Mike Sweers Interview - He wanted a Diesel Tundra (and to keep the 5.7 as an option)
Discussion in '3rd Gen Tundras (2022+)' started by borla123, Aug 7, 2022.
  1. Aug 15, 2022 at 6:04 AM
    #241
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    The lie-o-meter in my brother's 5.3 says his best ever fuel economy is 8.5L/100 km but that was on a long downhill stretch of highway.
  2. Aug 15, 2022 at 7:52 AM
    #242
    mass-hole
    mass-hole New Member
    Honestly, I bore scoped my intake valves on my Ecoboost at 100k miles and they were very clean. Barely anything on them. I don't really think its a big deal except for maybe trucks that really get babied and never get hot.
    Allegedly Ford does some trickery with the variable valve timing to let fuel back out of the cylinder to wash the valves.
  3. Aug 15, 2022 at 7:54 AM
    #243
    mass-hole
  4. Aug 15, 2022 at 8:00 AM
    #244
    mass-hole
    I've been saying this the whole time about everyone who thinks a V8 is a better option.
    Yes, it may have been if they had kept the exact same V8 completely unchanged. However, that was never going to happen. Best I can tell is the turbo 6 cylinders are no more of an issue than any of the DoD V8's. Both GM and Ram have issues with their DoD systems.
    We'll see what happens with Ford's system on the 5.0 since its completely different being a DOHC V8.
    borla123[QUOTED][OP] likes this.
  5. Aug 15, 2022 at 8:36 AM
    #245
    borla123
    borla123 [OP] The Pits
    Ontario
    18 Tundra TRD OR - '17 4Runner Torsen Full Time 4wd
    Driver Grip Handle Borla Dual, Line X, ESP Underseat
    I once got 9.9 L/100 with the 5.7 that's about 24 mpg. Similar situation. The trip was about 10 kms. 6 miles.
    Used to live in a valley. Filled up at a gas station at the top. There was no traffic so I put it in D and just let it go all the way home to see what would happen for fun. So 8 cylinders going in D. Got going pretty good if you look at the speedometer.
    LS3 and Cpl_Punishment[QUOTED] like this.
  6. Aug 15, 2022 at 9:20 AM
    #246
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Best I've ever seen is 12.7 but I don't have any long downhills here (at least not without long uphills right before or after).
    LS3 likes this.
  7. Aug 15, 2022 at 9:24 AM
    #247
    Breathing Borla
    AZ
    it is really the same or slower? I havent seen any actual testing at the same time. Seems odd with all that extra power
    they lost me with losing the underseat storage.
  8. Aug 15, 2022 at 9:28 AM
    #248
    borla123
    Ontario
    they lost me on the non-hybrid because of the back seat storage design.
  9. Aug 15, 2022 at 9:39 AM
    #249
    Breathing Borla
    AZ
    referring to the hump? not ideal but not a deal killer for me
  10. Aug 15, 2022 at 9:53 AM
    #250
    borla123
    Ontario
    no - its the frame for the batteries. Absolutely cannot be removed. All pro solutions I have seen are bandaids.
    A piece of plywood is no good. I need a lower floor - the hump sure doesn't help, neither does the smaller cab size and bed size.
    Anyway - bitch and complain I need my truck for utility and space.
    And I won't buy the Ford because I need the truck past the warranty period and I want the full rear open window.
    My son in law's Limited F150 has everything - everything - then this tiny window at the back - I don't get it.
    You wouldn't believe what I have had sticking out of that window. from the inside out and the outside in.
    rant over.
    edit
    @Sweers
    - change the seat design in the back so they fold up along with their supports like in the Gen 2 at least.
  11. Aug 15, 2022 at 10:48 AM
    #251
    mass-hole
    C&D shows the same 1/4 mile time, but 3 mph slower through the traps for the hybrid. It also takes 18 seconds for the hybrid to get to 100mph vs 15.9 for the non hybrid they tested.
    TLFtrucks less scientific testing had the hybrid at .5 seconds slower in the 1/4.
    It seems to get off the line slightly faster but then craps out up top.
    Yeah, yeah, drag racing trucks is dumb, but it definitely seems to indicate the hybrid isn't doing much for anyone. Not in performance, not it mpg's. Personally, I'd rather save the weight, complexity and money since the benefit seems pretty minimal.
  12. Aug 15, 2022 at 11:19 AM
    #252
    Breathing Borla
    AZ
    wow, wasnt aware of that. and agreed, I don't race trucks but stuff that that gives you an idea of real world driving performance, etc.
    I have been fairly out on the hybrid and this just adds to it.
  13. Aug 15, 2022 at 12:26 PM
    #253
    LukeS
    LukeS New Member
    Luke
    Northeast PA
    Army Green Limited TRD OR
    Agreed that posting 0-60 times for trucks is stupid. I'd prefer if C&D and these other places would instead give 50-70 times with max payload or while towing a 7klb trailer to give an idea of takeover or passing power when you meet that slow 18 wheeler on the highway.
    PermaFrostTRD likes this.
  14. Aug 16, 2022 at 1:46 PM
    #254
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    I can tell you hybrid vs non hybrid driving the same stretch of highway the hybrid is noticeably faster passing/ accelerating.
    Also this shows data that the hybrid (with larger tires and lift being a pro) is faster.
  15. Aug 16, 2022 at 2:54 PM
    #255
    mass-hole
    The trd pro tires are the same od just slightly wider and on those light weight bbs wheels. I bet its in the white noise
  16. Aug 16, 2022 at 6:07 PM
    #256
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    TRD Pro tires are 32.6” vs regular Tundra’s getting a 32.5” at least if the diameters are running true (often times tires don’t).
    The 285/65/R18 Falken Wildpeak AT3W on the TRD Pro weighs 50lbs per tire if it’s a P metric:
    https://m.tirerack.com/tires/Spec.jsp?tireMake=Falken&tireModel=WildPeak+A/T3W&partnum=865TR8WPAT3W
    The other choice in that size is a Load E at 61lbs per tire:
    https://m.tirerack.com/tires/tires....R8WPAT3W&vehicleSearch=false&fromCompare1=yes
    Pretty safe bet the TRD Pro is running the P metric 50lbs/tire setup.
    The Falken Wildpeak AT3W-A in 265/60/R20 weighs only 39lbs per tire.
    https://m.tirerack.com/tires/Spec.j...2022&autoModel=Tundra+4x4&autoModClar=CrewMax
    So the TRD Pro is running a tire that is 11lbs heavier per tire, or 28% heavier for a total penalty of 44lbs of extra rotational mass. Assuming wheel weights are identical, which is unlikely. I would be curious to see if the BBS forged 18”s are lighter than the 20” cast wheels on the TRD Off-road package. They might be, but looking at them I’m not convinced weight savings were the main goal; they’re pretty thick, probably very very strong too.
    DexterL likes this.
  17. Aug 16, 2022 at 6:55 PM
    #257
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    If they're anything like the 2.5 gen BBS wheels they are a lot lighter. Something like 5 or 6 lbs lighter than the similar 18" rim.
  18. Aug 16, 2022 at 7:59 PM
    #258
    Coal Dragger
    Kung Fu Dick
    So if that’s the case you’re still looking at a 5-6lb net penalty for the larger tires on the Pro.
  19. Aug 17, 2022 at 8:34 AM
    #259
    mass-hole
    I bet the 20" wheel you got the tire weight for is way heavier. I had 275/60R20's and the combined weight of the oem wheel and tire was 91.5 lbs. I went to 315/70R17's and the combined weight was 93 lbs. OEM 20" wheels are like a ship anchor.
    Either way the weight should matter less at the top end where the hybrid falls on its face. Tire weight would matter at the low end where the truck is accelerating the fastest. The trap speed for the TRD Pro is 3 mph slower, and if you go to the C&D website its time to 100 mph is like 2.5 seconds slower than the non-hybrid. The thing takes a massive dump once its up and moving.
    I guess until they test a Limited hybrid then there is no sense in arguing though.
  20. Aug 17, 2022 at 8:40 AM
    #260
    Silver17
    Northeast
    2017 TRD 4x4 Harrop SC
    You can’t compare the Pro wildpeaks to the specs you see on the website for the usual wildpeak of the same size. They were specifically made for Toyota to come on the new tundras. They have less tread depth and a lighter weight, etc. here is a snippet from an article about it from gearjunkie.com
    “The Tundra TRD Pro runs on 18×8 black forged-aluminum BBS wheels with 33-inch (P285/65R18) Falken Wildpeak all-terrain tires. The tires are specially made for Toyota, so don’t expect the tread depth you’d see on the Wildpeaks you can buy at your local tire shop.
    These special tires are used for fuel efficiency and on-road noise mitigation. You’ll probably want to upgrade them at some point if you plan to actually use the truck off-road.”
  21. Aug 17, 2022 at 9:02 AM
    #261
    Coal Dragger
    Kung Fu Dick
    I am fairly certain they weren’t even testing a full production truck when they tested the TRD Pro.
