Subwoofer Help?
Discussion in 'Audio & Video' started by Bluetoyotaguy, Aug 10, 2022.
  1. Aug 10, 2022 at 6:31 PM
    Bluetoyotaguy
    Bluetoyotaguy [OP] New Member
    Looking for help, wonder if I can hookup my pioneer sub to my dual sub with built in amp her are some pictures of the wiring situation. I have two wire running to the pioneer a power(right) and a ground (left) what else do I need to do to get this to work?
  2. Aug 10, 2022 at 6:37 PM
    Think things are getting all cobbled together there. I wouldn’t continue to try to integrate these two. They are not designed to be hooked up together. You’ve got the makings of a a crispy burnt truck right there. Wire nuts? Not a great solution. Zoomed in a little far to see, but I swear it looks like you hooked the positive power wire (12v+) and the ground wire up to the speaker leads? You need live and local help. And I suggest unhooking this mess until you find it.
    BrandonL812 and Dawoofles like this.
