Bilstein 5100 rear install issue! Super confused!
Discussion in 'Suspension' started by TENTUN14, Aug 22, 2022.
  1. Aug 22, 2022 at 10:01 PM
    TENTUN14
    TENTUN14 [OP] New Member
    2014 Silver Sky SR5 4x4 5.7 i-Force
    Diamondback Tonneau Diamondback Ladder Rack THULE roof Racks Tekonsha P3 Brake controller Plasti-Dip emblems and Wheels
    Installed the rear 5100’s on Friday, took a 4 mile test drive, ran well, drove 40 miles today and heard a loose clanging sound. I thought it was the ladders on my roof rack, but turns out the drivers side shock somehow came loose! I am at a loss. it seems that the nut on the top side is secure, the washers are in the correct order, bushings in the right spot, but something just gave way. Thoughts? Manufacture defect maybe? Something I totally noobed? I’ve installed shocks before, an really took my time trying to get this one right the first time, and felt pretty confident that I did.
    YardBird likes this.
  2. Aug 22, 2022 at 10:05 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Sure looks like that lower washer in the pic goes under the frame. Nut/top washer/bushing/frame/bushing/lower washer.
    EDIT: I was wrong about the number of washers on those - but two washers have smaller dia holes per side. Looks now to me like the washers are in wrong order.
  3. Aug 22, 2022 at 10:14 PM
    mountaingroan
    mountaingroan New Member
    Frank
    North Idaho
    2020 SR5 DC VooDoo 4WD Bench!
    Yep, installed incorrectly...
    BlueCrushSC16 and YardBird like this.
  4. Aug 22, 2022 at 10:16 PM
  5. Aug 23, 2022 at 4:55 AM
    TENTUN14
    I followed the diagram.
  6. Aug 23, 2022 at 5:13 AM
    timsp8
    NY
    Try to re-tighten to spec and use a little bit of blue loctite and do another test drive. Maybe it wasn’t torqued correctly the first time?
  7. Aug 23, 2022 at 5:19 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Looks like it's the wrong shock length.
  8. Aug 23, 2022 at 6:09 AM
    TENTUN14
    Could this be remedied by adding a riser block between the leaf spring and axle?
  9. Aug 23, 2022 at 6:09 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
  10. Aug 23, 2022 at 6:11 AM
    TENTUN14
    I can also easily just slide down the boot away from the top end….. not sure if that should be the case…
  11. Aug 23, 2022 at 6:22 AM
    BlueCrushSC16
    Charleston, SC
    Oh. You have the silver barrel in the wrong position. It should be under the frame mounting ear.
  12. Aug 23, 2022 at 6:54 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    When I got my 5100s I did not have to purchase any additional mounting hardware and everything fit accordingly
  13. Aug 23, 2022 at 7:38 AM
    TENTUN14
    I believe I did that, I am wondering if the new washers are the wrong size, allowing the silver barrel to slide up past them? Maybe I need to use hardware from the original shock prior to this install?
    mountaingroan likes this.
  14. Aug 23, 2022 at 7:52 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    If the old hardware was in decent shape, yes.
    Also in the future take a few pics of whatever you are taking apart for reference in putting it back together..
    My 5160s look like the @BlueCrushSC16 pic..
    B3CA39E9-96E7-45A9-A781-847D665C690B_zps_c93fc8c20fc99152630be2df033ca44b709c45d3.jpg
    https://youtu.be/RhRCxyxLOgg?t=494
    BlueCrushSC16 likes this.
  15. Aug 23, 2022 at 7:56 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    You put the wrong washer at the bottom
  16. Aug 23, 2022 at 7:56 AM
    TENTUN14
    The install video done by Overland Tundras shows them using the OEM washers and hardware.
    Sierradevil likes this.
  17. Aug 23, 2022 at 7:58 AM
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    IIRC, from the bottom up: flat washer > rubber > cup washer > barrel ]mount[ cup washer > rubber > flat washer
    1lowlife likes this.
  18. Aug 23, 2022 at 8:00 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    The shock shaft went through the bottom washer and the rubber bushing, now the right size washer is stopping it going all the way through…
  19. Aug 23, 2022 at 9:35 AM
    mountaingroan
    Frank
    North Idaho
    ^^^This...
  20. Aug 23, 2022 at 10:09 AM
    TENTUN14
    These are the pictures I took of the old shocks before taking them off. Only difference I see is on the old shocks, there is no metal washer between the lower bushing and the receiver cup.
  21. Aug 23, 2022 at 10:11 AM
    TENTUN14
    Also, I can just pull down the boot, which seems weird. I’m not seeing anything that should be stopping the shock from traveling up further than it should.
  22. Aug 23, 2022 at 10:14 AM
    C.I.
    Cesar Pedrin
    Cabo, Mx
    I highly recommend that you test fit the washers and bushings OFF the truck, the spacer CAN'T go past the first upper flat washer
  23. Aug 23, 2022 at 10:16 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Your bottom 2 washers are installed reverse
  24. Aug 23, 2022 at 10:24 AM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
  25. Aug 23, 2022 at 10:27 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    The washer with the smallest diameter hole is always on the bottom then rubber bushing, what’s stopping your shock going all the way through is the washer that you need on the bottom.
    BlueCrushSC16 and BroTun13 like this.
  26. Aug 23, 2022 at 11:14 AM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    Yep, all mine came with was the nut.:thumbsup:
  27. Aug 23, 2022 at 1:49 PM
    TENTUN14
    Thanks for all of your responses! I really appreciate the help!
  28. Aug 23, 2022 at 3:35 PM
    1lowlife and Sierradevil like this.
  29. Aug 23, 2022 at 3:42 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Did the shock break??let go on the inside??
  30. Aug 23, 2022 at 4:07 PM
    Rivulose
    Rivulose New Member
    I ran into this after my install and after noticing I fixed the one side in the pouring rain and made it home without the other side popping and jacked it up and fixed it.
    I followed the instructions provided but something was wrong. Can't exactly remember but switch around the washers.
    The retaining ring attached to the actually shock assembly near the top is resting inside the bushing and held up on something. The diameter on the bottom washer is wrong. Just swap em around and you'll be good.
