2007-2013 Toyota Tundra Transfer Case Actuator motor assembly
Discussion in '2nd Gen Tundras (2007-2013)' started by Pilgrimboy, Aug 18, 2022.
  1. Aug 18, 2022 at 11:36 AM
    Pilgrimboy
    Pilgrimboy [OP] New Member
    Rich
    2008 dark red Tundra
    Looking for a 2007-2013 Toyota Tundra Transfer Case Actuator motor assembly.
    My actuator is junk and i need to do a rebuild on it but the screw heads are rotten. I'm looking for a used unit for parts before I crack mine open. Any help on tracking one down would be greatly appreciated.
    I'm in Massachusetts.
    Thanks in advance,
    Pilgrimboy
  2. Aug 19, 2022 at 5:13 AM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    2007 Tundra CrewMax 4x4 5.7L V8
    Did you try looking at the part at junk yards. I am sure being in Mass/NE all Tundra's are 4x4 so all of them will have the accuator.
    Or look for it on car-part.com. It will give you an idea of the junk yards that have your trucks around your area. So you can go and get it.
    Cruzer likes this.
  3. Aug 19, 2022 at 10:19 AM
    Pilgrimboy
    Rich
    Thank you baraynavab for the response. As you note, I live in the North East and any parts from around here will suffer from the same rot issues I am confronting now. My hope is some kind forum member from a rust free area of the country might help a brother out.
    Thanks again for taking the time to help out. Enjoy the rest of your Summer !
  4. Aug 19, 2022 at 5:11 PM
    baraynavab
    Atlanta
    Okay I thought you said you needed used parts. So you should be able to find used parts from that actuator right?
