Toe’s “last mod, I promise!” Build thread
Discussion in '2.5 Gen Builds (2014-2021)' started by Toe404, May 19, 2021.
  1. May 8, 2022 at 10:14 PM
    Toe404
    Toe404 [OP] just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM
    Decided to treat my truck to a 1st birthday present. Got the 10k service done at work and jumped on a set of 17” RR7 wheels in matte gun metal. Can’t wait to get those wheels installed… now I just need to figure out what tires to get.
    :monocle:
  2. May 15, 2022 at 6:35 PM
    VigTundy
    VigTundy New Member
    Josh
    2019 TRDSport 4x4 5.7L
    Nice parts so far, Great looking truck!
    I just grabbed a set of the RR6 in bronze with beadlocks for my 19 Sport, Excited to get them mounted with the 35s.
    Toe404[OP] likes this.
  3. May 15, 2022 at 10:22 PM
    Toe404
    Tomas
    Concord ,CA
    thanks @VigTundy ! I can’t wait to get them installed. I wanna run 35’s but I’m pretty sure I’ll need to do a BMC in addition to the 5100’s
  4. May 15, 2022 at 10:24 PM
    Toe404
    Tomas
    Concord ,CA
    Just a couple pics after a wash
  5. May 16, 2022 at 6:21 AM
    VigTundy
    VigTundy New Member
    Josh
    It's fairly cheap to do and most local shops should be able to. I've owned and modded a couple Tacomas and always wanted 35s so I figured why not on the Tundra. I believe around $350 to do it. What size tires do you plan on running if not 35's?
  6. May 16, 2022 at 7:31 AM
    Toe404
    Tomas
    Concord ,CA
    ok that’s good to know, originally I was thinking of running 285/70/17, but I figure I may as well just go to 295/70/17’s
  7. May 18, 2022 at 8:21 PM
    Toe404
    Tomas
    Concord ,CA
    A lot going on in the past 2 weeks!
    My 5100 bilsteins arrived, placed the order for everything I need from Coach Builders, ordered some 20mm longer wheel studs to make sure my new RRW wheels are properly mounted, also ordered the ET locking lug nuts and lug locks direct from Relations Race Wheels. Also got some useless TRD accessories for some street cred.
    Black@Blue19, DannyD303 and VigTundy like this.
  8. Aug 9, 2022 at 11:24 PM
    Toe404
    Tomas
    Concord ,CA
    Been meaning to update my build thread for a while, been so busy with working two jobs and I got married on July 31st.
    anyways. I got a 3 bay switch plate to go in the credit card holder space. Plan is to add the front any time kit, relocate my rear window switch and get a light bar for the front at some point.
  9. Aug 9, 2022 at 11:31 PM
    Toe404
    Tomas
    Concord ,CA
    Also my wheels and tires, coach builder parts, bilstein 5100 shocks all arrived. Still DYING to get it all installed.
    Relations race wheels RR7 17”x8.5” at 0 offset
    Relations race wheels black lug nuts
    Relations race wheels black lug locks
    eBay 20mm longer wheel studs
    Bilstein 5100 adjustable struts/shocks
    Falken WildPeaks AT3 35x12.5x17
    Coach builder +2” rear shackles
    Coach builder brake line relocation kit
    Coach builder carrier bearing drop kit
    Coach builder front differential drop kit
    Coach builder bump stop spacer kit
    Coach builder coilover shims (2 driver, 1 passenger)
    Coach builder Front Bumper Shims
  10. Oct 3, 2022 at 1:28 AM
    Toe404
    Tomas
    Concord ,CA
    Just a couple small updates. Installed my coach builder bumper shims and a set of high flying black stereo surround covers. Picked up a set of N-fab Podium side steps for only 100 bucks on Craig’s list. Couple small scratches but damn near new.
    Should be getting my wheels and suspension installed in the next couple weeks. Tomorrow if I’m not being a lazy ass I’ll install my front anytime camera and relocate my rear window switch
    Black@Blue19 and bulldog93 like this.
  11. Oct 3, 2022 at 3:47 AM
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    Can you post a pic of your wheels? I want to get 17s with 0 offset. Just want to see how much poke.
  12. Oct 3, 2022 at 5:03 AM
    Nightshade1970
    Nightshade1970 New Member
    2021 Tundra Nightshade Edition
    Carven Exhaust, Nitto Ridge, Bora 2" spacers, TRD Rear Sway, AFE Air Filter, LED bulbs, Truxedo Pro cover, Eibach 2.0 Coilovers, Smoked taillights, Lamin-X fogs, more mods coming
    I'm looking into doing these myself. Can you let me know what wires you tapped into and was it a difficult job? Thank you.
    Toe404[QUOTED][OP] likes this.
  13. Oct 3, 2022 at 7:33 AM
    Toe404
    Tomas
    Concord ,CA
    I haven’t installed the wheels yet, but here is the group buy thread for these wheels, where people have posted installed pics.
    https://www.tundras.com/threads/rrw-wheels-group-buy-the-rrw-crew.106038/
    and here’s someone else’s truck showing the poke, mind you that these are 37’s.
    2014 Black tundra and bulldog93 like this.
  14. Oct 3, 2022 at 7:49 AM
    Toe404
    Tomas
    Concord ,CA
    wasn’t too bad, in total it probably took me 2.5 hours. I wired them with some quick disconnects just in case I need to remove the mirror. I tapped into the wires for the foot well light. The puddle lights fade on when I walk up to the truck with my keys in my hands. They also fade out when the the locks are pressed on the key fob.
    each light has a red and black wire, the black went to a chassis ground and the reds went to the wire that goes to the interior footwell light, which I’m drawing a blank on the color at the moment.
    Here’s another thread about the install process.
    https://www.tundras.com/threads/installing-puddle-lights-on-factory-sr5-mirrors.44755/page-4
    Gaston, bulldog93 and reywcms like this.
  15. Oct 4, 2022 at 4:54 AM
    Nightshade1970
    Thank you so very much!! Really appreciate it. Gonna tackle this soon
  16. Oct 4, 2022 at 2:46 PM
    Toe404
    Tomas
    Concord ,CA
    Started the ever time consuming sound deadening project. Made the mistake of going a little too high on the back wall of the cab and the deadening material stuck to the glass so I had to do some trimming and clean up.
    Got the backside of the cab done as well as the interior wall of the cab. Bolted the plate back on and started to do the front of the plate and my lady wanted to hang out so this is where I stopped for the day. Got about 3.5 hours in so far
    Black@Blue19, Patch999 and bulldog93 like this.
  17. Oct 4, 2022 at 7:34 PM
    Toe404
    Tomas
    Concord ,CA
    I also put Kilmat on the back side of the tail gate plate and two pieces inside the skin, made a huge difference with the tin sound of the tail gate. Even if I let the latch go it has a nice thud to it. One step closer!
  18. Oct 22, 2022 at 11:39 AM
    Toe404
    Tomas
    Concord ,CA
    Time for install! Tech still has to get the rear coach builder +2 shackles, hence the Carolina squat it currently has.
    stock TPMS swapped into the RRW Wheels.
    so far the 5100’s are installed at top clip with Coach builder struts spacers. 2 on the driver side and 1 on the passenger side.
    Coach builder bump stop extenders, diff drop kit, brake line relocation brackets, and carrier bearing drop are all in.
    body mount chop may be required. I’ll find out after alignment is done
  19. Oct 22, 2022 at 7:47 PM
    Toe404
    Tomas
    Concord ,CA
    Couple pics of the other side
    Black@Blue19, sr5shark and bulldog93 like this.
  20. Oct 24, 2022 at 7:51 PM
    #50
    Toe404
    Tomas
    Concord ,CA
    Just rolled on to the alignment rack. Here’s the specs. Tech said at full lock it rubs on the cab mount and the front of the fender liner before the alignment. I’ll have to check clearance tomorrow after I pick it up. I can push the fender liner forward and drill new holes, and I’ll probably end up doing the CMC.
    bulldog93 likes this.
  21. Oct 27, 2022 at 11:24 AM
    #51
    Toe404
    Tomas
    Concord ,CA
  22. Oct 27, 2022 at 12:48 PM
    #52
    Taco-Spike
    Two Trucks
    Looks badass
  23. Oct 27, 2022 at 2:26 PM
    #53
    0.S.T.
    0.S.T. New Member
    EAST COAST
    2007 BLACK TUNDRA 4X4 CREWMAX LIMITED 5.7 LITER
    Nice build. Truck looks great! Love the color of those rims, they really comp the color of your Rig!
    O.S.T.
  24. Oct 27, 2022 at 2:34 PM
    #54
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Looks great! The gunmetal RR7s with the blue are a sweet combo.
  25. Jan 6, 2023 at 5:40 PM
    #55
    Toe404
    Tomas
    Concord ,CA
    A couple more shots just because
  26. Jan 6, 2023 at 6:02 PM
    #56
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Lookin good brother!
  27. Dec 29, 2023 at 12:20 AM
    #57
    Savmikey47
    Savmikey47 New Member
    Wow nice build. I’m also in the Bay Area. Vallejo
  28. Jul 27, 2024 at 3:50 PM
    #58
    Toe404
    Tomas
    Concord ,CA
    Hey guys it’s been a while!
    currently at 23,780 miles. Got an oil change and tire rotation done. Sadly found out that the RRW security locking lug nuts are not compatible with the EBay extended studs.
    I had asked the tech, when the new wheels and studs were installed to put the locks on FIRST, then tighten and give the wheel a wiggle because I wasn’t sure if they would bottom out on the stud or the rim. Well he said “there all good”
    turns out they were in fact bottoming out on the longer eBay studs BEFORE they would fully seat on the rim. I should have measured and triple checked.
    thankfully these rims are hub centric and that really helps keep some of the weight off the individual lugs but now one stud on each side of the front end are toasted and new studs need to be installed. You can see where there’s one stud that has rust around it from where the rim wasn’t fully seated against the rotors and now the treads are damaged. At least it wasn’t worse…
    also my passenger side diode dynamics fog light has been flickering. Found a wire had broken so I’ll be repairing that as well.
    #58
