Cruzer's Re-Build for the Rubicon
Discussion in '2.5 Gen Builds (2014-2021)' started by Cruzer, Dec 8, 2020.
  1. Jun 29, 2022 at 12:28 PM
    #811
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    Oh! Clever!
    In the stock location will these limit your up travel by bottoming out the shock due to the length of the shock body?
  2. Jun 29, 2022 at 2:48 PM
    #812
    Cruzer
    Cruzer [OP] Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Yes, it could. The top of the shock body, on a stem top, sits about 3/4" below the mount. Whereas the center of the eyelet, for this adapter, sits about 1-5/8". So you lose just under an inch.
  3. Jun 30, 2022 at 5:48 AM
    #813
    starfish.pat
    starfish.pat New Member
    Patrick
    2008 Grey SR5 TRD Double Cab Short Bed
    It's funny what lengths we have to go through to mess with the rear suspension without breaking the bank. I bought OME rear shocks and I believe they're rated for around 2-4 inches of lift...but 4 inches being the max where you're concerned about it maxing out. I wanted a little more in the back for lift. Went up another inch with adjustable shackles and could not find a proper rear shock extender for OME shocks to save my life. I tried to find custom thread extensions, but nothing was the same thread pattern as OME. So I looked in to the bottom shock mount extensions. I found a lot for other car makes, but none for toyota. So after lots of measurements and Google searches, I decided to try these out:
    https://www.amazon.com/dp/B004PL87JQ
    They ended up working great with a little modification. I had to trim them up to fit between the shock mounts and I had to trim back the weld on the interior of the shock mount by about 1/8 of an inch. Aside from the custom trimming...it's a perfect fit and I've had no issues whatsoever. So if you're looking for a shock extension and don't want to pay a ton on new shocks, look no further!
    Cruzer[OP] likes this.
  4. Jun 30, 2022 at 7:34 AM
    #814
    Cruzer
    Cruz
    Sunnyvale, CA
    I already have something similar on my truck:
    These provided a 2" extension that I needed BUT because it creates a double joint (double pivot point) it makes the most annoying clinking sound, as it taps on the lower shock mount, that drives me crazy :annoyed: $170 for a shock isn't too bad plus my rear shocks were toasted anyways and wouldn't have been worth it to rebuild.
    starfish.pat likes this.
  5. Jun 30, 2022 at 8:30 PM
    #815
    starfish.pat
    Patrick
    Did you have to rig that up to fit or do they have a Toyota Tundra version?
  6. Jun 30, 2022 at 9:07 PM
    #816
    Cruzer
    Cruz
    Sunnyvale, CA
    It’s for a Jeep but it fit right in with no mods.
    Sunnier likes this.
  7. Jul 24, 2022 at 10:07 AM
    #817
    Cruzer
    Cruz
    Sunnyvale, CA
    Found out late this week that I’m going to do the Rubicon again………this coming Wednesday :eek2:
    Frantically fixing things on the truck.
    Still haven’t figured out how to fix the 4Lo issue but gonna try tweaking a bunch more stuff with my HP Tuner and hope something works.
    One of the modifications I’m trying is to increase the Tow/Haul button to allow 3x more air through the throttle body. It works really good in 4Hi but I can’t tell in 4Lo - need an obstacle to test it on.
    :fingerscrossed:
  8. Jul 24, 2022 at 10:41 AM
    #818
    Vizsla
    Vizsla 2 = 2.5
    More than happy to look through your tune file and see if I can find anything wrong with 4LO. There are other limits you can hit with component protection, but that might be tough to figure out.
  9. Jul 24, 2022 at 11:43 AM
    #819
    Cruzer
    Cruz
    Sunnyvale, CA
    DM me your email. I’ll send it later when I’m done working on the truck. Thanks!!
    eccracer104 and FrenchToasty like this.
  10. Jul 24, 2022 at 11:59 AM
    #820
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    Short notice but those are usually the best trips ! Be safe and have fun. Another write up in the future? The one earlier this year was epic.
  11. Jul 24, 2022 at 1:55 PM
    #821
    Cruzer
    Cruz
    Sunnyvale, CA
    If anything it’ll be me conquering the obstacles this time around
    :fingerscrossed:
    TG705, SAGE63, ATV25[QUOTED] and 2 others like this.
  12. Jul 24, 2022 at 1:56 PM
    #822
    eccracer104
    San Diego, CA
    You got them this time :benchpress:
    ATV25 likes this.
  13. Jul 24, 2022 at 5:47 PM
    #823
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    2011 super white Tundra double cab
    King 2.5 coilovers, King 3.0 rear bypasses, Camburg uniball UCAs, RCI skid plates, Camburg front bumper, warn zeon 10s platinum winch, monster hook reaper shackles, Rigid Industries lights, SDHQ sliders, SDHQ A-pillar brackets, SPOD, 17" Method standard wheels, 315/70/17 Cooper STT tires, Morimoto XB LED headlights, Boon dock steel rear bumper, Durobumps front bumpstops, Deaver U748 with MCM shackles
    If your 4wd acts up on Soup Bowl again just give it a good ol' 6k neutral drop and it'll climb right up! Just make sure to get it on film:rofl:
  14. Jul 24, 2022 at 6:23 PM
    #824
    ATV25
    Terry
    Redding, CA
    2019 Platinum
    I hope that smoke from the Oak Fire doesn't impact your trip. It's actually hanging on the east side of the valley clear up where I live.
  15. Jul 27, 2022 at 2:32 AM
    #825
    Cruzer
    Cruz
    Sunnyvale, CA
    Well this sucks! According to the schedule Jeeper’s Jamboree is supposed to start tomorrow but they closed the Rubicon Trail starting today. Fortunately, a buddy of mine found out online so at least I didn’t waste any gas. I guess the rematch will just have to wait :(
  16. Jul 27, 2022 at 3:10 AM
    #826
    ATV25
    Terry
    Redding, CA
    2019 Platinum
    BUMMER
  17. Jul 27, 2022 at 4:57 AM
    #827
    Sunnier
    Sunny
    San Diego, CA
    Well, damn. But yeah, woulda been worse to find out when you got there.
    Did you get yer truck all dialed in?
  18. Jul 27, 2022 at 7:26 AM
    #828
    Cruzer
    Cruz
    Sunnyvale, CA
    Fixed my front diff. Not sure about getting it dialed in though cuz the only way to find out is when I hit the trail.... which I will be doing :D New plan is to head down to Shaver Lake area and hit Coyote, Strawberry, and Mirror Lakes. If there's time maybe squeeze in Brewer Lake. Will save Swamp Lake for another time.
    reywcms, SAGE63, eccracer104 and 2 others like this.
  19. Jul 27, 2022 at 7:51 AM
    #829
    SAGE63
    San Diego County
    That sucks...so... what us your backup plan
  20. Aug 12, 2022 at 12:10 PM
    #830
    Cruzer
    Cruz
    Sunnyvale, CA
    Got my replacement ARB locker seals.
    Now to spend my weekend messing around with the rear axle :( Would much rather be doing other things - I have places to drink and drinks to see o_O
    Just hoping I don't mess up any of the axle seals in the process :fingerscrossed:
    SAGE63, TG705, ATV25 and 3 others like this.
  21. Aug 13, 2022 at 1:41 PM
    #831
    Cruzer
    Cruz
    Sunnyvale, CA
    So I started the process to replace the O-rings in my rear locker today. I've never taken out the 3rd member before so I've been watching youtube videos. I see a lot of unnecessary steps people take so here are some of the shortcuts that I've done so far.
    1. You're supposed to disconnect and take apart the brake line near the rotor so that you can pull the axle out. You first have to slide out this tab, then loosen the hardline.
    Fuck that! I'm lazy and want to do the least amount of work possible to get this job done. I just cut the retainer to open up the hole that it's in and slid out the brake line intact. Now I don't have to bleed the brakes :D
    2. You're also supposed to remove the parking brake. Which requires taking off the calipers and rotor. Fuuuuuuck that. I just removed the bolt from the brake line retaining clip, giving me just enough slack to pull the axle out of the carrier.
    Used a bungee cord to keep in place and stop it from rotating.
    Got the diff out, now to figure out how to actually replace the o-rings :monocle: currently reading the ARB install guide. Looks like if I remove the bearing caps and remove the carrier from the housing it should just slide out. Will find out tomorrow... got drinks to see.
  22. Aug 13, 2022 at 2:51 PM
    #832
    Vizsla
    Vizsla 2 = 2.5
    Yes the carrier will pry/pull out when the caps are removed. Mark the caps so they go back the same way, and there will be shims on each side so be careful to not mix them up. I looked through your tune but did not see anything obvious. Think it might be something with transmission torque limits, mine definitely works. Going to do a copy and paste into one of my tunes, but been waiting on a part for awhile, and of course had kick it back to have a new one made due to manufacturing error. Let me know if you figure it out though so I don’t waste time.
  23. Aug 13, 2022 at 3:26 PM
    #833
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    You could send him your tune and he could copy the stock fueling stuff over too. Same but opposite :D
  24. Aug 13, 2022 at 5:21 PM
    #834
    Vizsla
    Vizsla 2 = 2.5
    :facepalm:Copying all his tune changes into a tune that works with torque tables modified to confirm or eliminate. 2018+ requires different values than previous years, so no reverse copy and paste, and I’m not tuning anyones truck because not a tuner. If it works, he has a starting point.
  25. Aug 14, 2022 at 6:26 PM
    #835
    Cruzer
    Cruz
    Sunnyvale, CA
    So I removed the bearing caps...actually I removed one, the bearing cap with the copper hose running through it was just loosely hanging.
    I then picked up the carrier, thing is heavy AF and super slippery, moved it to the side so that it sat on top of the pinion, which gave me just enough room to remove the collar. Couldn't move it far because of the copper hose - was too lazy to remove the hose.
    The collar slides off the carrier exposing the 2 seals.
    Picked out the seal from its grooves and put in the new, lubricated, seals. Sliding the collar back onto the carrier was tricky because the seal would not stay in the groove. Make sure to grow out your fingernails so that you can use them to keep the seals seated as you slide the collar back on. Drop the carrier back in and tighten up the bolts.
    I did a test fit and spun the pinion to make sure the ring gear was not catching onto the copper hose. This transmission lift really came in handy as it allowed me to line up the 3rd member to the bolt holes, making it easy to quickly slide it back on after I applied RTV.
  26. Aug 14, 2022 at 6:54 PM
    #836
    Vizsla
    Vizsla 2 = 2.5
    Nice! No fun wrestling that heavy mf’er in and out. My gear guy won’t do it, bring the removed one to him, same with the front. Have the same transmission jack, can’t imagine doing it without.
  27. Aug 14, 2022 at 7:09 PM
    #837
    Sunnier
    Sunny
    San Diego, CA
    <adds to list>
  28. Aug 29, 2022 at 6:57 AM
    #838
    Cruzer
    Cruz
    Sunnyvale, CA
    Was surfing the web doing transfer case research when I stumbled upon a 200 series Land Cruiser front diff.
    The LC has the same size front diff as the Tundra but if you look closely it does not have an ADD attached to the extension tube.
    :monocle:
    Pivoted my surfing and found this
    This is the intermediate shaft that runs inside the LC diff tube. The difference between the Tundra is that ours is shorter because the ADD connects it to the stub shaft. (Lengthwise: Tundra intermediate shaft + Tundra stub shaft + Shift collar = LC intermediate shaft)
    If you’ve been following along on my build you’ll know that the stub shaft can easily break because it’s not made of solid steel but rather some form of powdered metal that is melted together. Below is a picture of the shift collar and stub shaft and where it breaks.
    So I ordered one. Only $160. If this fits then my front end will be engaged all the time, which means both front wheels rotate at the same rate (turning or not) and my front drive shaft will always spin but will not be in 4wd because the TC will not be engaged. I plan to remove the shift collar and leave the ADD in place. This way when I put the truck in 4wd, the ADD will do its thing tricking the ECU that it slid the collar.
    My front tires may not like this solution but we’ll see. Maybe I can get a second diff tube to install before any wheeling trips. Would it be a hassle? Of course, but being less worried about snapping a stub shaft on the trail is money in the bank.
    :fingerscrossed:
    @pandapro
  29. Aug 29, 2022 at 8:10 AM
    #839
    Punisher29073
    Punisher29073 New Member
    White Knoll, SC
    2019 Tundra TRD Pro
    Clearance lights, Light bar in front bumper, Ditch lights, CB Radio, AGM Battery, SLEE Sliders,
    Will this also put added pressure on steering components?
  30. Aug 29, 2022 at 8:38 AM
    #840
    Cruzer
    Cruz
    Sunnyvale, CA
    I know that a lot of the Taco guys do a similar mod where they use the intermediate shaft from an FJ Cruiser and I haven't heard of them complaining about their steering components being an issue. The Tundra steering rack is much stronger than a Taco's so we will see, only time will tell. I have chromoly inner tie rods and CB outers and have not had any issues wheeling hard with those so I'm not worried about them.
    As I was typing I realized that I could just take out the passenger CV axle, take apart a shitty aftermarket CV axle, and stick only the inner housing into the diff tube (like @joonbug). This will allow the front wheels to rotate independently of each other :yes::D I can then, easily, swap out CV axles when I go wheeling :yes::yes::yes::yes::yes:
    Thanks for making me think about this :D
