Error lights
Discussion in '2nd Gen Tundras (2007-2013)' started by turk, Aug 16, 2022.
  1. Aug 16, 2022 at 4:51 AM
    turk
    turk [OP] New Member
    greg
    millersville pa
    2011 platinum
    Well I filled my tank and and 2 wheel drive lights flashing I believe the check edge lights steady and the any skid controls flashing What is up never had codes before
  2. Aug 16, 2022 at 4:54 AM
    timsp8
    NY
    Check that the fuel cap is tight and clicks.
  3. Aug 16, 2022 at 5:03 AM
    turk
    greg
    millersville pa
    2011 platinum
    I disconnected the battery all night fired it backup lost the codes but now won't idle
  4. Aug 16, 2022 at 5:23 AM
    turk
    greg
    millersville pa
    2011 platinum
    So when you reset the computer by disconnecting the battery does that change the throttle body motor
  5. Aug 16, 2022 at 6:33 AM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    It will have to relearn the idle. There is some kind of procedure for it but I usually just drive it for a bit and it sorts itself out.
  6. Aug 16, 2022 at 7:40 AM
    turk
    greg
    millersville pa
    2011 platinum
    Clean the throttle body Which I know it was already clean because my local dealership said do it Which I knew it was already clean wiped it out purring like a kitten
  7. Aug 17, 2022 at 5:52 AM
    turk
    greg
    millersville pa
    2011 platinum
    Thanks for the help I was on vacation
