Anyone know if I can use rough country lift spindles without drop crossmembers on 2wd cm
Discussion in 'Suspension' started by Jsethwerner225, Aug 26, 2022.
  1. Aug 26, 2022 at 11:21 PM
    Jsethwerner225
    Jsethwerner225 [OP] New Member
    Hi everyone
    I have a 2010 2wd crew max with 1.5"rear procomp lift helper springs and 5100s on top setting in the front with tuff country tubular control arms.
    I just acquired a 6 inch rough country lift kit with everything except the dropped crossmembers . Could I use the lifted spindles in the kit to get more front lift without the crossmembers or would my geometry be all out of spec?I also got several size spacers with the kit that go on top of the strut assembly, was curious if I put 5100s on bottom setting with small spacer if that would help with ride. It came with huge blocks for the back which I don't plan to use, hoping I can use shackles with my helper springs to level out the rear if I get front higher with these spindles.
  2. Aug 26, 2022 at 11:22 PM
    Jsethwerner225
  3. Aug 26, 2022 at 11:47 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    By acquired, do you mean someone gave it to you? Just asking because I believe there are better ways to lift your truck. I looked into drop spindles for my truck (solomotorsports) and the needed parts in addition made a long travel kit way more desirable. And, Tough Country is not good stuff.
    Cruzer likes this.
  4. Aug 27, 2022 at 4:08 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    The drop brackets bring down your alignment cams and your lower control arms to correct the geometry, I'd think without that it would be a pain to align. Your lower ball joint would be operating at a weird angle too I would think.
    Cruzer likes this.
  5. Aug 27, 2022 at 6:20 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Geometry definitely out of whack. You could always buy the crossmembers from RC. But you’re gonna have to commit to the lift cuz as you know you’re gonna have to chop the OEM crossmembers. I’m not against these type of lifts, I have a 7” BDS myself, but it seems RC is the worst of them.
    des2mtn likes this.
  6. Aug 27, 2022 at 6:47 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    If it's newer RC stuff, I think they have upped their quality. ReadyLift was the bees knees early on but they lost some of their design team (migrated to RC). After that the reverse started happening.
  7. Aug 27, 2022 at 4:04 PM
    Jsethwerner225
    Yes I actually got the entire lift minus the crossmembers for 50$ so pretty much free and it's all brand new. Also got a set of rear radflo 2.5 shocks,2 sets of random tundra front spacer lifts and extra set of brand new stock spindles . Guy was just cleaning out his garage
