Can’t get new timing belt on
Discussion in '1st Gen Tundras (2000-2006)' started by Canatct, Aug 13, 2022.
  1. Aug 13, 2022 at 2:16 PM
    Canatct
    Canatct [OP] New Member
    2005 tundra
    Hi folks! New member here and starting off with a question.
    Got a 2005 Tundra dc 4x4 4.7 I bought brand new. 290,000 miles all by me. I bought a Aisin timing belt water pump kit and everything was going smooth until time to install the new timing belt. I have spent the last 3 hrs trying and it will not go on! I’ve installed several Subaru timing belts but this is my first attempt on my Tundra. Is there a trick to getting it on? Even installing it only on the left cam (drivers) it’s still off a tooth at the crank gear. It matches up with the old Toyota oem but has more teeth. I’m at a loss and this is my work truck. Any help would be greatly appreciated.
  2. Aug 13, 2022 at 2:21 PM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    If it does not have the same number of teeth as the belt that came off it sounds like you have the wrong belt. It should have the same number of teeth as the original.
    And, welcome to the forum!!
    YardBird, des2mtn and snivilous like this.
  3. Aug 13, 2022 at 2:36 PM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Where did you get the timing belt kit? The belt says Mitsuboshi on it?
    If you turn the driver's cam one tooth clockwise and the passenger's cam half a tooth clockwise, that might help. That's what I needed to do.
    Jack McCarthy likes this.
  4. Aug 13, 2022 at 2:48 PM
    Canatct
    2005 tundra
    Says Mitsuboshi CD298 on the belt.
    des2mtn likes this.
  5. Aug 13, 2022 at 3:00 PM
    Canatct
    2005 tundra
    I followed AllDatas instructions and got it to TDC + 50° before removing the old belt. Got the new water pump, idler pulley and tensioner pulley on but this belt is getting the best of me. Mine is the VVT version and I don’t have the cam gear tool. Only a 19mm wrench and if I turn it one hair too far clockwise (Looking at it from the front) she springs over. Then of course the 19mm bolt breaks loose trying to go back. I’m gonna wear the factory marks off the belt from handling it if this keeps up.
  6. Aug 14, 2022 at 11:02 AM
    You didn't release the tensioner pulley pin before you installed the belt, did you? IIRC, you install the tensioner, the belt, then release the pin it to put tension on it after.
    I can see how having the pulley tensioned already would cause this issue.
  7. Aug 14, 2022 at 11:05 AM
    PS, I've posted this before and feel like it's the best explanation I've personally seen to do the TB on the 4.7 2UZ-FE, pay attention to the reinstall part. Skip to around 6m20s:
    https://www.youtube.com/watch?v=HPpzLJwoxng
    N84434 and YardBird like this.
  8. Aug 14, 2022 at 11:57 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Trying to get the pin back into the tensioner is harder than trying to get toothpaste back in the tube (don't ask how I know this...).
  9. Aug 14, 2022 at 11:58 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Use a vice. That and rotate the holes to align before squeezing it back in.
    YardBird likes this.
  10. Aug 14, 2022 at 12:05 PM
    w666
    Maryland
    I did try the vise, but even more toothpaste came out!
    Jack McCarthy, Sunnier and YardBird like this.
  11. Aug 14, 2022 at 12:45 PM
    As much as you guys joke around…little surprised the “new belt stretching tool” didn’t come out and play.
    shifty` and YardBird like this.
  12. Aug 14, 2022 at 2:05 PM
    Canatct
    2005 tundra
    I figured it out. Never seen a timing belt that hard to get on. Before removing the belt I went to the T behind the cam gears, which isn’t 50° atdc. What was throwing me was the timing marks on the crank and lh cam gear were dead center and the rh was “off” just a hair. I was trying to get it dead center. Thought about it overnight and realized the belt markings were aligned with the green indents so there was nothing left to do but hold the lh gear and pull the pin. Spun it twice and all is well. I was overthinking it. That was the problem.
    I didn’t even have the tensioner on when installing the belt.
    And I’ve used a big C clamp to compress those tensioners before when I didn’t have a vice. Not on a 4.7 Toyota but other vehicles. Not easy but doable.
    Leo's first and huntertn like this.
  13. Aug 14, 2022 at 2:25 PM
    Glad to hear you worked it out, I was preoccupied the latter half of yesterday so I missed this.
    I do highly recommend watching that video though, just for next time. It might help you see some things you could've done differently, learn for next time. The video was produced in a way I felt I could easily understand and kinda get to know the little tips and quirks involved. Every engine has them.
  14. Aug 14, 2022 at 2:32 PM
    Canatct
    2005 tundra
    I tried to insert a couple pics.
    The rh cam gear needed to go 1mm over to be dead center of the T. The lh was dead center as was the crank mark. Now the cam markings on the belt were lined up with the factory gear marks. When I tried to spin that 1 gear 1mm the belt would jump a tooth. Now when at tdc the mark on the rh gear is still in the “I”, just not dead center.
    By the way, you can turn those cam gears with large oil filter pliers when you don’t have the sst.
  15. Aug 14, 2022 at 2:38 PM
    Bilgepump
    Bilgepump New Member
    '06 Sequoia Limited 4.7L VVT-i 2WD
    All Stock
    https://www.youtube.com/watch?v=Z46cM-Bw1rI&t=267sYes.....use the "T" mark for changing timing belt.....that way the camshafts will not unload and shift on you when removing the old belt.....that Mitsuboshi CD298 is the correct belt....line up the left cam mark then right cam mark on the timing belt with the camshaft timing marks that are pointing to the "T" mark....then draw belt down and around the idler pulley to the crankshaft timing gear and align the marks on the belt with the marks on the timing gear.......the timing mark, threaded hole, and the keyway....the belt will have marks for all three.....at least the Mitsuboshi belts do.....
    Make sure idler pulley is retighten to spec. if you loosen to get belt on....
    When everything is lined up....pull pin on tensioner.....to snug the belt tight
    Here is the best video hands down by a Toyota mechanic on a 4.7L......he uses the "T" mark and loosen the idler pulley for a little slack to get the belt on.
    Watch entire video but especially the 4:20 to 5:20 sec mark....you will see his tip....
    Jack McCarthy and standard like this.
  16. Aug 14, 2022 at 2:51 PM
    Canatct
    2005 tundra
    I finally left the idler pulley loose and tightened it after. Otherwise that belt wasn’t going on.
    Also the old belt had roughly 190,000 on it (yea I know). It really looked good with hardly any stretching. Idler and tensioner pulley felt great. The rubber cap on the tensioner was cracked. I think it could have kept going but will never know. I was working at a Chevy/Subaru dealer at the time so I let the Toyota dealership do it with factory parts.
    N84434 likes this.
  17. Aug 15, 2022 at 11:58 AM
    Bilgepump
    All Stock
    Canatct,
    Did you watch the video ? Hope you found it useful......Good video, huh,...use the info next time.....I have done timing belts and camshaft seals on my 4.7L VVT-i engine.....I am very familiar with the timing marks and where to set them for a timing belt change
    A Toyota mechanic once said that these belts would most likely do 200k.....they have kevlar threads built into them......not that I would let it go that long.....but I can believe your belt lasted 190k....
    shifty` likes this.
  18. Aug 15, 2022 at 4:26 PM
    Canatct
    2005 tundra
    I watched that one and several others before tackling the job. It’s zipped up but still parked awaiting a new radiator scheduled for delivery Wednesday. I started to put the old cracked one fora fire up but I’ll just wait and do it once.
    Thanks for everybody’s help.
    des2mtn, shifty` and YardBird like this.
  19. Aug 15, 2022 at 7:45 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    The belt should slide right on. And you do use the “T” while swapping belts. Like mentioned Cams are in a neutral position.
    Since these are interference engines you may want to slightly spin the crank pulley to make sure there is no interfering.
  20. Aug 15, 2022 at 8:10 PM
    Bilgepump
    All Stock
    Canatct,
    I am confused....did you do the work or the dealer..?
    Your posts above are confusing....
  21. Aug 16, 2022 at 4:04 AM
    Canatct
    2005 tundra
    I used the T. Alldata says go 50° past tdc which is past the T… but I used the T. I did this one.
    I was working at a Chevy/Subaru dealer when the first belt was changed by the Toyota dealer. This belt I replaced at home. That sounds confusing as I read it myself. Sorry.
  22. Aug 16, 2022 at 9:39 AM
    Bilgepump
    All Stock
    As you do these in the future, they get easier and easier....just use the "T" mark when changing belts.....can't go wrong......that way the camshafts will stay where they are and not unload and shift on you....
    After you get the belt on and pull pin on tensioner and get the crankcase timing cover back on .......rotate crank 2 full revolutions to see if everything lines up.....camshaft timing marks with either the "I" or "T" marks as well the "0" mark or white dot on crankcase timing cover......if everything lines up.....you are go to go.....button every thing back up......and pat yourself on the back for a job well done...
    des2mtn and YardBird like this.
  23. Aug 16, 2022 at 10:14 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    tacoguybill likes this.
  24. Aug 16, 2022 at 10:18 AM
    des2mtn
    Shady Grove
    Tonto cover
    N84434 and Tundra2[QUOTED] like this.
  25. Aug 16, 2022 at 10:20 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    OH! Silly me. Didn't realize this was a VVTI...
    My reading comprehension has failed me @TurdF
    shifty` likes this.
  26. Aug 17, 2022 at 9:01 AM
    Canatct
    2005 tundra
    Use the old serpentine belt to hold the fan pulley when installing those 4 hard to get on nuts.
  27. Mar 19, 2023 at 10:52 AM
    tacoguybill
    tacoguybill The Burrito Bandido
    Saaaan Diaaago
    06 DC SR5 4x4 174k, 04 Sequoia SR5 4x4 105k
    This is kinda weird, I saw this video use the T marks on an 08 GX470 and it sprung back on him, he recommended setting it to the I, everything was fine until the cam got bumped and it sprung which is fun! Now I get to worry about it more
