Dealership Oil Change Experience
Discussion in '2.5 Gen Tundras (2014-2021)' started by Chip_Tundra, Mar 19, 2022.
  1. Apr 9, 2022 at 9:18 AM
    When I worked for a Toyota dealership, the maintenance shop wouldn’t let just anyone change oil. You had to be ASE Certified and prove to the service manager you knew how to properly change oil, service a vehicle. In my three years of employment, to my knowledge we had no issues like this at all. Then again, we also didn’t have 10 minute oil changes either.
  2. Apr 9, 2022 at 10:52 AM
    737fixer
    737fixer New Member
    My two free oil changes at 10 and 20K were so overfilled that I had to immediately go home and change oil myself. My thought process was whatever moron filled my oil I couldn't trust if he did the filter or put in proper oil.
  3. Apr 9, 2022 at 11:19 AM
    Solid Snake
    Solid Snake The Anciet of Mu Mu
    West TN
    2006 AC 4x4 V8
    I bought my '06 last summer. Since I didn't know the maintenance history, I took it to a Toyota dealership for an inspection. They assured me they would inspect everything from bumper to bumper. When I picked it up and looked at the paperwork, they simply recommended things based on mileage. They inspected nothing other than the brakes. I had bought new wiper blades two weeks before this, and they recommended new wiper blades. Where I usually park, pine needles and small twigs fall and gather on my wiper blades. When I picked up my truck, the pine needles were still on the wiper blades. They recommended new wipers without even turning them on.
    WILLINH likes this.
  4. Apr 9, 2022 at 12:12 PM
    Abos
    Abos Long live 5.7L V8
    2014 SR5 Crewmax
    They have some good techs and a lot of stupid monkeys. I just got my truck in December and I had them replace the valve cover gasket under warranty. Normally I'd have done it myself but figured screw it, it's under warranty. They replaced it no problem but they forgot to slide the clamps back over two of the coolant lines that run along the valve cover that I know they would have had to replace the gasket.
    I went to the store one night when it was like - 20F out and smoke was billowing out of the engine. Popped the hood and noticed that the line blew off and saw the clamp slid way up on the line. So they attached the line but never put the clamp back.
    Luckily it was a short trip and I know a thing or two about vehicles and was able to put the line back on and slide the clamp into position. I sent the dealer an email with detailed description and pictures and never heard back. So I called and they were just like "oh yeah, I think that must be what happened." They didn't apologize or offer to give me anything. It could have been disastrous if I had hopped on the interstate for a longer drive. I wouldn't have noticed until the coolant light came on or it overheated and it could have cooked the head gasket.
    I have a free oil change but I don't even think I'm going to bother having them do that. All service was done at the dealer for the previous owner and when I took my skid plate off, half of the bolts snapped because they were on too tight.
    Hilarious how they said "this is why we don't like our customers to do maintenence themselves." lol
  5. Apr 9, 2022 at 1:24 PM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
  6. Apr 9, 2022 at 1:45 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Sorry this happened, that is why I have never used the "free" oil changes that have come with my Toyotas.
    Terndrerrr likes this.
  7. Apr 9, 2022 at 2:17 PM
    GatorBodine
    GatorBodine New Member
    I always drain the pan first as well. I guess it wouldn't hurt to loosen up the filter housing first to make sure all should be good, then drain the pan and go back to the filter.
  8. Apr 9, 2022 at 3:55 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Based on previous experiences, I have chosen to skip the dealership oil changes as well. I am the only person who has been under the hood of my truck. Once it is open, my order of operations is
    1. Remove fill cap
    2. Drain oil (doing #1 first makes this step much faster)
    3. Remove skid plate door.
    4. Get disposable filter drain tool out of filter cartridge packaging.
    5. When oil is done draining, close and lock Fumoto valve, and slide catch pan under the filter.
    6. Remove filter cartridge. Throw old cartridge, disposable drain tool, and both O-rings in the trash.
    7. Wipe up inevitable few drops from skid plate & install new cartridge with new, freshly oiled O-rings. DO NOT OVERTIGHTEN.
    8. Pour new oil. While it's draining, reinstall skid plate filter door, and spread a bit of kitty litter if any drops made it onto the driveway.
    9. Pour old oil in empty jugs.
    10. Take to O'Reilly's for recycling.
    OHwendTrd and Ely010606 like this.
  9. Apr 9, 2022 at 6:22 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    The only oil I have to pour in jugs is from the filter. I drain the pan straight in to a jug from the Fumoto. Of course that requires monitoring with an 8 quart capacity.
  10. Apr 9, 2022 at 6:27 PM
    This^^^^^. I had a very pleasant oil change at my dealership yesterday. Not all dealerships suck.
    Wait......you worked at a Yota dealership? What other secrets haven't you told me? Yeah, need to know basis. Ha!
  11. Apr 10, 2022 at 1:31 PM
    Cock-A-Doddle-Do
    Cock-A-Doddle-Do New Member
    Brett
    Cypress, Texas
    2021 TRD Off Road CM -Super White
    This was posted on a Facebook page....just another reason to NOT utilize dealership(s)....and a damn good reason at that!!
  12. Apr 10, 2022 at 2:10 PM
    bfunke
    bfunke Tundra Curmudgeon
    @Tbrandt - that Autozone wrench is POS. Get the Motiv wrench
    Cock-A-Doddle-Do likes this.
  13. Apr 10, 2022 at 2:20 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Since September of 2016 I have bought four (4) new-from-the-dealer Toyotas. Not once did I use their so called "free" oil changes.
    If you take your Tundra to the dealership for engine oil service you would be wise to check everything, including oil in the engine, right there in front of the service area. Now, of course, after you do all that you're not too far away from having just done the engine oil service yourself. Potato....tomato.
  14. Apr 10, 2022 at 2:45 PM
    Cock-A-Doddle-Do
    Brett
    Cypress, Texas
    How you gonna check the torque on ya drain plug, oil filter and don't forget when you are under the truck to check that all the bolts and clips are put back on ya skid plate...if you have one.....Nope 8ll just do my own oil changes!
  15. Apr 10, 2022 at 3:22 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Yup. I'm getting close to 300 engine oil changes that I've done myself since August of 1985.
  16. Aug 13, 2022 at 4:09 PM
    Speedyman WCC
    Speedyman WCC New Member
    Aaron
    2019 Cavalry Tundra TRD
    BN
    I have a 2019 tundra and brought it in to the dealership for the tire rotations as scheduled. The dealership didn't do the first oil change until the truck had 20k miles. I assumed that was normal. At 30k miles I go to do the oil change myself and the oil filter canister is cranked on there, liked they used an impact. The oil looks and smells like burnt dino oil, reddish brown. I looked at the manual and the first change was supposed to be at 10k miles. Shame on me for drinking the Toyota Care Kool-aid, but I trusted the dealership to do what's right. They can keep their free lifetime oil changes. I'm doing it every 5000 miles and using mobile1 0w-30. I hope I don't have excessive engine wear because of the BS 20k initial oil change.
    Sumo91 likes this.
  17. Aug 13, 2022 at 4:18 PM
    Speedyman WCC
    Aaron
    BN
    So I just removed the filter housing prior to the drain plug and it wasn't messy. Undoing the metal plug, there was maybe a half ounce of oil. When I put the clear plastic spigot thing in there, there was maybe 8-16 ounces of oil. I have my truck up on rhino ramps and I used a 5 gallon bucket to catch everything. Zero mess. I had to put the truck in 4hi to get the thing up on the ramps, 2hi and it was shoving the ramps around on my smooth concrete floor.
    Giskk likes this.
  18. Aug 13, 2022 at 4:21 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Ouch!! I'd definitely be speaking to them about a really good extended warranty, and pushing the issue with toyota corporate as well. 20k miles is a long time for an OCI on the factory oil fill.
