New Morimoto 14-21 Tundra Taillights have FINALLY arrived!
Discussion in 'Lighting' started by Headlight Revolution, Mar 24, 2022.
  1. Jul 11, 2022 at 10:04 AM
    #121
    King R 808
    King R 808 New Member
    2020 White Tundra TRD Pro
    I have morimoto gen2 heads and the new tails. I had a hyperflash issue but it was fixed when i added the included resistors to my tails.
    mZiggy[QUOTED] likes this.
  2. Jul 11, 2022 at 1:51 PM
    #122
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    That's what I'm doing as well, after trying to file a warranty claim they wouldn't go for it so Colton said he would send me a replacement set. My right one isn't bad at all, the left though looks similar to yours and pretty rough. I don't quite understand how you can pay a nice amount for taillights that clearly have a defect and they just chalk it up to the design of the mold. I get that there is a darker area on the middle inside, but it shouldn't be so irregular and chipped.
    King R 808[QUOTED] likes this.
  3. Jul 11, 2022 at 2:40 PM
    #123
    King R 808
    How long have you been trying to get it replaced?
  4. Jul 12, 2022 at 4:47 PM
    #124
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    It was a week or so going back and forth with Morimoto trying to get them to cover it under warranty and then middle of last week when Hot Shot said they put in the order for the replacement sent. Haven't heard anything recently though.
  5. Jul 12, 2022 at 5:14 PM
    #125
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Yeah I don't want to get in the business of doing this, but I wanted to make sure you were made right because I didn't like it either so I'll be essentially eating this set :anonymous:. I'll be able to resell them though (probably here) if I can't get Morimoto to take them back so I'm not too concerned. I just wanted to make clear that Hotshot Offroad is NOT the Morimoto warranty department :rofl:
  6. Jul 13, 2022 at 1:12 PM
    #126
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    I know. It’s pretty much a garbage situation and I appreciate your help with it.
    memario1214[QUOTED] likes this.
  7. Jul 15, 2022 at 1:58 PM
    #127
    CaptainTundyBear
    CaptainTundyBear New Member
    Austin
    2021 AG Limited
    Did anyone have any issues installing these on the drivers side? The resistor keeps meeting the tailgate assist arm so there’s resistance when closing the tailgate.
    Any recommendations?
  8. Jul 18, 2022 at 6:21 AM
    #128
    King R 808
    So something told me to walk to the rear of my truck when the lights are on and make sure the parking lights were on. For some reason the tails do not light up when the heads are on. the brake light, and turn signals work but no running lights. I double checked the fuse under the hood since the instructions that came with the heads said to pull the wrong fuse and I did in fact plug it in the right spot which is the fuse slot above where the instructions say to put it and the fuse is good to go. I pulled the fuse under the drivers side panel labels TAIL and that fuse is good to go also. I even went as far as putting my OEM tails back on and sure enough those no longer work either.... Seems like a fuse issue and i havent gone and pulled each fuse out to check each one yet because its been raining the past few days but i think i will need to. Any other idea of what it could be? I'm supposed to get a vehicle inspection at the end of the week so i can get new plates since i moved but without the parking lights working i wont pass.
    CorpsTundra likes this.
  9. Jul 21, 2022 at 12:25 PM
    #129
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    I just hung mine loose on the drivers side and tried to zip tie it the best I could to the other harnesses.
  10. Jul 22, 2022 at 5:13 AM
    #130
    King R 808
    I gotta say that the past two weeks of dealing with my Morimoto heads and tails has been a pain in the ass. However, thank you to @memario1214 and @Tundra234 for the comments and advice on my questions. @memario1214 spent some time with me on the phone and emailed me back and fourth multiple times. I got everything working finally! So just in case anyone else has this issue i'll post below the fix.
    The hyperflash on my heads were fixed when I installed the included resistors with the tails. The turn signals and brakes worked without issue after that until i decided to check if the running lights worked on my tails. turned out the license plate light, tails, and third light on top of the cab had no light when it was dark outside and my heads were on. (easy way for a quick ticket when driving at night) So in July of 2020 Toyota issued a recall for trucks with front turn signals and front hazard warning lights that do not flash brightly enough. To fix the recall the basically moved one wire in the headlight turn signal harness (picture below) and fixed their issue. At the time i didnt have Mori heads/tails so when they did my recall everything was good. However, fast forward 2 years and i install them the issue came. After a few days of working with @memario1214 and Mori tech guys I "un-did" the recall. At first no luck and nothing changed. However, I checked the kick panel 10A "TAIL" fuse and it was blown. After i replaced the fuse BANGO everything up and running! So long story short if you have a 20 PRO with the recall completed for the turn signals you MUST un-do the recall to get your heads/tails working properly.
    Side note though I have ZERO clue as to why this isnt something mentioned in the make shift Mori instructions or anywhere on the website. I highly doubt I'm the first one to have this issue... Especially it literally took Mori not even 12 hours to email me the fix.
    CorpsTundra and RoniusMaximus like this.
  11. Jul 22, 2022 at 6:57 AM
    #131
    coTony
    Tony
    Montrose, CO
    I bought the Morimoto headlights in 2019 for my 2018 and had issues from the first day. It took numerous emails back and forth that involved Morimoto and several other distributors trying to fix it. I finally got this fix this January. Customer Service
  12. Jul 22, 2022 at 7:02 AM
    #132
    King R 808
    WOW. So i guess i was lucky!
  13. Jul 22, 2022 at 2:31 PM
    #133
    memario1214
    Colton
    Missoula, MT
    I can't even believe that this recall was a thing in the first place... Do you know what years were affected by it? This was such a dumb thing to have to try and troubleshoot :rofl:
  14. Jul 22, 2022 at 2:41 PM
    #134
  15. Jul 22, 2022 at 5:42 PM
    #135
    King R 808
  16. Aug 10, 2022 at 9:37 PM
    #136
    RoniusMaximus
    RoniusMaximus The One and Only
    J
    Tri-Cities, Washington
    2020 MGM Toyota Tundra TRD PRO
    Synthetic Blinker Fluid
    A few more pics.
  17. Aug 17, 2022 at 3:57 PM
    #137
    Cliffy34
    Cliffy34 New Member
    Pittsburgh
    2018 White Tundra SR5 Crewmax
    Any idea on when/where these are available? Checked a few sites and they all seem to be back ordered.
  18. Aug 17, 2022 at 4:40 PM
    #138
    memario1214
    Colton
    Missoula, MT
    Supplier is experiencing delays, and the latest ETA on a restock for any of us is early November.
  19. Aug 21, 2022 at 4:51 PM
    #139
    RoniusMaximus
    J
    I have a 2020 TRD pro that arrived a week before the recall about the dim lights and when I provided my VIN to Toyota they said my truck was not affected. Do you think in my case id have to switch those 2x wire pins? Anyone with a 2021 trd pro and mori gen 2 headlights able to confirm this?
    Im asking because I am really really tempted to buy the new morimoto headlights and take up that free foglight offer.
  20. Aug 21, 2022 at 5:55 PM
    #140
    Those foglights really aren't that good. Most people sell them and go with something else.
  21. Aug 21, 2022 at 8:45 PM
    #141
    RoniusMaximus
    J
    I pulled up next to a buddy who has them and came away impressed when compared to my oem rigid fogs.
  22. Aug 21, 2022 at 9:17 PM
    #142
    BigAl
    BigAl New Member
    2014 SR5 Magnuson SC
    Can someone post up a picture of their tails with the red lens? I know HR's website has some, but it would be nice to see some more.
  23. Aug 22, 2022 at 8:48 AM
    #143
    memario1214
    Colton
    Missoula, MT
    The light recall I believe only impacted trucks originally equipped with halogen headlights so your Pro shouldn't be affected. :notsure: Either way I have a '21 Limited, was not impacted by the recall, and have Gen2 Morimoto headlights. Zero issues.
    Also, if you want to jump on the deal let me know. We can help you out here at Hotshot Offroad :cool:
    I'm thinking that you're thinking of the Morimoto XB fog lights. They were the first to the game, and they are admittedly pretty poor. @RoniusMaximus is talking about the 4Bangers. They are a far better product. I still believe that the SS3 Max is a better fog light, but the new 4Bangers in HXB output is a solid performer. And considering they can be added in FREE upon purchasing a set of XB headlights they are a pretty solid upgrade.
    RoniusMaximus[QUOTED] likes this.
  24. Aug 22, 2022 at 9:31 AM
    #144
    That is correct. I was referring to the Morimoto fogs. I forgot that they were including the 4Bangers with new orders now.
  25. Sep 6, 2022 at 7:00 PM
    #145
    mZiggy
    mZiggy Honey badger
    Marc
    2020 Tundra SR5-CM; 2020 4R TRD Pro; 2008 4R SR5 v8
    Love them.
    The tails are still on my list to eventually get for my MGM.
  26. Sep 6, 2022 at 7:03 PM
    #146
    mZiggy
    mZiggy Honey badger
    Marc
    This is correct, just the halogens.
    What I've been trying to figure out is if I still need to get the recall done since I have the morimoto xb headlights already. I'd actually installed them before finding out about the recall. Haven't had any issues, but I also understand it to be the risk of fire when using your brights and my lows with the XBs are plenty bright, so I never use my highs lol
    Anyway, point being is that idk if the factory harness leading into the aftermarket harness + housing removes the risk or not?
  27. Sep 6, 2022 at 7:13 PM
    #147
    I have the XB's as well and I am not having the recall done.
  28. Sep 6, 2022 at 7:14 PM
    #148
    mZiggy
    mZiggy Honey badger
    Marc
    Makes two of us I suppose. Lol
    Thanks man
    Taco-Spike and Tundra234[QUOTED] like this.
  29. Nov 10, 2022 at 6:16 PM
    #149
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    Led 3rd Brake light, looks neat. Think I might be swapping my stock one for this one.
    1BA39C1D-AFDC-44CB-A9ED-5ECDCD91DD4A.jpg 8A65A1B9-104F-4F58-A69E-F63184EEA083.jpg DAB3E3F5-C4D3-4F29-B281-09FA1F7578A6.jpg C25798E8-2E7D-4DFB-972E-93049FA5256F.jpg
    WawaLunar, Y0TA PR0, g6t9ed and 2 others like this.
  30. Nov 10, 2022 at 6:18 PM
    #150
    Taco-Spike
    Two Trucks
    Not bad
