Eibach Coils with Bilstein 5100 ride height?
Discussion in '2nd Gen Tundras (2007-2013)' started by Coldrunner, Aug 17, 2022.
  1. Aug 17, 2022 at 12:44 PM
    Coldrunner
    Coldrunner [OP] New Member
    Hampstead, NC
    Just installed Eibach coils with my Bilstein 5100 shocks on the middle setting with 35x12.50 tires. For those who have run this set up before, what is your fender height and how much did this lift your truck?
    I originally had the bilsteins set on the tallest setting but wanted to go for a true 3” of front lift to balance out the rear. Unfortunately, I never owned the truck stock and have no idea how close I am to a 3” lift. The back still sits a little tall (rear suspension: old man emu springs, Ride Rite air bags). Thanks in advance
    COTundra23 and twotrack like this.
  2. Aug 20, 2022 at 6:51 AM
    Coldrunner
    Hampstead, NC
    Any thoughts
  3. Aug 23, 2022 at 12:52 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    When measuring lift height, you need to measure from the center of the wheel (the hub) to the bottom of the fender...
    The Eibach pro truck springs are supposed to lift 0-2", and the 5100's on the middle setting are supposed to lift 1.6" I believe... so with those combined, you might be looking at around 3" of lift, maybe more.
    Here are two links to peoples measurements for stock ride height, again, they measure hub to fender.
    https://www.tundras.com/threads/3rd...ight-measurement-request-hub-to-fender.19016/
    https://www.tundras.com/threads/true-ride-height.18407/#post-428896
    The measurements I believe should be around:
    FP: 21.75"
    FD: 21.5"
    RP: 24.25"
    RD: 24"
  4. Aug 24, 2022 at 11:26 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    looks good. needs smaller wheels.
  5. Aug 25, 2022 at 4:02 AM
    Jjclamdips
    Jjclamdips New Member
    Wichita, Ks
    2008 Limited Double Can 2WD
    Whatever you do don’t jump on the black wheel fad.
    Those wheels look awesome!
    You could color match the door handles and mirror caps to get rid of some of the hideous black.
    PayItOff428 likes this.
  6. Aug 25, 2022 at 5:23 AM
    Tundra3k
    Tundra3k New Member
    Kansas
    2012 Crew Max
    I’m in Wichita too and selling my platinum wheels (no tires) if you’re interested!
  7. Aug 25, 2022 at 8:12 AM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    Fad? Black wheels make any car look better. I don’t have them or necessarily want them but there’s no denying it
    joseph_womack likes this.
  8. Aug 25, 2022 at 8:32 AM
    Tundra3k
    Tundra3k New Member
    Kansas
    2012 Crew Max
    Black wheels look much better IMO
  9. Aug 25, 2022 at 11:58 AM
    Jjclamdips
    Wichita, Ks
    Thanks but already have some.
    Tundra3k[QUOTED] likes this.
