Charging Diode for AGM batteries
Discussion in '2.5 Gen Tundras (2014-2021)' started by agrestic1, Aug 13, 2022.
  1. Aug 13, 2022 at 8:12 AM
    agrestic1
    agrestic1 [OP] New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    Can someone explain how replacing the alternator fuse with a Diode increases the charging voltage ? Thanks
  2. Aug 13, 2022 at 8:24 AM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
  3. Aug 13, 2022 at 8:37 AM
    Vizsla
    Vizsla 2 = 2.5
    The diode lowers the battery voltage signal sent to the alternator voltage regulator, this raises the output of the alternator same amount.
  4. Aug 13, 2022 at 9:35 AM
    agrestic1
    2016 CrewMax
    Got it thanks..
  5. Aug 15, 2022 at 2:01 PM
    Mr. Moto
    Mr. Moto SPIDERMAN, my 2019 Tundra TRD Sport-PRO
    Eastlake, OHio
    2019 Tundra TRD Sport (converted to PRO)
    TRD Pro Shocks (Fox 2.5 internal bypass w/ external reservoirs all around), TRD Pro dual exhaust; Nitto LT285/60R20, TRD off-road skid plates CBI Steel bumper, RC 20,000 lb. winch synthetic rope, BD S1 bush lights, rear floods.
    Looking to buy the Odyssey OBC-12A AGM battery charger from the maker of my ODX-AGM27F battery in my 2019 Tundra. Can anybody tell me if there are any dangers to the instruments and electronics i.e., things on standby power, alarm, etc. if I charge the battery while connected in the truck?
    Thanks.
    Trying to post to a larger audience but not sure how to do that on this site. Please feel free to broadcast to larger audience if you are savvy. Thanks again.
    HulkSmurf14 likes this.
  6. Aug 15, 2022 at 2:43 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    You're good to go while key is left in "on" position...just make sure you're input is less then your output and you'll have nothing to worry about...
  7. Aug 15, 2022 at 5:20 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    I have an optimate charger and charge all the time while connected, charger even came with a neat little cord to connect to the battery easily without using clamps.
    NewImprovedRon and HulkSmurf14 like this.
  8. Aug 15, 2022 at 5:38 PM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    ^^ This.
