Key option
Discussion in '2nd Gen Tundras (2007-2013)' started by Jdm206, Aug 6, 2022.
  1. Aug 6, 2022 at 11:07 AM
    Jdm206
    Jdm206 [OP] New Member
    2012 green tundra
    Exhaust
    My wife lost my second set of keys, so I was looking for options if I can have a key fob like the 4Runners and other Toyota cars. Is this doable with our truck or am I stuck with having a key and remote. I’ve search the forum and I can’t get a direct answer
  2. Aug 6, 2022 at 11:16 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    BlueCrushSC16 and PhotoNerd like this.
  3. Aug 6, 2022 at 3:52 PM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
  4. Aug 6, 2022 at 5:15 PM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    I had one of these before I installed my compustar remote start. It's one of my spare keys now.
  5. Aug 7, 2022 at 8:22 AM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    2013 5.7 4WD CM Bench-Seat Silver
    6” Pro Comp 37’s Custom audio and interior Off road capability is current focus
    EDC style - the key folds in half for a key and fob all in one.
    1st 2 locksmiths said it’s not possible but I said yeah huh. 3rd locksmith said sure NP and anyone who says it’s not possible is a newb.
    JCBerb and PhotoNerd like this.
  6. Aug 8, 2022 at 5:59 PM
    Jdm206
    2012 green tundra
    Exhaust
    Was the key fob a g chip too. Just worried nothing will program if I buy the new key
  7. Aug 8, 2022 at 9:55 PM
    JCBerb
    JCBerb Semper Fi
    Joel
    2017 CM LImited
    C4 Overland bumper, BD SAE fogs, Leitner Designs Rack, Rago Bed Channel Stiffiners, Warn Xeon 12S Plarinum, Bedslide, Front Runner Roof Rack, roof rack solar panels, RCI Full under carriage aluminum studs, RCI rear diff skid, Rago dash plate, Rago accessory panels, OEM LED headlights with wiring harness.
    I did one of these a while ago. Have to make sure the letter on your key matches the one you buy and then you can even program it yourself if you buy the cable and install the software. I had mine cut at a locksmiths store no problem or excuses. It wasn't perfect and wouldn't turn the ignition so I had to gently file a tooth down a bit and programmed it in techstream myself... done.
    Ohannon7 likes this.
  8. Aug 9, 2022 at 4:37 AM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    im not sure.
    I started to try to buy it myself but could tell I was in over my head so I just worked directly through the locksmiths.
    he showed me a picture (via text) of what key he could get and program. I said OK and he ordered it. Once it arrived a few days later I met him and he programmed it. I paid like $150 for the key and the, cut, and the programming. (Tampa).
    thank you and good luck all!
