Tail lights and plate lights not working !
Discussion in 'Lighting' started by Blackstallion19, Jul 11, 2022.
  1. Jul 11, 2022 at 5:11 PM
    Blackstallion19
    Blackstallion19 [OP] New Member
    2019 pro
    2019 tundra pro. Tail lights and plate lights will not turn on… checked all fuses No recent upgrades or mods to the lighting system .. anyone ran into this issue with a remedy ? Thanks for your time
    Julz2024 likes this.
  2. Jul 12, 2022 at 8:10 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    You checked both fuse box location?
    especially the one under the steering wheel. Fuse TAIL. Pull out completely and visually inspect.
    If you did, then forget i say anything. Might have to take it in since it should be under warranty still.
  3. Jul 13, 2022 at 1:24 AM
    Blackstallion19
    2019 pro
    Update::: So i looked under the dash and found the secondary fuse box.. checked the tail light fuse.. blown .. replaced the fuse. As soon as i turn my switch on it pops the fuse again…. Sounds like i have a short in the wire somewhere which i find very odd considering it’s a Florida truck with zero rust
  4. Jul 13, 2022 at 1:31 AM
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
  5. Jul 13, 2022 at 3:55 AM
    Maybe a short in one of the tail light bulbs? Pull the bulbs and check for any rust or corrosion in the sockets. Common problem since the taillight harnesses are exposed to the elements and moisture gets in them.
    NewImprovedRon likes this.
  6. Jul 13, 2022 at 5:11 AM
    BrandonL812
    Brandon
    Also check your trailer harness plug. Water could’ve gotten in from rain.
  7. Aug 13, 2022 at 8:09 PM
    Jmor6766
    Jmor6766 New Member
    Jon
    SW Colorado
    2014 White Tundra TRD SR5 4.6L
    Definitely check for rodents. This happened to me a few weeks ago. Still unsure if it was marmots camping a week earlier before check engine came on or a large squirrel at my house. They chewed one spot that was a foot taller than anything for it to stand on. My truck sits during the week. They chewed 2 gas lines, seam sealant in multiple places, wire harness sleeves all over the place, and through tail light harness.18002485-C8F3-40FC-96BC-437B7162472F.jpgAF9AEA19-61F6-44C4-AC24-7AA55119555B.jpg037744C8-36A6-4344-9BED-861437162FE0.jpg
    A couple of repaired pictures below. Luckily Toyota had the new filler neck in stock online for quick shipping and other was standard fuel hose. I patched wires above spare tire and re-wire loomed about 8-10 areas where they didn’t chew through wires just the loom.
    A966D094-479D-4709-BE8D-43F6DA3B70FC.jpg A70B19A2-4B17-4117-8B33-10F947AD58C7.jpg
    6F286046-7541-4104-8B4F-A80CDC73262B.jpg 1D322C76-20EB-456F-8041-7FFB1D2F4450.jpg
  8. Dec 27, 2024 at 3:49 PM
    Tundra_King1
    Tundra_King1 New Member
    2018 Tundra 4x4 5.7L Crewmax
    2.5" Level with Bilstein 5100s, 275/70R18 Nitto Ridge Grapplers, and JBA UCAs.
    Any update on the fix? I have a 2018 with the same issue.
  9. Feb 13, 2025 at 7:57 AM
    Jmeyer200
    Jmeyer200 New Member
    Late to the party but just dealt with this problem first hand after failing inspection for the reverse and license plate lights. Checked and all fuses were good. Also found that the plate lights and reverse lights are on the same fuse. Crawled under the rear bumper to check bulbs and/or remove the reverse lights themselves when I found the issue. Both lights were completely unplugged from the wiring harness. No damage and no signs of tampering…just unplugged and hanging there. The harness clip barely reaches the light port and when plugged in, there is a lot of reverse pressure pulling back on the connector. Once it dries out, I’ll tape the hell out of the connection to hopefully prevent this from happening again.
    I would have included pics but it’s raining and I’m not crawling under there again today.
    Wondering how long I’ve been driving around like this??…probably awhile.
