  1. Aug 19, 2022 at 2:16 PM
    Rangergillikin
    Rangergillikin New Member
    Alabama
    2021 magnetic grey TRD Pro Crew Max.
    TracRac bed rack, Retrax bedcover, Anytime forward facing camera, Rago dash mounting plate, changed all lights to LED with 1200lumen reverse light, added LED above tag reverse light, rear bumper step, Go Rhino step sides, CCM Cat Security Shield, tool mounts on bed rails, added tie down pad eye on bed rails.
    Not all done in one day but I did a lot of easy mods this month and a few others that I never posted. Matter of fact I have never posted anything, other than a few questions and comments, but I have gotten a lot of good ideas from all the mods everyone else has posted. Love this forum. Anyway here are a few things that I have done to my 21 TRD PRO.
    EyeCatcher Tailgate Insert , Amazon. Tag light back up light from Headlight Revolution. Bed step from Sparks.
    Door sill protector decals, and radio decals from www.tvdvinyldeacals.com
    Bedside inlays from www.tufskinz.com
    Chrome delete from www.ajtdesign-LLC.com , Dash mounting plate from C6412237-7B9C-4671-BCE8-D1B713BF6EF0.jpg
    AVS ventshades
    ABS sensor covers, ebay
    Changed out Toyota bed rails cleats and replaced with Moebulb V-ring tie down anchors and T-slot nuts off Amazon and made some tool holders for the rails. Changed out ever light except headlights with LED and added the 1200 lumin backup LED from Headlight revolution
    Also added Desert does it seat jackers, went over truck with a clay bar and put on two coats of wax. Chemical guys Jet seal first then their butter wax. When I first bought truck a year and a half ago I added Go Rhino step sides, retrax bedcover and put my old tracrac rack on it. Also installed anytime front camera from Trail Grid pro a few months back. Planning to rattle can bed liner spray or powder coat rack when I get around too it. Also got all glass covered in ceramic tint to cut down on UV. I think that pretty much catches me up on most of the mods that I have done now. Sorry for such a long post.
  2. Aug 19, 2022 at 2:20 PM
    Taco-Spike
    Two Trucks
    Nice work!!
  3. Aug 19, 2022 at 2:29 PM
    Rangergillikin
    Alabama
    Thanks. It’s been fun.
    Taco-Spike[QUOTED] likes this.
  4. Aug 19, 2022 at 2:33 PM
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    Waiting for the winch for the installation.
  5. Aug 19, 2022 at 2:46 PM
    PermaFrostTRD
    Northern NY
    What are the straps you’re holding the tool to bed rail with?
  6. Aug 19, 2022 at 3:28 PM
    Rangergillikin
    Alabama
    PermaFrostTRD[QUOTED] likes this.
  7. Aug 19, 2022 at 3:32 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Installed air bags with cradles in preparation for my new travel trailer.
    SMTundra, JCBerb, Tony_h and 12 others like this.
  8. Aug 19, 2022 at 4:28 PM
    junior
    junior Member
    Zach
    Santa Cruz, CA
    2016 Tundra TRD Off Road
    Black Rhino Rapid 17" 35x12.5 Mickey Thompson Baja Boss Fox Performance Elite 2.5 DSC at 3" with Coachbuilder 1/4" shim on driver side JBA UCAs Fox Performance Elite 2.5 DSC rear shocks Dobinsons HD Leaf Springs Firestone Airbags + Daystar Cradles Prinsu Cab Rack 2024 Four Wheel Camper Project M Camper Mods: Goal Zero Yeti 4000 house battery 200w solar IceCo fridge Truma Propane Heater
    Rotated my tires after just about 5K miles. Its a workout, these things are heavy!
  9. Aug 19, 2022 at 4:30 PM
    Taco-Spike
    Two Trucks
    Looks like something I could flip in my backyard for a workout
    Johnmatrix and batman900 like this.
  10. Aug 19, 2022 at 4:37 PM
    junior
    junior Member
    Zach
    Santa Cruz, CA
    at like 120lbs Id say so :rofl:
  11. Aug 19, 2022 at 4:38 PM
    Rangergillikin
    Alabama
    What kind and did you install a compressor. Air bags are on my list of future mods.
  12. Aug 19, 2022 at 4:42 PM
    Rangergillikin
    Alabama
    FYI. I just used some 1/4 inch x 2 inch aluminum flat bar to mount the tool holder to the rail to lower them some. Not sure if you can tell by the picture. Attached flat bar to rail with t nut and v ring.
    PermaFrostTRD likes this.
  13. Aug 19, 2022 at 4:49 PM
    CaptRussia253
    Ruslan
    No compressor just routed both lines to the rear. Here’s a link where I got mine.
    TORQUE Air Spring Bag Suspension Kit with Cradle for 2007-2021 Toyota Tundra [up to 5,000 lbs. of Load Leveling Capacity] (Replaces Firestone 2445 Ride-Rite) (TR2445) https://www.amazon.com/dp/B0B787KDV9
  14. Aug 19, 2022 at 5:22 PM
    AZTundra
    Paul
    Phoenix, AZ
    Your brake line extension brackets are swapped. This should be the correct orientation. I don't think it really matters, but wanted to point that out.
  15. Aug 19, 2022 at 8:04 PM
    Bergy24
    Bergy24 New Member
    Can you post some close up pictures of your mount please
  16. Aug 19, 2022 at 8:39 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Hand wax for the Pro today....
    frichco228, Jego, Henry1jg and 20 others like this.
  17. Aug 19, 2022 at 8:54 PM
    NorthShore
    NorthShore New Member
    2014 SR5 TRD Offroad Crewmax
    Took the skid plate off to change the oil the other week. Decided to sand off the rust and paint since I had some leftover supplies from doing the tow hooks. 5 coats of duplicolor matte bronze and 4 coats of matte clear. Just the stock trd offroad skid but looking alot better.
  18. Aug 19, 2022 at 9:25 PM
    Vizsla
    Vizsla 2 = 2.5
    No, they are not. The bracket in the middle of yours will hit the bed and could smash the brake lines if you ever bottom out hard. The ARB middle bracket is shorter to prevent, and also doesn’t need to be as long due to how the axle moves when articulated, need the longer bracket on the point further out because when articulated it drops out further than the center one can. See how the feet on the arrow bracket actually do something on the outer lines that are subject to side loads with the ARB?, and don’t have to bend the snot out of brake lines.:notsure:
    CB12ABDB-1F8C-4483-A453-785294951B1C.jpg 75C39FD5-9D96-4804-8487-B11031364854.jpg
  19. Aug 19, 2022 at 10:08 PM
    Rangergillikin
    Alabama
  20. Aug 20, 2022 at 5:24 AM
    Cthulhu
    Thank you so much for posting this, considering the CB kit doesn’t come with instructions. Makes total sense what you’re saying. Gonna go swap mine around right now.
  21. Aug 20, 2022 at 5:33 AM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    I have this same quick fist rubber clamp to hold my shovel to the molle panel. Highly recommend them.
  22. Aug 20, 2022 at 5:50 AM
    Rangergillikin
    Alabama
    I may upgrade to the Molle panels later. Just wanted something until I get them.
  23. Aug 20, 2022 at 6:04 AM
    RustyShackle323
    Stewart
    NC
    Yep, understand that. Here is my little setup. Not as extreme as some, but it works well for me.
  24. Aug 20, 2022 at 6:28 AM
    joey2018
    joey2018 New Member
    Nope, and we have good taste in color!
  25. Aug 20, 2022 at 7:19 AM
    Yzed608
    Yzed608 New Member
    Wisconsin
    Love these wheels, probably what I'd go with next tire change, to 17's as well. Not a big fan of the fake beadlock look.
    junior[QUOTED] likes this.
  26. Aug 20, 2022 at 7:24 AM
    CaptRussia253
    Ruslan
    Not according to OME. Either way I don’t think it matters haha
    AZTundra[QUOTED] likes this.
  27. Aug 20, 2022 at 7:24 AM
    AZTundra
    Paul
    Phoenix, AZ
    I followed the directions from @coachbuilder for the install on mine, but after looking closer the OP appears to have the OME kit as seen by the non-arrow looking bracket (over the pumpkin) which is flat as shown in the OME kit pictures while the Coachbuilder kit uses a Z shaped bracket.
    Here is a thread where Coachbuilder noted the directions for his kit: https://www.tundras.com/threads/how...brake-line-relocation-kit.73374/#post-2724213
    Post# 11:
    "Thanks for posting, The arrow shaped bracket bolts to the top of pumpkin and will need to remove the bolts on each side of pumpkin before installing this bracket. just as you mentioned the hard lines are tight and will physically bend the hard lines in order the reach the bracket. after you have pulled the hard lines up you'll need to rotate the metal tabs 180 degrees on each side of pumpkin. this will allow the har lines to mount higher than they were originally. after you've done this follow the speed sensor wire up ( just left of pumpkin ) up to the pre filter box on the underside of bed. there is a threaded stud that is holding the speed sensor wire. the Z shaped brake will allow this wire to drop down and back providing addition length. Hope this helps. Let me know if you need pics."
    It looks like you corrected me in that thread also. :facepalm:The OP's is correctly installed. Do you know why the directions are different between the two kits? Thanks for catching my oversight on the OP's post. :bowdown:
    French Avocado and CaptRussia253 like this.
  28. Aug 20, 2022 at 7:26 AM
    AZTundra
    Paul
    Phoenix, AZ
    Yeah, I just noticed that was the OME kit and not the coachbuilder kit. My bad.
    CaptRussia253[QUOTED] likes this.
  29. Aug 20, 2022 at 4:44 PM
    Uturn09
    Uturn09 New Member
    Roscoe
    2017 Grey Tundra SR5 TRD
    None to day....that’s why I’m here.
    Installed a RAS (Roadmaster Active Suspension) Heavy Duty system today to go with my 5160’s previously installed. Drove a mile so not sure of the ride difference yet. I gained 1.25 inches right after install, we Will see if it settles some.
    upload_2022-8-20_19-39-58.jpgA
    Also I adjust my rancho speedometer calibrator…. For like the 5th time. Getting close, last setting was off 2 miles in a 266 mile trip compared to gps. The weird this is the odometer is getting close but the speedo is still of like 2-3 mph.
  30. Aug 20, 2022 at 4:47 PM
    Which adjustment disc did you use? 1.25 sounds like the higher setting. I believe the white one is the smallest and right at 3/4 lift.
