  1. Jul 7, 2017 at 6:58 PM
    #7711
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Dayam!!
    1UPPER likes this.
  2. Jul 7, 2017 at 7:07 PM
    #7712
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    Now that's dedication and attention to detail lol
    1UPPER[QUOTED] likes this.
  3. Jul 7, 2017 at 7:12 PM
    #7713
    PaRunnerd
    PaRunnerd No N00B, No Pro.
    Dave
    Lehigh Valley, PA
    2014 Magnetic Gray Tundra SR5
    Plenty planned thanks to all of you.
    Wowzers! That's awesome. It's going to look amazing on your truck.
  4. Jul 7, 2017 at 7:13 PM
    #7714
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Here is a pic with the two 10" Rigid Radiance lights installed. IMG_8394.jpg
  5. Jul 7, 2017 at 7:31 PM
    #7715
    Darth Tundra
    Curt
    17 CM TRD Black
    Will do !!!
  6. Jul 7, 2017 at 7:55 PM
    #7716
    PaulROahu
    PaulROahu New Member
    Paul
    Kaneohe, Hawaii
    2017 5.7 Tundra Platinum 4x4 MGM
    Had time today to instal interior floor LED lights from Sylvania ZEVO 16 color with remote. Had infared installed under passenger front pannel. Ran the driver line under center counsul, the the rear went from passenger side pannel door to under passenger seat and center counsul for rear driver seat. Used the 36" line for rear driver passenger LED. Velcroed the remote with infared facing the passenger side to the rear of shift column. I feel like BLUE LEDs for now as I'm mellow, maybe RED if I'm stuck in traffic..lol
  7. Jul 7, 2017 at 8:38 PM
    #7717
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    Got some kangs installed with out of the box settings, I love them! Plush ride on the street and smooth off road and I removed the front sway bar. My best mod EVAR!
    srad750c, TXMiamiFan, Viper3G and 9 others like this.
  8. Jul 7, 2017 at 10:20 PM
    #7718
    Flyinryank
    Flyinryank New Member
    Las Vegas, NV
    White 2015 CM 4x4
    Installed SDHQ ABS Shields.
    While I was under there I saw that my lower shock mount and shock shaft got bitch slapped by a rock or two haha. Hopefully it doesn't chew through the shock seal.
  9. Jul 7, 2017 at 10:40 PM
    #7719
    edwin729
    edwin729 Tundra Life
    Edwin
    Arizona
    2023 Silver Tundra Crew 4x4 Plat
    Cant wait to see pics of the grille on truck!
  10. Jul 7, 2017 at 10:54 PM
    #7720
    edwin729
    Edwin
    Arizona
    where did you find the carbon shift knob area cover?
  11. Jul 7, 2017 at 10:59 PM
    #7721
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Auto anything under B&I. You order by what kit/ area you want to carbon fiber over lay. Kinda expensive but quality is good as it gives you a another layer of protection. I bought the complete kit for interior and exterior
  12. Jul 7, 2017 at 11:56 PM
    #7722
    Agitated1
    Agitated1 Newish Member
    Los Angeles
    2017 Tundra Crewmax TRD 4x4 Quicksand
    TRD Pro Grill King Coilovers with compression adjuster Tint 5% Rear, 30% front and 70% windshield Husky X-Act Floor liners BA Muffler 8in standard system Truck Covers USA retractable bed cover Yakima bed rails
    Nice setup. I just installed mine last weekend.
  13. Jul 8, 2017 at 9:04 AM
    #7723
    1UPPER
    TEXAS
    Flux capacitor!
    So I had to loosen all 84 bolts again to mount the upper frame mount. Ugh! The upper mount has an arch to it to arch the frame. This grill is a lot of work for sure. But patience is key when they don't give you any instructions. Lol IMG_8398.jpg IMG_8409.jpg
  14. Jul 8, 2017 at 9:18 AM
    #7724
    Eclipsed & Floating
    Eclipsed & Floating Over it.........
    I’m right where I need to be
    Voluptuous Whitey
    SEXY
    Krezz[QUOTED] likes this.
  15. Jul 8, 2017 at 10:04 AM
    #7725
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    Agreed!!
    Watt maker likes this.
  16. Jul 8, 2017 at 11:06 AM
    #7726
    Samoan Thor
    Hory Shit! I have asked before but I was told there was no demand for it but my question was if anyone knows who makes skid plates for the shock mounts cuz I was worried that might happen.
  17. Jul 8, 2017 at 11:35 AM
    #7727
    edwin729
    Edwin
    Arizona
    Do you have pics of radio console and dash area with overlay?
  18. Jul 8, 2017 at 11:36 AM
    #7728
    KrazieZ
    KrazieZ New Member
    Zachary
    2017 Toyota Tundra sr5
    K&n filter, leather seats, stubby antenna
    So how did you run the wire from back seat to the other back seat ? Under center console or what ?
  19. Jul 8, 2017 at 11:58 AM
    #7729
    PaulROahu
    Paul
    Kaneohe, Hawaii
  20. Jul 8, 2017 at 12:01 PM
    #7730
    PaulROahu
    Paul
    Kaneohe, Hawaii
    You can choice between multiple cabin fiber colors
  21. Jul 8, 2017 at 12:06 PM
    #7731
    PaulROahu
    Paul
    Kaneohe, Hawaii
    From the passenger back seat used the longer wire connector 36" and went under back side of rear center counsul. The two wires split from the passenger side door pannel that's why you need the longer piece to fit. Taped the LEDs to rear cross sliding plate so not to pinch any wires. I'll. Try take some pics later
    KrazieZ[QUOTED] likes this.
  22. Jul 8, 2017 at 2:28 PM
    #7732
    mgm16trdpro
    Northern NJ
    Yes that's correct. If u stick the wire under the rear of center console u can kinda work it like dental floss further and further under, almost to where it goes straight across to both seats. Hope helps.
    KrazieZ[QUOTED] and PaulROahu like this.
  23. Jul 8, 2017 at 3:35 PM
    #7733
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    Added the bottle opener today. Clearly the best modification you can do to any truck. Adds 5hp, 6 ft/lbs of torque and attracts all the ladies. It's almost impossible to drive it now because there are just to many women in the road wanting my truck.
    19732071_1585153354830121_91861735413281_5a41823d60881bc907063d5ea731b39e19885314.jpg
    Tucked out of the way so nothing sliding in should hang up on it.
    19642591_1585154838163306_49491662261840_dd3d12abfd64ff4a7d16a48712db6324ab5aa07b.jpg
  24. Jul 8, 2017 at 5:32 PM
    #7734
    BakNBlk2014
    BakNBlk2014 So Impossibly Black
    Donald
    Virginia Beach VA
    2014 limited cm attitude black 4x
    BDS 4 1/2 Nitto Terra Grappler 35x12.5/18 BW Fender Flares Moto Metal 970 Wheels Leer Tonneau Bed Cover Black Plastidip Grill CF Wrap Interior AJT Shift Knob 35% Tint Weather Tech Mats Toyota Bed Mat AFE Intake
  25. Jul 8, 2017 at 7:17 PM
    #7735
    bsktball55
    bsktball55 New Member
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    I found out the other day that when you add this little bundle
    Your wife all of a sudden becomes more vocal. You should slow down, this road is too bumpy for her, don't go around that turn so fast, you need to remember, you have a little baby in the back now. Had to go pick up a trailer from my cousin yesterday, he had a very steep gravel driveway that was causing my traction control to kick in. "Do you really think you should be doing this with a baby in the backseat?"
    BlackMaxx, Krezz, 757TUNDRA and 17 others like this.
  26. Jul 8, 2017 at 7:20 PM
    #7736
    1UPPER
    TEXAS
    Flux capacitor!
    I finally finished my grill! It was a lot of work! Had to assemble and disable it three times. I also had to fabricate my own aluminum side brackets and mounting points for the bottom of the grill. It took me 9hrs to install with no breaks. It's very heavy as well. IMG_8417.jpgIMG_8414.jpg IMG_8418.jpgIMG_8419.jpg
    BlackMaxx, Krezz, PaRunnerd and 13 others like this.
  27. Jul 8, 2017 at 8:41 PM
    #7737
    Toeb
    Toeb Well! That escalated quickly!!
    Toby
    North Carolina
    2014 SR5 double cab
    2.5 leveled 20x10 -19 hostile sprockets w/ 305-55-20. And just getting started
    She got a bath today. Then the rain came.
  28. Jul 8, 2017 at 8:58 PM
    #7738
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    :eek: Are there any good trails near you?
    TRD15559 likes this.
  29. Jul 8, 2017 at 10:12 PM
    #7739
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Awesome. Find some (wider) trails and me, @dcsleeper408 and @16tunterd will come up there.
  30. Jul 9, 2017 at 12:39 AM
    #7740
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    Black '14 CM SR5 w/ SC; 40s on 17s; 5.29s
    Bald Mountain? I'm going there this week.
    dcsleeper408 likes this.
