Boat advice
Discussion in 'Towing & Hauling' started by nobodyintexas, Aug 18, 2022.
  1. Aug 18, 2022 at 3:08 PM
    nobodyintexas
    nobodyintexas [OP] What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I have a ‘20 1794 4x4
    harrop blower, sway bar and traction bars, trans cooler
    can/should I tow my new mastercraft x26
    9600lbs loaded on its tandem trailer. Or thereabouts
    Would like to drag it from houston to Austin some time
    y’all be kind as I’m new to towing
  2. Aug 18, 2022 at 3:16 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Isn't your towing capacity either 9200 or 9400 lbs?
  3. Aug 18, 2022 at 3:19 PM
    nobodyintexas
    South of Houston
    Yes. Or thereabouts
    I have access to a 1ton ford
    it rides like it has square tires
    I suspect that will be my tow vehicle
  4. Aug 18, 2022 at 4:35 PM
    Retired...finally
    Pull the drain plug. Lose 400 pounds of ballast and you're golden.
  5. Aug 18, 2022 at 4:36 PM
    AZBoatHauler
    So.Arizona
    I’m shocked if it is really that heavy. I’m towing a 22’ wake boat and am about 6,000-6,500 loaded on trailer.
    FWIW, I see a Tundra towing a X46 all the time at my lake and it doesn’t seem overloaded or struggling.
    ETA the tongue weight on the big wake boats is usually under 10% so they don’t seem to squat nearly as bad as other trailers. A big v8 hanging behind the axles helps.
  6. Aug 18, 2022 at 4:59 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I suspect it will ride better with 10k lbs behind it.
  7. Aug 18, 2022 at 5:02 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    Yeah but his boat is a legit yacht. 26’ I believe. Assuming his tundra is 7200 lb GVWR, a boat GWR of 9600 puts his GCWR at 16800, which is prob 1000lb north of what his truck is rated for. I’m over a bit at times but not that much.
    I might do it until I figured something else out. But I would definitely upgrade brakes and rear suspension.
    @nobodyintexas check your manual for your truck’s code. It’s on the door jamb on the black and white sticker. Then look at your GCWR for what your truck code is. These are listed in the manual. This is the code you’d be lookin for:
  8. Aug 18, 2022 at 5:02 PM
    AZBoatHauler
    So.Arizona
    Just saw the dry weight is 7,000 lbs - you might be over 9k. Damn that’s a big boat. :fistbump:
  9. Aug 18, 2022 at 5:04 PM
    AZBoatHauler
    So.Arizona
    Yup, I was thinking of an X23 which is about 3’ shorter and 2500 lbs lighter…
  10. Aug 18, 2022 at 5:39 PM
    Terndrerrr
    Music City
    6UR-FE
    And an expensive one to risk pulling with a half ton IMO.
  11. Aug 18, 2022 at 5:58 PM
    But do you have a tranny cooler? This is always the question….
    @hagrid
  12. Aug 18, 2022 at 6:29 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Also get a brake controller if you don’t have one. I towed my dump trailer very heavy one time and I could not stop. Very scary and dangerous. Bought a brake controller immediately after.
    nobodyintexas[OP] likes this.
  13. Aug 18, 2022 at 7:45 PM
    AZBoatHauler
    So.Arizona
    99.9% of boat trailers don’t use electric brakes. I’d bet OP’s trailer has surge brakes making a controller useless.
    KNABORES likes this.
  14. Aug 18, 2022 at 7:57 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Ahem...
    Tundra is pulling champion.
    NWPirate, Outbound, Oey12 and 4 others like this.
  15. Aug 19, 2022 at 3:45 AM
    nobodyintexas
    South of Houston
    yup. love it.
    and only to prevent @hagrid from jumping my sh1t.
  16. Aug 19, 2022 at 3:47 AM
    nobodyintexas
    South of Houston
    if your gonna be a bear, be a grizzly bear.
  17. Aug 19, 2022 at 3:56 AM
    nobodyintexas
    South of Houston
    yikes...just found this....I don't think I'll be risking it.
    and it has a 108 gallon gas tank! and all our gear.
    easily approaching 10k lbs
    Cpl_Punishment and Jaypown like this.
  18. Aug 19, 2022 at 4:04 AM
    nobodyintexas
    South of Houston
    just checked...@AZBoatHauler is right...i have surge/hydraulic system....or, it's not electric.
  19. Aug 19, 2022 at 4:19 AM
    Bowzer
    Bowzer New Member
    I'd like to volunteer my services as a guide vehicle to assure you stay safe between Houston and Austin. Of course, this also includes being on board said boat when in the water to assure nothing was damaged during my guide duties...just to assure safety and thoroughness.
    Seriously, you may be pushing your luck a bit here. Especially considering the traffic challenges we have between these fair cities.
  20. Aug 19, 2022 at 4:23 AM
    nobodyintexas
    South of Houston
    I may need you. I reckon we'll have 10 college kids on board + me and my son.
  21. Aug 19, 2022 at 4:45 AM
    Chris996
    Chris996 New Member
    2018 TRD Sport
    None
    You’re going to want to upgrade to an electric over hydraulic system.
    In essence you’ll remove you surge actuator and add an electric pump which is controlled by your electric brake controller.
    It’s a complete game changer when it comes to stopping a heavy load.
    Air bags will also help with rear end squat.
  22. Aug 19, 2022 at 4:50 AM
    ZPhilip
    Philip
    West Chester, PA
    My bad, didn’t know. The P3 also controls electric over hydraulic but I don’t even know what that means.
  23. Aug 19, 2022 at 5:02 AM
    Chris996
    Chris996 New Member
    2018 TRD Sport
    None
    https://www.boattrailerparts.com/Ti...ic-Over-Hydraulic-Kit-Disc-Brakes_p_1275.html
    I’m assuming you have disc brakes of course. If not you’ll need to upgrade.
    Its not inexpensive, but after towing with an electric over hydraulic set up, you’d NEVER go back to a surge.
    You can use your controller to apply as much braking force as you’d like. No more feeling like 9k lbs behind you is pushing you around. You can actually make the trailer slow the truck down if you wanted to.
    The breakaway kit is added insurance if the unthinkable happens.
    I’ve towed a pretty heavy set up all over the Northeast chasing tuna, and the EOH setup has saved my rear in a couple of emergency stop situations.
  24. Aug 19, 2022 at 7:05 AM
    AZBoatHauler
    So.Arizona
    That’s probably with a triple axle trailer but still…
    :benchpress:
  25. Aug 19, 2022 at 7:06 AM
    nobodyintexas
    South of Houston
  26. Aug 19, 2022 at 7:14 AM
    AZBoatHauler
    So.Arizona
    They show the triple axle weighing a whole 5 lbs more than the double…
    :monocle:
    can’t wait to see some pics of the wake/wave.
    Cpl_Punishment likes this.
  27. Aug 19, 2022 at 7:15 AM
    nobodyintexas
    South of Houston
    once this monsoon season passes here in Houston, I'll post.
    AZBoatHauler[QUOTED] likes this.
