DIFF DROP AFTER INSTALLING LEVEL KIT..
Discussion in '1st Gen Tundras (2000-2006)' started by TurdFerguson, Aug 15, 2022.
  1. Aug 15, 2022 at 10:33 AM
    No, mine is bone stock. The only change which made it slightly worse was going from the worn out Tokicos to the new Bilstein 4600s.
    I mean if I can get the hole in the bottom of my frame patched, I'd reconsider upgrading to a better setup, but for right now, I don't want to spend a great deal.
    des2mtn[QUOTED] likes this.
  2. Aug 15, 2022 at 10:46 AM
    He thinks I'm butthurt? :confused:
    Well, best not burst his fragile reality, so I'll go full butthurt and....
  3. Aug 15, 2022 at 10:49 AM
    AZBoatHauler
    So.Arizona
  4. Aug 15, 2022 at 10:53 AM
    TurdFerguson
    TurdFerguson [OP] New Member
    Waynesboro, Virginia
    2000 TUNDRA SR5 AC 4x4 V8
    2002 TUNDRA SR5 AC 4X4 V8 TRD
    Telling me how I should have properly worded what I wanted to ask, shows an extremely high, estrogen fueled level of sensitivity. Are you post-partum, by any chance?
    Aww, sweetie...I see you dried your tears enough to have me blocked from my own post!
  5. Aug 15, 2022 at 10:55 AM
    On the flip side of that, being so sensitive to someone not telling you what you wanted screams "I'm a snowflake"
    That sword cuts both ways.
    EDIT: Actually, not being able to take constructive criticism, or any criticism for that matter, also screams "snowflake". 2 for 2, friend.
    4x4_Angel, Black Wolf and GODZILLA like this.
  6. Aug 15, 2022 at 10:56 AM
    AZBoatHauler
    So.Arizona
  7. Aug 15, 2022 at 11:01 AM
  8. Aug 15, 2022 at 11:03 AM
    AZBoatHauler
    So.Arizona
    That extra $60 is tough to come by.
  9. Aug 15, 2022 at 11:06 AM
    But OP's kit "ain't exactly cheap", so you must be joking if you think anyone can afford that outrageous cost to compensate for their tiny dick. I mean, look at the price! How would you possibly afford that AND a diff drop. Tiny dick is one thing, but tiny dick and broke from buying best of the best top of the line lifts to compensate is just a bad idea. You're just picking on his kit because you're an elitist douchebag who can't read.
  10. Aug 15, 2022 at 11:14 AM
    AZBoatHauler
    So.Arizona
    If only that were the case - I’d finally have something nicer than my $700 6112 setup. Thankfully I did read about what to avoid before dropping my hard earned $.
  11. Aug 15, 2022 at 11:20 AM
    Courtesy, manners, decorum. All dead I guess.
  12. Aug 15, 2022 at 11:40 AM
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    Kids, Kids... and douchebags, huddle up!!
    The front diff is supported at 3 locations. Popular diff drops only add spacers to the front. Now remember back to your middle school Geometry days: The CV axles, for the sake of easiness, we'll say sit 1/3rd the way between the mounting points. This means that the CV's themselves are only dropped 1/3rd the thickness of the spacers you installed. This also means that the companion flange on the front diff has changed angles and is now pointing more upwards to the transfer case. Ideally, the faces of the companion flanges for the transfer case and front diff should be parallel. If you change the angles you will most likely add vibration to your rig.
    My 2 cents,
    4x4_Angel, abcinv, 5N0W808 and 6 others like this.
  13. Aug 15, 2022 at 12:56 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
  14. Aug 15, 2022 at 1:26 PM
    REESE77
    REESE77 New Member
    Reese
    03' 4x4 v8
    Maybe this is what you're looking for. As far as I've seen, they are all 1" spacers. not very hard to find this information online. I posted a question similar to yours a while back and got no clear answers, it happens. nobody is trying to offend you, they're just dropping whatever input they can. its a forum. if you want clear answers, call any of these companies that make the product, or at least do research.
    4x4_Angel and 5N0W808 like this.
  15. Aug 15, 2022 at 1:31 PM
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
  16. Aug 15, 2022 at 2:17 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Well that's terrifying.
    * saves for later use *
  17. Aug 15, 2022 at 5:01 PM
    869D49D3-5341-4C8D-8073-0035CF43FE3E.jpg Did I miss the party?
  18. Aug 15, 2022 at 6:18 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Baby's first lift kit
    Tundra2, 5N0W808, shifty` and 4 others like this.
  19. Aug 15, 2022 at 6:23 PM
    Don't melt any snowflakes, bro. :rofl:
  20. Nov 10, 2022 at 2:10 PM
    #50
    Sunnier
    Sunny
    San Diego, CA
  21. Nov 10, 2022 at 2:14 PM
    #51
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    o_O you ok over there? Kind of snappy.
  22. Nov 10, 2022 at 2:16 PM
    #52
    4x4_Angel
    Bree
    Funky Town, Texas
    And I'm pretty sure this answered the question :)
  23. Nov 10, 2022 at 2:16 PM
    #53
    4x4_Angel
    Bree
    Funky Town, Texas
    And another answered:)
  24. Nov 10, 2022 at 2:17 PM
    #54
    4x4_Angel
    Bree
    Funky Town, Texas
    GODZILLA[QUOTED] likes this.
  25. Nov 10, 2022 at 2:23 PM
    #55
    4x4_Angel
    Bree
    Funky Town, Texas
    :rofl: I couldn't even read this with a straight face
  26. Nov 10, 2022 at 3:19 PM
    #56
    :hattip:
