Coil Pack Spring Fell Into Cylinder
Discussion in '1st Gen Tundras (2000-2006)' started by 67Camaro, Aug 21, 2022.
  1. Aug 21, 2022 at 10:53 AM
    67Camaro
    67Camaro [OP] New Member
    Keaton
    Tennessee
    2018 Toyota Tundra SR5
    2006 Tundra, V8 engine. A friend was replacing spark plugs and dropped a "spring" from one of the coil packs into the cylinder. I want to make an attempt to get the spring out before he has it hauled to a mechanic. Anyone have experience with this? I have a magnet on a stick and a long reach expanding claw cable. I don't know the spring material. Hoping it is not stainless or some other non-ferrous type. Thanks for any advice!
  2. Aug 21, 2022 at 11:32 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Magnet, homemade paperclip hook, HP sprayer off a compressor (with goggles on). I'm sure you can get that out.
    ATV25 likes this.
  3. Aug 21, 2022 at 11:49 AM
    weadjust
    weadjust New Member
    Tupelo, MS
    2006 Tundra Limited DC
    I would try a shop vac with smaller hose duct taped to the larger shop vac hose. Stick the hose in spark plug hole and seal the gap around the hose and spark plug hole with a rag or something and see if you can get it.
    ATV25 likes this.
  4. Aug 21, 2022 at 12:47 PM
    Fairly sure it's a steel spring. Just pop the spark plug out, run magnet on a stick down the hole. Mine has a pivot head about 3" up like this, I'd angle it slightly for wider sweep.
    FirstGenVol likes this.
  5. Aug 21, 2022 at 1:02 PM
    Retired...finally
    Before you go hog wild, get a cheap endoscope from Amazon and look to see where it is.
    dbittle and NickB_01TRD like this.
