831Tun How'd I get here build?
Discussion in '2.5 Gen Builds (2014-2021)' started by 831Tun, Mar 16, 2018.
  1. Jul 19, 2022 at 4:27 PM
    #1141
    831Tun
    831Tun [OP] heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I think it's the same place Alex ordered from, OHC on Ebay. And, I think the stripe is off a hair. :cool:
    SpeshulED and joonbug like this.
  2. Jul 19, 2022 at 4:29 PM
    #1142
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Revesol on Ebay makes one with a red stripe and stitching that's pretty nice and substantially cheaper. I have one of the Revesol ones but I kinda ruined it.
  3. Jul 23, 2022 at 9:11 AM
    #1143
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Started shock therapy today. I found it extremely difficult to determine what the shim stacks are in my coil overs. The info available at Poly Performance said I had a 12 20 stack on the compression side. That's .012 thickness for the two largest diameter shims and .020 for the remaining four. In reality I found it's a straight 12 stack.
    So what's all this got to do with the price of tea in China??
    Well, I'm happy with the rebound so not messing with that stack, BTW, it's a straight .008. I'm happy with slow speed compression (big hits and g-outs). But the high speed, little stuff feels a little harsher than I'd like. The plan is to add two more shims to the compression side between the piston and the first (largest) shim. So, another .012 thick 1.75 dia. shim next to the piston separated from the original stack with a .02 thick .085 dia shim. The idea is allow the first large shim to flex and pass oil more easily. @osidepunker did something similar with his Fox shocks but Fox has a different # system for their shims so this is a bit of shot in the dark...........fingers crossed.shock valving.jpg
    Compression side Rebound side
    Thickness Dia Thickness Dia
    .012 1.75
    .020 .085
    .012 1.75 .008 1.75
    .012 1.60 .008 1.60
    .012 1.50 .008 1.50
    .012 1.30 .008 1.30
    .012 1.15 .008 1.15
    .012 1.00 .008 1.00
    jc153, TG705, joonbug and 6 others like this.
  4. Jul 23, 2022 at 10:00 AM
    #1144
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I need to dive into this once I sort out some clearance issues
    831Tun[OP] likes this.
  5. Jul 26, 2022 at 1:10 PM
    #1145
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    So, initial impression of the re-valve is that it did exactly what I'd hoped (pure luck) in terms of small, high speed bumps. Now I need to get it in the dirt and check the bigger, slow speed stuff. I'm testing with the bypasses removed and at this point I'm hoping any issues with big stuff can be tuned via the bypasses. I feel this is very unlikely since I really have no clue what I'm doing and it'd be remarkably unusual to dial it in without a lot more re-valving attempts. :fingerscrossed:
    Blang805, jc153, joonbug and 5 others like this.
  6. Jul 26, 2022 at 1:11 PM
    #1146
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    LOL pure luck. I'll be keeping an eye on this progress!
  7. Jul 27, 2022 at 3:19 PM
    #1147
    SCRunner12
    SCRunner12 New Member
    Robert
    Santa Cruz, CA
    2015 SR5 Crewmax
    What shop did your regear and do you remember the pricing? My truck came with 35's and while it's fine around town, I'd love to have some of the power back when towing/highway.
  8. Jul 27, 2022 at 3:34 PM
    #1148
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    The place was called Wright's in Salinas and was just under $1,400 to re-gear front, rear and install an ARB locker. They've retired since. There's a place up in the bay area where @Shelbie67 had his done and I think Joon is maybe getting ready to have his done there too. It might be all the way up in Walnut Creek. Lemme know if you want the guy's info or Joon might have it.
  9. Jul 29, 2022 at 8:14 PM
    #1149
    SCRunner12
    Robert
    Santa Cruz, CA
    2015 SR5 Crewmax
    Hmm Walnut Creek to SC on a break in schedule sounds fun…haha
    Might see if TFR Motorsports on 17th does regears. They seem to do a lot of fabrication and builds. Thanks for the help. Now to decide 4.88 or 5.29. No plans to go bigger than 35’s and want the best driving characteristics.
    831Tun[QUOTED][OP] likes this.
  10. Jul 29, 2022 at 8:26 PM
    #1150
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    4.88s would be my choice for 35s. If you get REM polished gears I think you can drive from Walnut Creek home w/o having to stop for a cool down like I did coming back from Salinas. But, lots easier to get 'em done locally. You just wanna be sure they know what they're doing. BTW, I think I met the TFR guys dad. I think he's a plumber and came in to do some work when I was remodeling Malone's bar and grill in Scott's Valley.
    TG705 and joonbug like this.
  11. Aug 9, 2022 at 12:07 PM
    #1151
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    Does that brace clear superchargers?
  12. Aug 9, 2022 at 2:26 PM
    #1152
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    That's a great question, I've wondered that myself. If you really want the brace (I highly recommend it for those that drive fast offroad) I'm certain Kyle could make it work.
    joonbug likes this.
  13. Aug 9, 2022 at 2:34 PM
    #1153
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    The way it is currently I’m gonna say no.
  14. Aug 9, 2022 at 2:40 PM
    #1154
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Yours is BA but different than mine. Yours looks bigger. ;)
    joonbug[QUOTED] likes this.
  15. Aug 9, 2022 at 2:45 PM
    #1155
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Noice.
  16. Aug 9, 2022 at 2:49 PM
    #1156
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Really? Post a pic
  17. Aug 9, 2022 at 3:03 PM
    #1157
    Vizsla
    Vizsla 2 = 2.5
    The brace was my doing, spent a good bit of time and money on it, with the intention making it available to others. Unfortunately shared what I was doing with the wrong person, and that person immediately contacted the fab shop I hired to do the work trying to buy it. Caused problems. I do know if it fits with a supercharger, but you would want one made out of tube. Feel free to dm with questions.
    Yours is supposed to clear a supercharger.:cool:
  18. Aug 9, 2022 at 4:04 PM
    #1158
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Really? He made it fit a supercharger but couldn’t make it fit a flimsy plastic engine cover? :rofl:
  19. Aug 9, 2022 at 4:20 PM
    #1159
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Me? Did I cause problems? I think I might've ordered the 2nd one?
  20. Aug 9, 2022 at 8:51 PM
    #1160
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I’d definitely want this in the future.
    Vizsla[QUOTED] likes this.
  21. Jan 8, 2023 at 1:44 PM
    #1161
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Despite having the SDHQ sensor guards, I broke an ABS wheel sensor in Baja. Joseph from BRM epoxied it back together and surprisingly it held up for the rest of the trip. The Jomax sensor guards look like they afford a little more protection so I decided to upgrade just the rear as that's where the real punishment and rock slinging occurs.
    So, here are some comparison photos. BTW, if anyone's looking for some free, gently abused, SDHQ sensor coversJomax vs SDHQ.jpg ByeSDHQ.jpg JomaxJan2023.jpg ......
    jc153, Sunnier, eccracer104 and 5 others like this.
  22. Jan 8, 2023 at 1:47 PM
    #1162
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    Nothing on that truck has been gentle :rofl::rofl::rofl::rofl:
    Sunnier, TG705, sr5shark and 2 others like this.
  23. Jan 31, 2023 at 7:21 PM
    #1163
    Blang805
    Blang805 New Member
    Central Coast California
    2010 CrewMax Platinum 4x4
    Build in Signature
    sweet build man. i like it.
  24. Jan 31, 2023 at 7:25 PM
    #1164
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Thank you
    Blang805[QUOTED] likes this.
  25. Jan 31, 2023 at 8:03 PM
    #1165
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I was actually just looking at these. We ran into abs sensor issues probably due to hitting all the water and ice at speeds. My current ones seem ok but these look like they offer way more protection. Currently running these https://snsdesigns.biz/products/toyota-abs-sensor-guard
  26. Jan 31, 2023 at 8:23 PM
    #1166
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    The ones in your link look like they at least offer better protection than my old ones. With the Jomax ones I can't imagine damaging the sensor itself, the wire remains a little vulnerable. Baja is brutal and not breaking down is priceless.
    joonbug, Mater and reywcms[QUOTED] like this.
  27. Feb 1, 2023 at 7:00 AM
    #1167
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Sounds like a good Mastercard commercial :rofl:
    reywcms, joonbug, Mater and 1 other person like this.
  28. Feb 10, 2023 at 12:39 PM
    #1168
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    Hey Warren,
    Those sensor guards do look to provide more coverage. Were you able to buy just the rear guards? Where did you order from?
  29. Feb 10, 2023 at 6:36 PM
    #1169
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    jc153[QUOTED] likes this.
