The Cream Pie - A 2005 4wd/LS/5-Speed/SAS Conversion
Discussion in '1st Gen Builds (2000-2006)' started by the_white_shadow, Aug 8, 2019.
  1. Jul 18, 2022 at 9:22 AM
    #271
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I was referring to this pic
  2. Jul 18, 2022 at 9:24 AM
    #272
    the_white_shadow
    the_white_shadow [OP] New Member
    Ah gotcha. The rear is a 2005 chevy 14b that has drum style parking brakes inside the rotors. Kinda a two-in-one thing from the factory.
    Mountun Goat and des2mtn like this.
  3. Jul 18, 2022 at 9:28 AM
    #273
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Oh ok didn't know that. Gotta pic of the rotor?
  4. Jul 18, 2022 at 9:43 AM
    #274
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    It’s just a rotor with a giant hat pretty common concept on heavy(er) truck rear ends.
    des2mtn and snivilous like this.
  5. Jul 18, 2022 at 9:46 AM
    #275
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Tundra is the same way iirc. Actually I think anything with discs before the electronic parking brakes came out are that way.
    the_white_shadow[OP] and des2mtn like this.
  6. Jul 18, 2022 at 10:06 AM
    #276
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Guess I'm not used to seeing e-brake shoes that big
  7. Jul 18, 2022 at 10:14 AM
    #277
    the_white_shadow
    'They really arent that big. Probably 8" in diameter.
  8. Jul 18, 2022 at 10:26 AM
    #278
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Width-wise they look pretty good sized
  9. Jul 19, 2022 at 6:44 AM
    #279
    the_white_shadow
    Thanks Bob.
  10. Jul 19, 2022 at 7:10 AM
    #280
    Kappes03
    Kappes03 New Member
    2014 Tundra 1794 1996 Toyota Hilux Surf
    Dang, nice build. Surprised you didn't just build a bumper haha
    5N0W808 likes this.
  11. Jul 19, 2022 at 7:12 AM
    #281
    the_white_shadow
    It would have probably been faster. I will be making a high clearance prototype rear bumper with the help of Nathan at Trail Toys. Hopefully he will bring another option to the market for the 1st gen tundra guys.
    Cruzer, 5N0W808 and Kappes03[QUOTED] like this.
  12. Jul 19, 2022 at 9:07 PM
    #282
    the_white_shadow
    I had to do some slicing and dicing of the grille guard tubes for it to open and close.
  13. Jul 19, 2022 at 9:08 PM
    #283
    the_white_shadow
    Nah. Just Nathan. He uses my shop to build his stuff.
  14. Jul 21, 2022 at 6:13 AM
    #284
    the_white_shadow
    A pic of the bumper and winch mounted. The weight settled the springs about an inch. It still a little nose high, but i think it will come down some once the springs settle some more.
    Also been working on the bed floor for the 66 C10. This was by far the worst job to do. The entire damn thing bolts together with like 150 nuts/bolts. The wood floor is structural to the truck. It sucked. I couldnt have imagine doing it without a lift. I think it came out pretty good. The floor is oak with two coats of stain and 3 coats of water seal.
  15. Jul 21, 2022 at 6:17 AM
    #285
    easleycrawler
    Travis
    Easley, South Carolina
    2020 Limited DC 4X4 CEMENT
    The tundra turned out great. The bed floor is sweet as well.
    5N0W808 and the_white_shadow[OP] like this.
  16. Jul 21, 2022 at 6:19 AM
    #286
    the_white_shadow
    Thanks. I have a few more things to finish on the Tundra. Its getting tuned tomorrow morning, then rear bumper, camper shell, vinyl floor inside, etc.
  17. Aug 2, 2022 at 9:06 AM
    #287
    the_white_shadow
    Some updates:
    I took the truck to get it tuned last Friday and it really woke it up. The driving manners are much improved as the ecu isnt trying to "learn" as much as it was out of the box. Fuel and timing tables adjusted and its much better now. Should also get improved mpg provided i can keep my foot out of it.
    On the way home i noticed a slight vibration upon deceleration which was the drive shaft being about an inch too short. I knew this gong in, but was hoping it would be an issue. I ordered a new one from tom woods. When i got home i noticed oil all over the underside and tailgate of the truck. Turns out the seal and driveshaft slip yoke were bad and the transfer case leaked fluid everywhere while i was driving. At least its rust proofed now. Hopefully the new seal and slip yoke will fix the problem.
    While i wait on parts, i started mocking up the prototype trail toys high clearance rear bumper. This bumper is meant for 2nd/3rd gen tundras so a little modification is required for ours 1st gen trucks. 1st the width is about 3" too wide per side. 2nd is the way our bumpers mount to the frame. The frame width is 34" on both generation of trucks so that helps. I came up with a new mounting plate that i will have drawn up in CAD and cut out of 3/4" plate. Once i get it mounted, ill start on the wings and cut the bottom of the bed. I plan on also adding a step to the bumper as well.
    Note, the hitch mount is on backwards on this bumper. it was a mistake during assembly for a previous customer. Its the reason im using it for mockup/prototyping. It will still work just fine with some mods to the back side. As you can see i need to trim about 3" off each side so it lines up with the edge of the taillights.
    CAD design of the bumper bracket. It has an integrated d-ring mount.
  18. Aug 10, 2022 at 9:46 AM
    #288
    the_white_shadow
    Updates on the rear bumper. Its fully welded and painted. The plan is for Trail Toys to make a template and possibly offer it for FGT tundra owners. His 2nd gen tundra bumpers have options for single or dual swingouts.
    Welded and Painted
    Edge trim on the bed to clean it up some
    Got some Amazon el cheapo backup lights to fit where the Baja Designs S2 pods were designed to go.
    I plan on controlling the lights with this Switch Pro knockoff.
  19. Aug 10, 2022 at 10:09 AM
    #289
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Got that bumper on my 2016. Shit is tough AF and has not bent with all the drops I’ve landed on it.
  20. Aug 17, 2022 at 6:47 AM
    #290
    DesertRoads
    DesertRoads Telecom Guy
    Utah's West Desert
    2005 DC SR5 V8 4WD LSD & TOW PKG
    LED Lights Galore. Mostly Stock
    Your jack stand on a picnic table bench makes me cringe in hopes it doesn't snap in half. lol. Love the ARB bumper! That's the style I would love to have. The Safari isn't a good look for our 1st Gen's.
  21. Aug 17, 2022 at 7:00 AM
    #291
    the_white_shadow
    LOL. Nah. Its made out of the sturdiest of high quality wood. If it can hold my fat ass up, it can hold up a 200lb bumper.
    Thats the reason i went with the Tacoma ARB. The safari for our trucks gives it that big chin look.
  22. Aug 17, 2022 at 9:21 AM
    #292
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    The amount of work you have done to that truck is mind bottling!!!;). Great stuff and looks amazing. One awesome rig!!:)
  23. Oct 29, 2022 at 8:45 AM
    #293
    Cummins3500
    Logan
    :spending:My bank account starts getting real nervous when I look at this build thread….. this thing is killer
    I need one of those rear bumpers btw
  24. Oct 29, 2022 at 9:40 AM
    #294
    Cruzer
    Cruz
    Sunnyvale, CA
    @the_white_shadow I’m setting up a Rubicon Trail run June 8-11 2023 for capable Tundras. I did the trail already this year so I know for a fact we can squeeze through. Got a buddy from Colorado in a 2.5 gen on 40s, and a 2.5 gen from Utah on 37s that are going. I invited another SASd 1st gen on 40s - he’s a maybe. Would like to extend the invitation to you.
    Would probably camp at the Loon Lake entrance on the 7th and head out the next morning.
    5N0W808 likes this.
  25. Oct 31, 2022 at 8:21 AM
    #295
    the_white_shadow
    Thanks for the invite. Im a maybe as well. Next years offshore schedule may put a damper on my wheeling plans. Ive always wanted to do the Rubicon trail.
    easleycrawler and Cruzer[QUOTED] like this.
  26. Nov 10, 2022 at 8:09 AM
    #296
    the_white_shadow
    I drove it to work today. Does that count? It wont get much harder wheeling than that. I have other shitboxes to beat up.
  27. Nov 25, 2023 at 1:40 PM
    #297
    easleycrawler
    Travis
    Any updates?
    The Black Mamba likes this.
  28. Jun 9, 2025 at 7:29 AM
    #298
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    @Outbound may have shot him
