ECM communication failure
Discussion in '2.5 Gen Tundras (2014-2021)' started by Bigozzy, Aug 17, 2022.
  1. Aug 17, 2022 at 3:59 PM
    Bigozzy
    Bigozzy [OP] New Member
    I had a water in fuel issues in truck which caused misfires and eventually limp mode. Issue was dealt with and truck runs great now but almost complete dash is lit up with lights. Used my obd reader and discovered a ecm communication failure code but it wouldnt clear it or reset .Left my battery cable off all night and still wouldnt reset . Before water trouble, truck never had any issues or codes. Dealer wants me to bring it in again and he says the water issue had nothing to do with the ecm troubles. I dont think he right because i had no issues before the water . Any tech on here that can help ? Thanks
  2. Aug 18, 2022 at 9:18 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    Does the truck seem to run fine? Did it specify exactly which ECU it has lost communication with? You say ECM but sometimes that is used as a generic term.
    Have you checked every fuse in the truck. ECUs that don't have power cant communicate.
    Any chance of wiring damage to the CAN lines between ECUS? From rodents or some other event?
    What was the code you pulled exactly?
    HulkSmurf14 likes this.
  3. Aug 18, 2022 at 5:47 PM
    Bigozzy
    The truck does run fine and I’ll get the codes tomorrow…thanks
  4. Aug 18, 2022 at 5:49 PM
    Welcome from NY.
    Do you have a aftermarket remote starter?
  5. Aug 19, 2022 at 11:31 AM
    Bigozzy
    34033866-0B58-48DF-8943-4211B06F9ABE.jpg No remote start ..truck is stock.. theses are the codes
  6. Aug 21, 2022 at 6:35 AM
    Bigozzy
    got it fixed now...did a zero point calibration and worked great... thanks for the replies
