Catalytic Converters
Discussion in '2.5 Gen Tundras (2014-2021)' started by Frank1848, Aug 14, 2022.
  1. Aug 14, 2022 at 10:49 AM
    Frank1848
    Frank1848 [OP] New Member
    2014 Tundra
    So I woke up today to find all my cats had been stolen! Any suggestions on good after market ones and a way to prevent it from happening again?
  2. Aug 14, 2022 at 11:02 AM
    blaserdude
    blaserdude New Member
    Eugene
    2019 Tundra Limited Double Cab
    none
    Just a quick question. Does not the noise made by a sawsall or whatever alert people who may hear?
    BC
  3. Aug 14, 2022 at 11:07 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    most use the near silent band pipe cutter - with a cordless drill for the juice. takes seconds to snap it.
    https://www.youtube.com/watch?v=76TCwEhI-aQ
    TTund16 likes this.
  4. Aug 14, 2022 at 4:57 PM
    Frank1848
    2014 Tundra
    I live in a complex and my spot is to far from my condo to hear anything
  5. Aug 14, 2022 at 5:04 PM
    timsp8
    NY
    HulkSmurf14 likes this.
  6. Aug 14, 2022 at 5:35 PM
  7. Aug 14, 2022 at 5:42 PM
    Njmike13
    Njmike13 New Member
    Hunterdon county, NJ
    2021 PRO Lunar Rock
    Sorry this happened. I hope the thieves die a slow painful death along with anyone they love.
    There are some issues with aftermarket cats throwing codes. Search around for more information before you buy.
  8. Aug 16, 2022 at 7:41 PM
    texmln
    texmln New Member
    I helped my BIL put on Valhalla shields last weekend. They look like they will do the trick. As for aftermarket cats, I had the front driver side honeycomb break apart in my OEM cat after 175k miles and I replaced it with a Walker bolt on set. The tubes line up perfectly and they bolted right up with no problems and no leaks (just make sure you get new tube gaskets too). The Walkers have been working fine for two years/38k miles. No CELs, no problems whatsoever and I didn't even bother to replace the oxygen sensors. At the time the Walker set cost roughly 1/5th of the Toyota OEM cats for one side. A quick look today shows the driver side Walker's at under $400 and the OEMs can be had online for about $1500.
    JohnnyWaffles and HulkSmurf14 like this.
  9. Aug 18, 2022 at 11:05 AM
    Fallingblock
    Fallingblock New Member
    Southern MD
    2017 SR5 DC Tundra
    Nice an affordable aftermarket solution to a frustrating problem
  10. Sep 12, 2022 at 6:47 PM
    Deans 2021
    Deans 2021 New Member
    Thomas
    I just got my aftermarket Cats installed at Toyota. They used the Flow Masters. They have been good so far. No codes and I've towed with it and no issues.
    Bammer likes this.
