Member
    NJ
    What pressure did you run? I put in 40lb. I need to do a chalk test.
  17. Aug 30, 2022 at 4:13 PM
    #2867
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    Not that I am aware of. This offset is great. Not too aggressive yet looks good and allows for larger tires. I have new rims and tires since then but kept the same offset.
    21sr5[QUOTED] likes this.
  18. Aug 30, 2022 at 4:14 PM
    #2868
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    Hell yeah! I knew you couldn’t leave those 33s on there for long. Looks great.
  19. Aug 30, 2022 at 4:18 PM
    #2869
    king.cong.1119
    Haha. Thanks. Yea the 33s were super smooth and light so it was great and I kinda got spoiled.
  20. Aug 30, 2022 at 5:00 PM
    #2870
    jaflynn738
    jaflynn738 New Member
    Virginia
    Looks great, any rubbing?
  21. Aug 31, 2022 at 7:58 AM
    #2871
    06tacomadc
    06tacomadc New Member
    Motor City
    Tundra
    21 1794 with HE wheels and ridge grapplers
    COTundra23, equin, Bo Dangles and 4 others like this.
  22. Sep 2, 2022 at 2:30 PM
    #2872
    Marshwalker
    Marshwalker New Member
    Z
    2020 tundra
    275/70r 18 maxxis razor at
    18in scs ray 10
    6112 1.9
    5160 with 1.5 icon pack
  23. Sep 2, 2022 at 2:59 PM
    #2873
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Newly 2/1 lift with BFG KO2 275/70-18 on Mamba M23 E12
  24. Sep 2, 2022 at 3:05 PM
    #2874
    Uturn09
    Uturn09 New Member
    Roscoe
    I ran 32-36, 40 is probably fine
  25. Sep 2, 2022 at 7:41 PM
    #2875
    olds350
    olds350 New Member
    How did you address the short factory studs and those acorn lug nuts used on the Rebounds? Did you swap out the studs?
  26. Sep 3, 2022 at 3:13 PM
    #2876
    frichco228
    Frank
    Virginia
    You will like RAS, I run the same suspension and height and think the truck works much better with RAS and that suspension vs just the Eibach suspension alone. They compliment each other very well. Seems to better match the spring rate of the lifted coilovers.
    Clemshady[QUOTED] likes this.
  27. Sep 3, 2022 at 3:39 PM
    #2877
    Clemshady
    Jeff
    Thanks for the info. I’ve heard a lot of good things about RAS. I can’t wait to get them on. :thumbsup:
  28. Sep 5, 2022 at 1:33 AM
    #2878
    k3k0a808
    k3k0a808 New Member
    2021 1794 WCP
    Still havent taken really good pics yet, been busy with work.. but i got these
    D1S7N, 406Michael, KWC and 14 others like this.
  29. Sep 5, 2022 at 3:30 AM
    #2879
    Beatle
    Beatle New Member
    285/70/17 maxxis tyres on Elite podium rims p30
  30. Sep 6, 2022 at 8:34 PM
    #2880
    PayItOff428
    PayItOff428 New Member
    Jake
    The United State of Texas
    2012 SR5 Double Cab 4X4
    Summit Dakar 17x9 0 offset on 35” Nitto Ridge
