Anyone running 285/75r18 ?
Discussion in 'Wheels & Tires' started by Tundra694, Aug 17, 2022.
  1. Aug 17, 2022 at 10:43 AM
    Tundra694
    Tundra694 [OP] New Member
    AJ
    2021 Tundra Crew Max Trd Off Road
    I’m looking at Goodyear duratracs 285/75r18 for my Tundra with 1.9” lift in front. Anyone running these ? Clearance issues ?
  2. Aug 17, 2022 at 10:49 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    I'm running Cooper discover's in that size and with my 3" lift I only had rubbing on the front bumper. I used 2 sets of bumper shims from coachbuilder and that fixed it. I also have aftermarket UCAs so I couldn't tell you if stock ones would have an issue.
  3. Aug 17, 2022 at 10:52 AM
    Tundra694
    AJ
    I have bumper shims sitting ready to be installed. I’m running +40 wheels as well so the UCA clearance gains me +20mm over stock. Are yours on stock wheels ?
  4. Aug 17, 2022 at 10:53 AM
    AZBoatHauler
    So.Arizona
    how close are you to the cab mount? I'm stuck between sticking with 285/70 18 or bumping up to these next set...
    Tundra694[OP] likes this.
  5. Aug 17, 2022 at 10:55 AM
    Tundra694
    AJ
    that’s what I’m wondering. I see conflicting reports on needing BMC or not.
  6. Aug 17, 2022 at 10:55 AM
    RegGex
    RegGex I noticed you copied my beard
    Oregon
    2021 TRD Pro CM
    I have a very similar setup to @TucsonTundra1794 besides the bumper shims and I just have a slight bit of rubbing at full turn, bumper shims should fix that though. My wheels are +18 methods
  7. Aug 17, 2022 at 10:57 AM
    RegGex
    Oregon
    2021 TRD Pro CM
    I didn’t need any BMC as well (SPC UCA’s helped with that :thumbsup:), only thing I had to do was remove mud flaps
  8. Aug 17, 2022 at 10:58 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Tons of pics and info of folks running that size all over this site. Search 285/75 and you should get a bunch of hits. Works well with the stock +60 and much easier to fit than 35/1250 tires.
    Lose front air flaps, may need bumper shim, may need removal of mud flap and potential to trim wings off stock skid plate if your truck has one. Perfect tires size on a tundra, big and beefy, good ground clearance and less performance impact than 35x1250s.
  9. Aug 17, 2022 at 11:02 AM
    frichco228
    Frank
    Virginia
  10. Aug 17, 2022 at 11:04 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    I'll take some pics at full turn, I am close but not rubbing.
  11. Aug 17, 2022 at 11:14 AM
    biebs96
    PA
    I run this size and they fit perfectly with that size front lift
  12. Aug 17, 2022 at 11:24 AM
    Tundra18overland
    Tundra18overland Traversing the million mile road
    Jesse
    GA
    2018 SR5 CM Expedition Build
    2” lift will clear 285/75/18 all day on factory offset. May have to remove mud flaps like others said, but that should be it.
  13. Aug 17, 2022 at 11:39 AM
    PermaFrostTRD
    Northern NY
    Subbed for pics. Also curious about the +40mm offset wheel, OP. What do you have? :monocle:
    Tundra694[OP] and AZBoatHauler like this.
  14. Aug 17, 2022 at 11:54 AM
    Tundra694
    AJ
    AR201. One of the only close to factory offsets I could find. I didn’t want 1”-2” of tread poking out and screwing the sides of my truck up with stone chips
  15. Aug 17, 2022 at 8:31 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Perfect size for maximizing sidewall and not having to chop up or otherwise modify your truck. I’m running a fully OEM setup except for the tires. All I did was remove the little flaps in front of the front wheels.
  16. Aug 17, 2022 at 8:59 PM
    415hhh
    415hhh New Member
    285/75/18 Toyo OC3… MCM/ADS kit, I did the BMC more for future, no front flaps, factory front bumper. I like the pizza cutter look, no rubs. Great tire size!(came from 295’s)
  17. Aug 17, 2022 at 10:29 PM
    PermaFrostTRD
    Northern NY
    No lift/level?
  18. Aug 18, 2022 at 3:59 AM
    Terndrerrr
    Music City
    6UR-FE
    TRD Fox kit.
    PermaFrostTRD[QUOTED] likes this.
  19. Aug 18, 2022 at 4:29 AM
    Tundra694
    AJ
    Looks good ! Good to know.
  20. Jun 20, 2025 at 5:26 AM
    Indiana28Tundra
    Indiana28Tundra New Member
    2025 Tundra SR5
    Just put on Cooper Rugged Trek 285/75r18 on DX4 Flare wheels (+12). Only rubbing was wheel well liner and a utility knife and 2 zip ties took care of it. Running Bilstein 5100 leveling kit.
