Ask the Detailer
Discussion in 'Detailing' started by T-Rex266, Nov 13, 2017.
  1. Aug 1, 2022 at 4:50 PM
    #4801
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    [​IMG] [​IMG]
    I'm having this "ghosting" issue with pretty much every badge.
    I got myself a little drill adapted polisher kit (3" diameter) -since I wasn't doing entire panels- meguiars water spot remover, meguiars polishing compound and even turtle wax rubbing compound. Was able to get the outline from being so noticeable at a few feet with the spot remover and polish, however, still there. Then I tried the rubbing compound (by hand) and TBH... not a lot of change other than the hazing of the clearcoat, only did one letter (A) with little pressure.
    It's driving me nuts and would really like to make use of my newly added kit before considering a pro or any more aggressive method.
    Any help is appreciated .
  2. Aug 1, 2022 at 4:52 PM
    #4802
    Ckatz53
    Ckatz53 Newish
    MD
    www.fouroneodetailing.com
    Ghosting almost always requires a respray. Unfortunately the color underneath the badges is the true vehicle's color. Everything else has been "bleached" by the sun and lightly faded. You never notice it until you've had a vehicle and tried to take the badges off. You can diminish with wetsanding/cutting/polishing...but it will almost always remain.
    Edit: was hard to see the pics they're so small. Are you referring to the literal outlining (looks white) of the letters? And not real ghosting of the paint that existed below the emblems themselves?
    ToyoMafia likes this.
  3. Aug 1, 2022 at 4:58 PM
    #4803
    C.I.
    Cesar Pedrin
    Cabo, Mx
    I re-uploaded! sorry about that. Yes, the outline, dunno if thats ghosting or not :D
  4. Aug 1, 2022 at 5:54 PM
    #4804
    Ckatz53
    Ckatz53 Newish
    MD
    Looks like it may be adhesive. Have you tried a 3m adhesive remover eraser wheel followed up with Goo Gone?
  5. Aug 1, 2022 at 6:04 PM
    #4805
    C.I.
    Cesar Pedrin
    Cabo, Mx
    No eraser wheel. For removing the badges I used CarPro TarX & Adhesive remover + plastic razor, made short work of the glue. This seems different, feels like mineral deposits; Fingernails can still catch on the thicker spots after all the buffing.
  6. Aug 1, 2022 at 6:09 PM
    #4806
    Ckatz53
    Ckatz53 Newish
    MD
    Were they the factory chrome badges that are just 3m'd on? That sounds like they've rubbed into the paint and scratched but that wouldn't make sense with something 3m'd on as it's still slightly raised. I've seen something similar with an overlay badge before that was poorly placed over the OEM badge but not to that extent where it's literally the entire badge outlined...was only a small section.
  7. Aug 1, 2022 at 6:10 PM
    #4807
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    I have been using optimum tire dressing for a year. Now there is lots of buildup....almost like grease on the tire. Any recommendations on what to use to loosen this? I tried a brush on a drill and simple green....doesn't do a thing.
  8. Aug 1, 2022 at 6:25 PM
    #4808
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    A good degreaser works. Even an APC (all purpose cleaner) like optimum power clean. I use it straight (not diluted) and have cleaned off tires caked with tire dressings. Do it multiple times until your foam from agitating is basically white and not having any browning color to it.
    T-Rex266[OP] likes this.
  9. Aug 1, 2022 at 7:44 PM
    #4809
    Ace96
    Ace96 New Member
    Western KY
    2021 Voodoo Blue TRD Sport
    I would not recommend turtle wax rubbing compound and a drill attachment. That is a recipe for burning through clear coat.
  10. Aug 1, 2022 at 8:00 PM
    #4810
    C.I.
    Cesar Pedrin
    Cabo, Mx
    Why on earth would I do that? :confused:
  11. Aug 2, 2022 at 12:01 PM
    #4811
    Hanzo
    Hanzo New Member
    So I’m pretty sure the haze on my windows is from a previous owner smoking in the car. I tried the glass specific microfiber and cleaner but it’s still hazey. Any other suggestions?
  12. Aug 2, 2022 at 1:36 PM
    #4812
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    I've mentioned this before, I'm not a detailer, just follow this thread.
    About a teaspoon of corn starch in 1/2 cup of water (ish) should be cloudy and settles quickly. Dip a cloth in that mess and 'polish' your windows. Then use a regular cleaner. Don't drip the cornstarch stuff on upholstery or it dries white. I've never had this cause any problems. But if someone here is concerned with scratching window tint please chine in. Also, I used to smoke. That film is a bear.
    Ckatz53 likes this.
  13. Aug 2, 2022 at 1:40 PM
    #4813
    Ckatz53
    Ckatz53 Newish
    MD
    Heavy smokers film I'll use diluted APC, dry, then use glass cleaner. That film can be tough to get through with just an alcohol glass cleaner.
  14. Aug 2, 2022 at 5:46 PM
    #4814
    Azblue
    The Dirty T ( ^_^)_且
    16CMTXED and ToyoMafia like this.
  15. Aug 2, 2022 at 5:59 PM
    #4815
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    I hate glass.
  16. Aug 2, 2022 at 6:53 PM
    #4816
    DBWA
    DBWA New Member
    Dave
    2022 Tundra TRD Limited 6.5' Bed
    What’s the recommendation when it comes to ceramic coating over PPF (Xpel). Is it worth it? Are there drawbacks?
  17. Aug 2, 2022 at 6:54 PM
    #4817
    ToyoMafia
    Magic carpet.
    I have not heard any drawbacks. Coatings work very well over PPF.
  18. Aug 2, 2022 at 6:55 PM
    #4818
    DBWA
    DBWA New Member
    Dave
    Is the process any different in terms of preparation, application and long term care?
    ToyoMafia[QUOTED] likes this.
  19. Aug 2, 2022 at 6:58 PM
    #4819
    ToyoMafia
    Magic carpet.
    check this out.
    https://youtu.be/7RCgqdGrvrA
    Fotnot, T-Rex266[OP] and DBWA[QUOTED] like this.
  20. Aug 3, 2022 at 6:41 AM
    #4820
    nhw544
    nhw544 Food fight!
    RVA
    2019 Black Tundra 4x4 Sport
    Keep in mind I’m not a detailer, just a regular guy who likes a clean truck.
    I washed my truck on Monday evening. Used some Turtle Wax brand soap that I’m pretty sure has wax in it. I know lots of folks in this thread aren’t fans of TW products, but I had a large container of it and I’m almost done with it. Plus I’m too cheap to throw it out lol. Anyway…wash the truck from roof to wheels, rinse, dry body of truck and dry glass. Then I come back with glass cleaner on all the glass. I use either Invisible Glass or another product that I don’t remember the name of, but it’s also in an aerosol can and was recommended by the guys who installed my new windshield. I use microfiber towels when applying and drying the glass cleaner.
    cartage1 and Ace96[QUOTED] like this.
  21. Aug 3, 2022 at 7:31 AM
    #4821
    C.I.
    Cesar Pedrin
    Cabo, Mx
    I believe that buffing will eventually get rid of it, but man is it taking long.
  22. Aug 4, 2022 at 3:50 PM
    #4822
    briarpatch
    briarpatch New Member
    Optimum Power Clean undiluted. It's the last step I do prior to preparing a tire for a coating. It may take several iterations before they are completely clean
    Fotnot and ToyoMafia like this.
  23. Aug 5, 2022 at 11:44 AM
    #4823
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
    Interesting on CG
    cartage1 likes this.
  24. Aug 5, 2022 at 1:13 PM
    #4824
    Ace96
    Ace96 New Member
    Western KY
    No lies detected. :rofl::rofl::rofl:
  25. Aug 14, 2022 at 10:58 AM
    #4825
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I just used Optima No Rinse for the first time and i'm not sure what i'm doing wrong.
    I wanted to use it as a quick detailer like Merilins Magic Elixir (thats my go to), i diluted ONR down to 16:1 (maybe a little bit stronger, just kinda winged it), and it doesn't really seem to work that well. I'm using a cheap sprayer from Sam's Club, but it was really dificult to wipe away. I'm not sure if I'm doing something wrong, but it was pretty dificult to get it off. I would have to use two towels, one to do a first wipe and another dry one after to try to buff it off.
    Not sure if i have it not diluted enough, or maybe i'm using too much per pannel (about 1.5 sprays per panel).
    Any advice?
  26. Aug 14, 2022 at 4:56 PM
    #4826
    Ckatz53
    Ckatz53 Newish
    MD
    Dilution looks right and I always use two towels for sealants, quick detailers, etc. Spray, spread with one same, try and wipe up majority with that towel, then buff with the second towel.
    Were you in the sun? Hot panels? Also did you dilute with distilled water? ONR can help reduce hard water spotting but it isn't a magic elixir. If your water is hard, it'll cause smearing issues.
  27. Aug 14, 2022 at 6:25 PM
    #4827
    ToyoMafia
    Magic carpet.
    Have a bottle of ONR never touched it. Did throw down a coat of Hydro2 on the Tesla today. BC6215C7-6D6E-4519-B4E0-9469584AD9C0.jpg
  28. Aug 15, 2022 at 5:59 AM
    #4828
    Danimal86
    Daniel
    Sacramento, CA
    I used it first thing in the morning, so it was in the sun but it was pretty cool out still.
    We dont have really hard water, but i only had about a cup of distilled water left, so i used that and topped it off with bottled water.
    Yesterday i used Merlins Magic Elixir (carpro Ech2o and Reset) on the wifes lexus and it just comes off so easily and seems like it did a better job of cleaning and wiping away.
    Maybe i'll dump this batch and get some more distilled water and mix a fresh batch.
  29. Aug 15, 2022 at 6:00 AM
    #4829
    ToyoMafia
    Magic carpet.
    @War Machine may be able to chime in on this as well. I know he is a ONR paid sponsor
  30. Aug 15, 2022 at 6:17 AM
    #4830
    War Machine
    War Machine SSEM # 5 3MW
    Which one do you have, the blue one or green one? The green one has the issues you’re experiencing, but I’ve never had that problem with the blue.
    The 16:1 ratio is correct. I do always use distilled water in my mixtures, but I don’t think using regular water would cause your problem.
