Suspension question
Discussion in 'Suspension' started by Mailman13357, Aug 26, 2022.
  1. Aug 26, 2022 at 9:00 AM
    Mailman13357
    Mailman13357 [OP] New Member
    2012 Black Double Cab Tundra 4x4
    Forgive my novice questions as I'm new to the truck world.
    I bought a 2012 Tundra with 117k miles which had a 2 1/2" leveling kit already installed. The black shocks appear to be the originals and I'd like to upgrade the suspension. Rear shocks I'm assuming I can just swap out no problem. What about the front? Is there a anything I need to do different to make up for the extra height of the leveling kit or do I just replace the front as if it were stock.
    Also, what brand/model shocks does everyone recommend? I see Bilstein 5100 mentioned quite a bit.
    Thank you.
    joseph_womack likes this.
  2. Aug 26, 2022 at 9:25 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Lots of options. low end $ 5100s, 6112s. mid level $OME, Dobinsons, Toytec lifts, Eibach Pro truck 2. The mid levels you can get fully assembled, so easy to just swap in the new parts. Toytec and Eibach are 0-2.5 lift, adjustable on the truck, think that is still true for the older Pre 2014 tundras. For the $, hard to beat the Eibach setup at about a grand for assembled adjustable coil overs and matching rear shocks.
    But there are many great options, much depends on your budget and intended use. Tons of info in the suspension forum about different setups, builds, pics, etc.
  3. Aug 26, 2022 at 10:04 AM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    If you're looking to keep it leveled then you'll need a taller shock than stock offers... the above mentioned brands are all good options.
    I've had the 5100s on my truck, switched out the fronts for Eibach Stage 1 (for more lift), but now I'm switching the fronts out to bilstein 6112s for the bigger shock body and better off road handling vs the Eibach stage 2.
    What's your budget? What're you looing for? (leveled? lifted?) What do you use your truck for? (only paved roads? dirt roads? aggressive washboard and whoops?)
  4. Sep 5, 2022 at 3:18 PM
    DGC64
    DGC64 New Member
    2018 double cab 4x4 limited
    Looking for suspension help for my 2018 tundra limited 4x4 double cab. It has the stock bilstein 5100s with 31" K02's.
    I've only had this truck for 6 months, but have owned older Tundras. I love Tundra trucks too much not to drive bc of a failed back surgery.. I'm looking for the best ride possible on & off road. I do feel every bump and it wears on me after awhile. Prolly don't want to lift it , it's fine to me where it's at.. thx for any input.
  5. Sep 5, 2022 at 8:45 PM
    joseph_womack
    Joe
    Louisiana
    I'd try and go with a reservoir shock, maybe something like the Fox 2.0's, I can't quite tell you what to go with, but try posting either a main thread asking for help, or give the boys at shock surplus a call, they're good guys and can help steer you in the right direction
  6. Sep 6, 2022 at 11:22 AM
    DGC64
    DGC64 New Member
    Ya I was thinking Fox shocks but b4 kicking out the money I wd rather speak to someone with experience. Thx for the response.
  7. Sep 6, 2022 at 11:24 AM
    joseph_womack
    Joe
    Louisiana
    That or also @memario1214 could answer any question you have
    also Hugo over at Toytec is a great resource for all things lifts
