Towing Help needed, only 3500lbs
Discussion in 'Towing & Hauling' started by Doug2000, Aug 12, 2022.
  1. Aug 12, 2022 at 8:44 AM
    Doug2000
    Doug2000 [OP] New Member
    London, Ontario, Canada
    2017 Tundra SR5 5.7L DC 4X4
    Hey Guys
    So I’m near 50, I have been towing for 30 years, Sea Doos, tent trailers, small travel trailer, and loaded up landscape trailers. I haven’t had an issue getting a good setup till now.
    I had a 2004 Ford Freestar with a 2004 Fleetwood Redwood @ 3500lbs. I used a Husky round bar WDH. It towed perfect with a WDH except underpowered. 64C860CE-A7D2-490D-8DBA-8DD386F51BDC.jpg
    My 2008 Tacoma towing the 2007 Escape 17B WDH towed fine.
    I traded the 2008 Tacoma for a 2017 4Runner and it towed great with a EazLift WDH. We took that across to LA and back up through the mountains of Colorado no issues at all. I forgot about it at points. 4245573B-E04D-4EAC-8C23-358B4C06D152.jpg
    I’ll post my questions in the next post
  2. Aug 12, 2022 at 8:58 AM
    Doug2000
    02DCF6D7-63C6-499A-BF3A-2629A442610F.jpg 242D1BCC-049A-4F0A-8B5A-DBC981097C61.jpg AA90EE94-52C5-4ED1-A11C-485C90FBE1BA.jpg 445AA7EA-46D2-4B35-A236-FF7E6AA5FAC2.jpg So now we have a 2017 Tundra SR5 with tow package including trans cooler and brake controller, TRD exhaust, TRD Rock Warrior wheels, BFG KO2 tires, and the heritage grill. It’s a beast and pulls all day long. Only issue is it’s thirsty.
    The trailer we custom ordered from British Columbia which is 2800 miles away. It is an 2020 Escape 19. Only available factory direct. We paid $32K CAD which is like $25k USD. Cheap for American customers and lasts 50 years.
    So my issue is I can’t get a good ride while towing it. It bounces lots. These trailers don’t really sway at all. Dry weight is 3150lbs but I came across the CAT scales with closer to 3900lbs loaded. I will add weights in a third post.
    We’re using the Reece Pro Series trunnion style Weight Distribution Hitch that we bought with the trailer. I have tried many different setups with it without success.
  3. Aug 12, 2022 at 9:11 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Can you describe the bounce a bit more? Is it up and down that you feel through the entire truck (porpoising) or is it just the trailer that is bouncing independently?
    Those Escapes tow very nice so something isn't right.
    ColoradoTJ and AZBoatHauler like this.
  4. Aug 12, 2022 at 9:15 AM
    mountainpete
  5. Aug 12, 2022 at 9:19 AM
    Doug2000
    Here are my CAT scale weights. We weren’t heading out on a trip so it is only close to travel weights. Loaded with all normal equipment like linens, pots and pans, cords, one battery in the front box, bikes on the back, and a few barbell plates to simulate some extra gear. For the best part, we often travel light. All 3 tanks are empty which is typically how I roll.
    First weigh is truck only.
    Second weigh is truck and trailer, no bars.
    You can see in my third weigh, the WDH is set to 3 links which on the third sheet is 360 lbs. Just over 10%.
    3FD054A7-C9B5-40EE-B486-DED7C11D5751.jpg B0FAB019-9586-4302-8530-8A6AB8895CD2.jpg
  6. Aug 12, 2022 at 9:25 AM
    Nightshade Tundra
    Nightshade Tundra New Member
    Alex
    2021 Ram 2500 Laramie
    Only thing I can think of is maybe the distribution bars are rated to high for the trailer and it may be pushing upwards between the tongue and the hitch? have you tried taking them off and seeing how it affects the ride?
  7. Aug 12, 2022 at 9:27 AM
    AZBoatHauler
    So.Arizona
    I’m seeing your first tongue weight being 380 lbs and your second being only 240 lbs.
    (Drive + steer weights - truck weight)
    I’d argue 380 might not be enough…
  8. Aug 12, 2022 at 9:28 AM
    18" TRD Off Road Wheels
    Just looking at the pic of your setup, you're sitting pretty level, so I would rule out a WDH not being dialed in properly. Maybe the bars are too heavy for the lighter trailer?
    Beyond that, I'd be looking at tires and suspension. What PSI are you running your tires at? Over inflated tires will ride rough and kick a bunch. Tired shocks could be the culprit as well. How old are they? Any leaking?
  9. Aug 12, 2022 at 9:28 AM
    AZBoatHauler
    So.Arizona
    And you need to add the tongue weight to the trailer weight so that means your trailer really weighs about 3,900 lbs which means 380 lbs = less than 10%.
    mountainpete and Cpl_Punishment like this.
  10. Aug 12, 2022 at 9:31 AM
    Doug2000
    53BCA9F8-1022-4454-9308-CFA5CC25CD14.jpg 6087A2E7-FBE3-4235-BE10-67B3D171D148.jpg
    So the only thing I can really narrow down my problems to is the tires. I have BFG KO2. They are load range C. They are not a heavy duty tire. When I bought them I was careful to make sure the load rating was higher than the original Bridgestone Duelers. The original tires were rated P as in Passenger tires if I recall correctly.
    In the past I had bought Load Range E but hated them, way too stiff. Ruined the ride.
    I have watch many YouTube videos where guys are towing really heavy on stock tires without issue.
  11. Aug 12, 2022 at 9:31 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I may use the wrong terminology but that WDH has chains and thus is not one I'd describe as having "trunnion bars". Not that it should matter for your setup.
    I thought the WDH was supposed to be set based on sag, not weight. Measure the height of your front truck fender on level ground without the trailer hitched. Then hitch up the trailer and hook up the bars. They should bring your front fender back to its original position or close. If not, you don't have the right amount of weight distribution.
  12. Aug 12, 2022 at 9:32 AM
    Nightshade Tundra
    Alex
    I towed heavy with the stock tires on my old Tundra and it was awfull
  13. Aug 12, 2022 at 9:38 AM
    Have you tried towing without the WDH? It’s not required on the Tundra until 5k. You can get away control without load distribution.
    Your tires are fine. Load range C tires will out perform the P-Metric car tires.
    Terndrerrr and AZBoatHauler like this.
  14. Aug 12, 2022 at 9:39 AM
    Doug2000
    So when I do a setup. I set the trailer level so the frame is parallel to the ground so there is even weight on each axle. Measure the fenders on the truck and make note before hitching. Hitch up and add the bars adding links till the back fenders are just below stock height.
    Doing this, I confirmed on the scales I was around 360lbs or 10% tongue weight.
  15. Aug 12, 2022 at 9:41 AM
    Doug2000
    The bouncing is worse without the bars. If I take the trailer to storage, I don’t set them up. It’s only OK for a short run.
    The truck is a 2017 with only 41,000km. I only drive it for fun.
  16. Aug 12, 2022 at 9:45 AM
    Doug2000
    I would say it is porpoising. Both the truck and trailer are bouncing at the hitch.
    I have tried the torsion bars at 2 links there is not a lot of tension on them.
  17. Aug 12, 2022 at 9:45 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    With your front lifting 1/4" at most when you hitch the trailer, I would argue you don't need the WDH.
    GODZILLA and AZBoatHauler like this.
  18. Aug 12, 2022 at 9:45 AM
    AZBoatHauler
    So.Arizona
    I’d really try filling up everything (water, propane, etc) and increasing the tongue weight. Sounds like it’s ass heavy which wouldn’t be surprising for a 4,000lb trailer with 240lbs tongue weight.
  19. Aug 12, 2022 at 9:54 AM
    Nightshade Tundra
    Alex
    Have you searched the trailer on the web to see if others are experiencing the same issue? I would think its to new to have leaf spring issues or axle issues but you may want to get those checked as well
    ColoradoTJ likes this.
  20. Aug 12, 2022 at 9:55 AM
    Doug2000
    I always run 31psi front and 33psi rear. The trailer is set to 50psi as per Escape.
    I run the tire pressures on the Tundra door jam. I had asked here on the forum what the tire pressure was listed on the TRD Rock Warrior edition built from 2009 to 2013 but didn’t get a straight answer. That is where the wheels came from. I had them refinished.
  21. Aug 12, 2022 at 9:56 AM
    AZBoatHauler
    So.Arizona
    I’d bump the rear pressure to 45. Front around 40. The door jamb is for p-rated tires - truck tires need more pressure.
  22. Aug 12, 2022 at 9:57 AM
    Doug2000
    I’m going to post a link to this discussion on Escapeforum.org to see if anyone has any insight.
  23. Aug 12, 2022 at 9:57 AM
    Nightshade Tundra
    Alex
    I would bump up that tire pressure
    gnatehack, GODZILLA and AZBoatHauler like this.
  24. Aug 12, 2022 at 9:59 AM
    Personally, I think you have too much hitch.
    I have had two LDH for the same trailers. One was for my 14k rated flatbed and the other was for my camper 860 lb tongue weight. I have mixed the two bars up before and I had the same reaction you are having. One set of bars was 1000 lb and the other was 1200 lb. Even with the heavy bars on the flatbed we’re rough if I didn’t have the weight. Most often I carried both sets of bars.
    I don’t want you to take my advice either. I’m just some dummy on the internet. Read it from the Pro’s and calculate it for yourself. That’s what I had to do back in the day.
    https://www.etrailer.com/faq-2-steps-weight-distribution-size.aspx
    No offense, but those chain style WDH are often not what you are looking for. Make sure they are reverse rated. I never knew that on my first LDH and had some damage done to my hitch/trailer when it came apart. FYI
    Luckydog, blenton, GODZILLA and 2 others like this.
  25. Aug 12, 2022 at 10:03 AM
    Nightshade Tundra
    Alex
    I have to ask how are you setting up your WDH? are you jacking up the truck and trailer together and then connecting your chains to your trailer tongue or just connecting your chains without jacking up your truck and trailer?
    I personally use a chain style WDH and have never had issues but I know that some people out there don't like that style either
    Cpl_Punishment and ColoradoTJ like this.
  26. Aug 12, 2022 at 10:07 AM
    Is yours reverse rated?
  27. Aug 12, 2022 at 10:08 AM
    blenton
    blenton New Member
    Agreed. Under 5k with a full-size truck and a weight distributing hitch is adding too much spring to the back of the truck. There’s not enough tongue weight to “flex” the distribution bars and they just bounce down the road like you have an unloaded 1 ton dually.
    I’ve done the same thing with a WD hitch on a car hauler. Unloaded the car and thought to drop a few links on the WD hitch bu left it engaged. Bounced horribly with a rough ride.
  28. Aug 12, 2022 at 10:10 AM
    He did say it was worse without the LDH.
    Maybe the RAS could be the ticket. Everyone I know that has that setup is beside themselves on how well they work.
  29. Aug 12, 2022 at 10:12 AM
    AZBoatHauler
    So.Arizona
    IMO - The WDH hitch may mask some of the porpoising due to the bars but that doesn’t necessarily mean he is heading in the right direction.
  30. Aug 12, 2022 at 10:13 AM
    blenton
    blenton New Member
    Ah. Must have overlooked that…
