  1. Aug 16, 2022 at 5:09 AM
    You and me both. Tired of reaching in the sunglass holder to open/close garage.
    5N0W808[QUOTED] likes this.
  2. Aug 16, 2022 at 6:29 AM
    DesertRoads
    DesertRoads Telecom Guy
    Utah's West Desert
    2005 DC SR5 V8 4WD LSD & TOW PKG
    LED Lights Galore. Mostly Stock
    So adding another fan to the radiator helps keep the engine cooler when hauling a heavy load?
    5N0W808 likes this.
  3. Aug 16, 2022 at 6:49 AM
    I’m more about AC cooling. But I’m sure it wouldn’t hurt with hauling too. I’ll have to do a trip up my mountain and see.
  4. Aug 16, 2022 at 7:14 AM
    DesertRoads
    Utah's West Desert
    Plus high school kids don't care about washing out sponges and end up marbling the finish on our vehicles. It's not their car/truck, why worry about it? Grrrr
  5. Aug 16, 2022 at 2:10 PM
    Ghostly.-
    Ghostly.- Tragic.
    Mitchell
    Montana
  6. Aug 16, 2022 at 2:38 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    I got my parts in to replace LCA and steering rack, and now I just have to wait for a window when I can dig in and get all the repairs done. Might be a couple weeks.
    @shifty` I know you had issues with how your packages were delivered with your suspension, but this might one-up on that.
    The first one is how it arrived, apparently the driver did not understand that the arrows should point up. Then once I lifted it up, you can see why it was on its side.
  7. Aug 16, 2022 at 2:49 PM
    If you have any questions when you do your rack, let me know, I recently did mine, not the most enjoyable experience
  8. Aug 16, 2022 at 2:50 PM
    REESE77
    REESE77 New Member
    Reese
    03' 4x4 v8
    Is this for better cooling? if so post a link to this fan.
    5N0W808 likes this.
  9. Aug 16, 2022 at 2:56 PM
  10. Aug 16, 2022 at 2:57 PM
    REESE77
    REESE77 New Member
    Reese
    03' 4x4 v8
  11. Aug 16, 2022 at 2:58 PM
    Hahah naw, just tested the waters
    des2mtn likes this.
  12. Aug 16, 2022 at 3:01 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
  13. Aug 16, 2022 at 3:04 PM
    REESE77
    REESE77 New Member
    Reese
    03' 4x4 v8
  14. Aug 16, 2022 at 3:06 PM
    des2mtn
    SW
    Tonto cover
    Hard mount that bitch. You're going with the white man's 12" too?
  15. Aug 16, 2022 at 3:07 PM
    REESE77
    REESE77 New Member
    Reese
    03' 4x4 v8
  16. Aug 16, 2022 at 3:09 PM
    des2mtn
    SW
    Tonto cover
  17. Aug 16, 2022 at 3:13 PM
    Putting aside they look comparable, I think the price is justified since @FrenchToasty fan is the “tornado” version, so it must be better, right? o_O
  18. Aug 16, 2022 at 3:18 PM
    des2mtn
    SW
    Tonto cover
    Sounds like something the exhaust man would tell you.
  19. Aug 16, 2022 at 3:26 PM
    Holy shit. Yeah, that looks about like what FedEx did to my 130A alternator from RockAuto. Are you missing anything from your box?
    BTW, that looks like packing fail than anything. My suspension f-up recently was purely warehouse/packaging fail.
    That said, who'd you order it from?
  20. Aug 16, 2022 at 4:26 PM
    I have another derale fan on my garage as an exhaust that runs off my solar bank, it’s been running 12hrs a day for almost 3 years now. Often with voltages below 11. They seem to be pretty quality
    RUSTYNUTS, 5N0W808, NUDRAT and 2 others like this.
  21. Aug 16, 2022 at 5:26 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    more product that won't come out of the can. :annoyed:
    I scheduled a woolwax treatment this year.
  22. Aug 16, 2022 at 10:08 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Did you do before/after height measurements?
    Kinda got me interested.
    Flex-a-lite makes some that are reusable.
    I still need to wire my A/C fan too.
    RUSTYNUTS, des2mtn and 5N0W808 like this.
  23. Aug 16, 2022 at 10:15 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    I saw that pic. Looks nice.
    You should go back to a stock grill and send me that one.
    Makes me miss @Darkness tho.
    alb1k and 5N0W808[QUOTED] like this.
  24. Aug 17, 2022 at 12:07 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Only difference I see is you've got bigger wheels and a bumper. Thought you were gonna slam that shit snow kitty....:rofl:
    bmf4069, 5N0W808[QUOTED] and alb1k like this.
  25. Aug 17, 2022 at 4:28 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Two days and ~ 40 miles after replacing my fuel pump (Denso) I've started throwing a P0031 code (O2 sensor). Coincidence? Probably. I can't see any correlation between the two. Has anyone else seen this or similar anomalies after a fuel pump change?
  26. Aug 17, 2022 at 5:43 AM
    Could just be coincidence, never personally had it happen on any of my vehicles. But I'd swap both O2 on driver's side just to be safe.
    If your fuel pressure was a hair low before, maybe it was masking an issue with the O2 sensor?
  27. Aug 17, 2022 at 5:56 AM
    w666
    Maryland
    Yeah, I already ordered them both. I replaced the rears earlier this year when I did exhaust work. The fronts were inevitable...although I've been procrastinating since they're such a bitch to wrestle out of there. Still an odd coincidence. I won't obsess about it unless it persists after I install the new sensors.
  28. Aug 17, 2022 at 6:10 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    The fronts weren't that bad on crackie.
    shifty` likes this.
  29. Aug 17, 2022 at 6:15 AM
    that reminds me, I probably need to swap out my air filter during next OC.
    Tundra2[QUOTED] likes this.
  30. Aug 17, 2022 at 8:07 AM
    w666
    Maryland
    Do you still have that 130 amp alternator for sale?
