Dimensions of non lifted Toyota/advice?
Discussion in '1st Gen Tundras (2000-2006)' started by Sethsquatch, Aug 24, 2022.
  1. Aug 24, 2022 at 3:55 PM
    Sethsquatch
    Sethsquatch [OP] New Member
    Seth
    2004 Toyota Tundra Double Cab, 35's
    Hey guys and gals! First post. Brand new 1st gen owner.
    Long story short, I was under the gun and had to buy a truck over the weekend. This one looked clean, one owner, drove great, everything worked.
    Got underneath and saw fabtech coil overs for the lift, no worries, I can replace down the road.
    Later on I see there's actually a goofy 4 inch tall extension bolted on top of the knuckle. I have never seen something like that before and it sketches me out.
    So I am going to try to replace it with something more sturdy, but I love the look and height of the truck, so I'm trying to determine the actual amount of lift I have. Maybe center of wheel dimension to the underside of the fender?
    If anyone with a stock SR5 4wd could help out, thanks in advance!
    YardBird likes this.
  2. Aug 24, 2022 at 4:29 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
  3. Aug 24, 2022 at 5:16 PM
    Sethsquatch
    Seth
  4. Aug 24, 2022 at 6:48 PM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    Love the color. :101010:
    Sethsquatch[OP] likes this.
  5. Aug 24, 2022 at 10:11 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    if it has a bigger lift.. which it appears so if its got extensions on the knuckles.. theres no going back to stock without some frame repairs. 90% sure the frames are cut for driveshaft clearance if its a dropbracket lift
    as for something more beefy? im not sure if anyone makes taller spindles like they do for the new trucks.
    Hi06silver and Sethsquatch[OP] like this.
  6. Aug 24, 2022 at 10:17 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Need more pics of suspension components just so we know what all is going on as well just to go along with what @empty_lord said.
  7. Aug 25, 2022 at 5:06 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
  8. Aug 25, 2022 at 3:29 PM
    Sethsquatch
    Seth
    This is exactly what I'm going to do. Tuff country has longer spindles (knuckles?) that they will sell me apart from their kit for $980
    Worth it to make it safer I think. Then Icon has some long coil overs specifically for 5-6 inches of lift, which I'll probably do a little down the road when I can recover from this mess. My local mechanic quoted me $600 to swap the knuckles (spindles?) and install new ball joints, new brakes I'm ordering and new wheel bearings, because why not?
    YardBird and des2mtn[QUOTED] like this.
  9. Aug 25, 2022 at 7:58 PM
    NickB_01TRD
    KY
    Is that a stock spindle with that uh "ball joint lift kit" on it? Almost looks stock but has that weird deal bolted to it
    Hi06silver likes this.
  10. Aug 25, 2022 at 8:13 PM
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    The new tuff country spindles come with new wheel bearings. Also make sure the send you the spacer I had them make for millng the drivers side spindle down too far where the ABS sensor goes into the hub. They weren't aware and made hundreds like this. If you don't have that you'll likely fuck up the sensor. Not cheap....ask me how I know. Did t get a response when I told them I was pretty sure that's the reason mine now activates randomly after the swap. Dialog went dead. If you have any more questions pm me we can talk. Also, there's another guy, I think from a Facebook tundra page, that had the same lift I believe he was able to make everything work with something other than icons. If you're interested I can contact him for more info.
    des2mtn likes this.
  11. Aug 26, 2022 at 8:04 AM
    Sethsquatch
    Seth
    Yes exactly, apparently something they did 20 years ago as a cheap quick lift....
  12. Aug 26, 2022 at 8:17 PM
    Wahayes
    Will
    2017 tundra limited *sold*
    o_O:help: w t f is that haha
