  1. Aug 15, 2022 at 6:36 AM
    #8821
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Depends on what you are using for paint.
    Latex - you’re best off using an airless and running the paint full mix. Honestly, I wouldn’t spray latex any other way.
  2. Aug 15, 2022 at 6:38 AM
    #8822
    RainMan_PNW
    Casey
    Clark County, WA
    bought and then put together an IKEA bed frame for our incoming exchange student…
  3. Aug 15, 2022 at 3:20 PM
    #8823
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    Installed a new dishwasher. My plan was for someone else to install a new dishwasher. I paid $190 for removal and haul away of the old one and installation of the new one. My wife called mid morning and said it won't fit. It's about 1/2 inch from going in all the way.
    So I left work early, we're on day one of a week long audit so it's not the best time to leave early.
    Get home and pull the new one out. It was hitting a curled up piece of linenoleum. Cut that bitch out and bam.
  4. Aug 15, 2022 at 5:34 PM
    #8824
    Bergy24
    Bergy24 New Member
    I guess I’ll be replacing a washer as soon as we find one we like and that’s available. Pretty sure the main drum bearing is toast in the Samsung front load we’ve had for 15 years. I guess it paid for itself. I hate appliance shopping. Never know if you’re buying a lemon or not.
  5. Aug 15, 2022 at 5:37 PM
    #8825
    Took the new ceiling fan back down, added the receiver for the remote, reconnected wiring, re-hung it.
  6. Aug 15, 2022 at 5:53 PM
    #8826
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    Finishing up a tile job for a friend of mine.
    Grout the walls tomorrow.
  7. Aug 15, 2022 at 6:14 PM
    #8827
    AZTundra
    Paul
    Phoenix, AZ
    I need to pull down my living room ceiling fan that was installed about a year ago. Remote worked fine for about a month then no longer worked. Batteries are fine and I'm positive the dip switches are in the correct position. That fan isn't connected to a light switch and is always hot so our fan has been going non-stop at the same speed for a year...the only thing I can think of is that the remote receiver wiring somehow came disconnected or it just failed.
  8. Aug 15, 2022 at 6:22 PM
    #8828
    Ckatz53
    Ckatz53 Newish
    MD
    www.fouroneodetailing.com
    Cut that drum out and make a fire pit out of it! I hate "finishing" stages so I haven't fully stripped the paint...but I plan on turning it into R2D2 at some point. This thing gets HOT.
  9. Aug 15, 2022 at 6:26 PM
    #8829
    I would just get a new one. No dip switches on this one
    Universal Ceiling Fan Remote... https://www.amazon.com/dp/B07WBYT5H9?ref=ppx_pop_mob_ap_share
  10. Aug 15, 2022 at 8:15 PM
    #8830
    JMB
    Chesapeake, VA
    Classic redneck. My oldest daughter has been using a dryer drum for a fire pit for years. She doesn't weld, so the legs are four cinder blocks.
  11. Aug 15, 2022 at 8:18 PM
    #8831
    Ckatz53
    Ckatz53 Newish
    MD
    Can take the redneck out the country...but never the country out of the redneck. May live in suburban MD but I was born and raised in the good ol' WV.
    TaquitoBandito, JMB[QUOTED] and Mater like this.
  12. Aug 16, 2022 at 5:54 AM
    #8832
    RainMan_PNW
    Casey
    Clark County, WA
    TWSS
  13. Aug 16, 2022 at 10:38 AM
    #8833
    Ckatz53
    Ckatz53 Newish
    MD
    Wife liked the natural look of the frames so no stain. Just 2 coats of poly and finished setup. Turned out solid.
    RainMan_PNW, WVI, drobb and 6 others like this.
  14. Aug 16, 2022 at 1:39 PM
    #8834
    Drywall is up
  15. Aug 16, 2022 at 4:23 PM
    #8835
    Ckatz53
    Ckatz53 Newish
    MD
    Hung the yak up finally. Have to adjust the straps with some paracord on the underside but it fits where I wanted it.
    RainMan_PNW, WVI, drobb and 5 others like this.
  16. Aug 16, 2022 at 4:36 PM
    #8836
    Quite the sticker collection
    TaquitoBandito likes this.
  17. Aug 16, 2022 at 4:37 PM
    #8837
    Ckatz53
    Ckatz53 Newish
    MD
    Thanks, half of em are from the previous owner. Ive been adding on over time. The wall doubles as a rock climbing wall whenever I feel like putting the cleats back up.
  18. Aug 16, 2022 at 5:28 PM
    #8838
    Tundar the Barbarian
    Tundar the Barbarian New Member
    2020 MGM TRD OffRoad
    Speakers, amp, subs, floorboard lights...and the little step thing under the bumper
    PXL_20220817_002309135.jpg PXL_20220816_223529702.jpgGot 3 275 gal containers to daisy-chain off my crawl space sump output...the one I have, filled up in one night of rain! They'll all fit under the deck, and water the plants without touching our well supply. Also, sanded, tacked, and second coat on the wall bed materials.
  19. Aug 16, 2022 at 6:05 PM
    #8839
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Finished a couple showers since the last time I posted. Started my first herringbone pattern today. What a PIA. C09CC6F1-2E36-44DC-8E91-C8F2A67D6CAF.jpg 494B2C94-0A21-4835-AB32-A4B3E77136C6.jpg
  20. Aug 16, 2022 at 6:07 PM
    #8840
    Ckatz53
    Ckatz53 Newish
    MD
    Do you do this professionally or hobby? Our second full bath is old and my wife keeps nagging me to update it. I want to turn it into something like the center photo but retain the bathtub functionality. I'm a DIY'er so I just wing it 95% of the time...turns out decent for the most part lol.
    BlueRibbon4x4[QUOTED] and 1UPPER like this.
  21. Aug 16, 2022 at 6:09 PM
    #8841
    BlueRibbon4x4
    Geno
    Awesome. It’s my profession, bathrooms and kitchens. I specialize in bath tile. A new tub with new tile walls is definitely something you can tackle if you’re a good DIYer.
  22. Aug 16, 2022 at 6:12 PM
    #8842
    Ckatz53
    Ckatz53 Newish
    MD
    Awesome. The more I do, the more I feel like I should have gone into a trade. Too late now! I enjoy making stuff...most of the time from scratch. One day I'll give it a whirl....add it to the list of 1 million other things I need to do around here. Any excuse to buy new tools.
    JMB, Fotnot, 1UPPER and 1 other person like this.
  23. Aug 16, 2022 at 6:13 PM
    #8843
    BlueRibbon4x4
    Geno
    I hear ya!
  24. Aug 16, 2022 at 6:14 PM
    #8844
    Yes please
    BlueRibbon4x4[QUOTED] likes this.
  25. Aug 16, 2022 at 6:15 PM
    #8845
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Finally got around to finishing our kitchen remodel. Remove our old granite tops and installed white level 5 Quartz countertops, installed a pot filler, gas cooktop, vent hood, under cabinet leds and a white honed Chevron marble tile. I did the tile myself and my wife loves it.
    Before:
    After:
  26. Aug 16, 2022 at 6:16 PM
    #8846
    SwitchThrottle
    2021 Barcelona CrewMax
    Not a home improvement per se, but that's $850 in lumber that will become 2 2'x6' tables with a hidden drawer for the church.
  27. Aug 16, 2022 at 6:16 PM
    #8847
    BlueRibbon4x4
    Geno
    That’s a big one. 4’ x 9’ x 9’ ceiling.
    T-Rex266[QUOTED] likes this.
  28. Aug 16, 2022 at 6:30 PM
    #8848
    Looks great.
    Happy Wife Happy Life.
    1UPPER[QUOTED] likes this.
  29. Aug 16, 2022 at 6:32 PM
    #8849
    Kdogg77
    Kdogg77 If it ain't broke, it will be...
    Ken
    Central Cali
    2017 Tundra Crewmax
    6" RC suspension lift, 18" Pro Comp wheels, 35x12.5x18 tires, RC front/rear bumpers, RC Grill insert, Spider No Drill Roof Rack, Lighting by RC and Cali Raised. Interior mods include AJT Designs, Pioneer, and Rockford Fosgate.
    This is almost the exact design we are looking for in our home. How far are you willing to travel? Need to meet up again soon in Hungry Valley.shower.jpg
  30. Aug 16, 2022 at 6:38 PM
    #8850
    BlueRibbon4x4
    Geno
    Sorry man, I don’t travel at all, actually. I work for a contractor, and he keeps me 100% busy in my city. Out of curiosity, where are you located?
