Parking sensors not working
Discussion in '2.5 Gen Tundras (2014-2021)' started by Nasty2sss, Apr 8, 2022.
  1. Apr 8, 2022 at 4:48 PM
    Nasty2sss
    Nasty2sss [OP] New Member
    Phil
    2016 sunsetbronze limited Tundra
    Leveling kit
    Like the title my 2016 limited Tundra,parking sensors do not work anymore.Anyone else have this problem? If so how much to fix? Thanks in advance for any help
  2. Apr 8, 2022 at 4:57 PM
    GreatBasinTundra
    GreatBasinTundra Beer Me!
    Reno, NV
    2020 Tundra SR5 DC
    Kings f/r, TC UCAs, RCI skids, RCI sliders, C4 bumpers f/r, Warn 12s winch, 35s on 17” Rebounds, softopper, wet okole covers
    Try to reset in the settings, check for any associated blown fuses and if all fuses are good, disconnect the battery for a few minutes. Is it both front and rear? I don’t have any parking sensors, but most likely they all did t just stop working. Start with the basic stuff if you haven’t tried these already.
    Nasty2sss[OP] and Ely010606 like this.
  3. Apr 9, 2022 at 4:54 AM
    Nasty2sss
    Phil
    Leveling kit
    I am getting the warning on the dash to check sensors see dealer. Just wondering if anyone else has had the problem
  4. Apr 9, 2022 at 7:05 AM
    Nasty2sss
    Phil
    Leveling kit
    Thank you,I disconnected the battery, reconnected and they seem to work fine. Thanks for the help
  5. Aug 8, 2022 at 9:10 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    my (front left) sensor on my 2016 just goes off when im not close to anything while sitting still. Then when i drive off it stops beeping.
  6. Aug 8, 2022 at 9:29 AM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
    The parking sensor normally goes off when you go above 3-5 mpg but can come back on when you stop again, There is a TSB out on this issue (attached). I bought the parts to fix it but then the problem stopped. Waiting for it to reappear.
    bulldog93 likes this.
